“Appropriate Modeling Approach for Thin Plasma Layers”
  • Context: Graduate
  • Thread starter Thread starter rcc01
rcc01
TL;DR
Asking whether a micron‑scale, low‑density plasma layer can be modeled with standard cold‑plasma permittivity or requires a full inhomogeneous Maxwell treatment, and whether thin‑film approximations (surface impedance, effective index) are valid.
I’m trying to understand how to model EM wave propagation through a very thin, low‑density plasma layer (micron‑scale thickness). The plasma frequency is well below optical frequencies, so the layer remains transparent.
My questions are:
  1. Can such a thin plasma sheet be treated using the standard cold‑plasma permittivity model ε(ω)=1−ωp2/ω2 or do the boundary conditions imposed by the adjacent dielectrics require a full inhomogeneous Maxwell solution?
  2. Are there known approximations for phase delay or index modulation caused by a thin plasma sheet, similar to ionospheric phase‑shift models?
  3. Does the thin‑film geometry allow simplifications such as treating the plasma as a surface impedance or effective boundary layer?
I’m not asking about any device specifics — just the appropriate modeling approach for thin, low‑density plasma layers.
P.S. I previously posted a more optics‑focused version of this question in the Optics section. I’m posting this version here because I’d appreciate input from plasma specialists on the thin‑film case.
Yes, you can model in the "standard" way because it's directly analogous to a multilayer interference filter, but with one of the layers having an unusual dielectric constant.
Yes, simply model your modulator as a layer of thickness ##t## with a frequency-dependent refractive-index ##n_p\left(\omega\right)=\sqrt{1-\omega_{p}^{2}/\omega^{2}}##. You can easily check for a given ##t## how far ##\omega_p## has to be varied (by adjusting the plasma electron density) to achieve, say, a ##180°## phase-shift in visible light as it passes through the layer. To get a sense of what's possible you don't even need to model the other layers: just assume the light starts inside the plasma layer on the left and propagates to the right through a total distance ##t## and see what phase shift you can induce.
Possibly, but why bother? The finite-thickness calculation described above is already almost trivially easy.
Thanks, this is very helpful. Treating it as a multilayer interference filter with one layer having a tunable dielectric constant is a very clear way to think about it.
I’ll start by modeling the plasma as a finite‑thickness layer with a frequency‑dependent refractive index and look at how much index change (via electron density) is needed to get a π phase shift at visible wavelengths for a given thickness.
I had been worried that the adjacent dielectrics might force a much more complicated treatment, so it’s reassuring to know that the standard thin‑film approach is sufficient here.
