Approximation Theory Help: Parameter Estimation & Fitting Curve
34 replies · 7K views
a.mlw.walker
Hi
Is there anyone here who has a good understanding of using approximation theory and parameter estimation techniques who can help me understand a chapter of a paper, and why certain techniques have been used. I have tried to use the given data, and matlabs optimization tools to follow the chapter through, but I cannot get a good fitting curve (at all). the method requires Levenberg marquardt to approximate some parameters, golden section search to improve them, and then a trisection search (which I think is golden section search?) to find more parameters based on the first ones found.
Thanks
Could you post a reference to the article? Not sure if I could help but I'd be happy to take a look.
Great thanks. I have the relevant extract of the paper, which i have attached. I basically want to use levenberg marquardt to solve equation 40 for a,b and c0. The value Tk is:
I have timings for tk: 1.994, 1.806, 1.632, 1.493, 1.2
x tk
1 1.2
2 1.493
3 1.632
4 1.806
5 1.994
Its an oscilating system that slows with time.
Equation 41 apparently is to refine the parameters further, however golden section searc i thought finds a minimum, however i am not sure what minimum, because plotting those points above gives a constant downward gradient.
Equation 42 requires the approximations from 41.
I can't find a way (that i can get to work) to approximate those values. any ideas?
(P.S. I can't upload twice so the image is my attachment about the same question here: https://www.physicsforums.com/showthread.php?t=513060)
I found a link to a pdf of the actual paper, which should make the discussion a bit easier.
http://www.roulette.gmxhome.de/roulette[1].pdf
Equation 40 is a least squares formulation based on equation 35 (which is what I thought a couple of years ago when this topic was first introduced). Based on your 5 timings I did a quick and dirty curve fit using downhill simplex. Not sure I did it right, but both a and c0 are negative and the fit doesn't appear to be very good. The data look rather linear. Is this the same result you got with Matlab?
Yeah for the data points, I used the MATLAB curve fitting tool, but I couldn't get it to do a levenberg marquardt fit. It couldn't converge. Did you use my values for x, I think they should start at zero not 1 thought, but I haven't tried that yet. Is yours a levenberg marquardt fit?
Equation 41 in the paper is supposed to refine the parameters, did you read that bit?
On that website, under manual, you can see his values for a and c0 can be negative. that's not a problem i don't think.
I used MATLAB though to try and do a downhill simplex, but it still can't converge. how did you do that?
The equation i am fitting to is:
Fitted_Curve = (1/(a*b))*(c-asinh(sinh(c)*exp(a*Input*2*pi)));
but the graph after trying to solve is:
Actually I have managed to get it to plot it. But like you, not a very good fit...
You got a bad fit because you fit the wrong parameter. You should be fitting a, b, and c0 by minimizing equation 40,
[tex]S(a,b,c_0) = \sum_{k=0}^N \left\{t_k - \frac 1{ab} \left(c_0-\sinh^{-1}(\sinh c_0\cdot e^{ak\pi})\right)\right\}^2[/tex]
or you should be fitting a by minimizing equation 41.
what is different? are you saying that you either do 40 or 41, not both?
I am saying that the one thing you shouldn't do is to do the fit from post #5 (as quoted in post #7).
From the paper, it looks like the author first did a multivariate fit in equation #40 on parameters a and b and then refined that estimate by doing a fit on a only via equation #41. In other words, equation #40 when minimized gives the final value for b but only an initial guess for a. The final value for a comes from minimizing equation #41.
Note well: That `with' section after equation #41 applies to both equations #40 and #41. In particular, note that c0 is not a tuning parameter. It is instead an ugly expression that is a function of the tuning parameters a and b and of the time difference t1-t0.
I tried that, but I can't get it to produce a good fit (compared to the above graphs) at all. It is closer estimating c0.
From your earlier post
"The equation i am fitting to is:
Fitted_Curve = (1/(a*b))*(c-asinh(sinh(c)*exp(a*Input*2*pi)));"
What I am fitting is actually the difference between this and the actual data.
I understand to freeze b in equation 41 though, however I can't get the golden section search to produce a better estimate, however I am still approximating for c0 at this stage.
You shouldn't be estimating c0. It is merely a stand-in for
[tex]c_0 = -\coth^{-1}\left(\frac{e^{a2\pi}-\cosh(ab(t_1-t_0))}{\sinh(ab(t_1-t_0))}\right)[/tex]
yeah, i can't get that to converge. by the way is t1 - t0 the values up there or is it the difference between those times? i,e tk(1) - tk(2)
Hmmm, if that's the case, the author's description of equation 40 is misleading. He indicates the function to minimize is a function of a,b,c0 implying that all three need to be estimated. He should have said the function to minimize is a function of a,b where c0=xxxxx. Not well written.
hotvette please could you try it, i cent get it work
Yeah, I was wondering that also. If the author uses consistent notation, t0 should be t @ k=0, which is zero according to equation 35. Kind of confusing.
If you mean a two parameter estimation using post #11 as the definition of c0, sure, but I don't think the result will be much better. The data points are close to linear. I doubt they will fit an exponential decay function very well no matter how much the parameters are manipulated. In fact, the fit should be worse because the value of c0 will be restricted, but I'll give it a try (later).
What do you reckon about the original data being cumulative so:
x tk
1 1.2
2 2.695
3 4.325
etc etc. that way t1-t0 would be that time, but fit the curve to the cumulative times?
Edit! yeah, cumulative fits better, much better, and I am using the correct c0. however i am not using the individual timings but the cumulative time for T0, which doesn't seem correct...
Found out that T0 is the time for the initial time value, and is therefore a constant
x tk
1 1.2
2 2.695
3 4.325
Yep, looks better using cumulative. Attached is three parameter fit. However, what do you mean by "Found out that T0 is the time for the initial time value, and is therefore a constant"? Pls elaborate.
Yeah I got better too, but mine curves the other way...(attached). That is using D H's idea that c0 is not a parameter in itself.
The website that you said you found the whole document at says that T0 is the time of the initial revolution, on the page called manual at the bottom somewhere...
What have you plotted on the y axis? I plotted the cumulative time?
I made goof and just now edited my last post with the correct version. Almost a perfect fit (looks identical to yours), though I still used 3 parameters. Looks like you are on the right track.
I'm not going to argue with you on that one! Look at my post #7: I initially thought that equation #40 was a minimization with respect to those three parameters myself. It took a couple of readings to see that this is not the case.
Looks like our collective understanding is converging. I tried a two parameter fit and the result is nearly identical to a three parameter fit. Almost looks too good. :smile:
What still bothers me is the expression T0 = t1 - t0 because it seems to me t0 has to equal zero (based on equation #35).
a.mlw.walker:
Unless you object, I'd like to move this back to mathematics, where you originally asked about this topic.
You didn't get any bites the first time around because you put the question in "General Math" and you gave the thread a bad title ("please can people advise me on this!"). Threads in general math whose titles are of the form "please help me", are entirely in lower case, and ends with "!" are typically from students asking us to do their homework for them while they go toss down a beer. So, other than perhaps the mentor responsible for that section, nobody even looked at your post.
This time around you got bites despite having put the thread in the wrong place (this is not a MechE question) because you gave the thread a good title and kept the original post short and to the point.
Now back to the question at hand:
I have noticed on occasion that a non-linear multivariate fit doesn't seem to fit as well as I'd like and it seems to leave some signal in the residuals. Polishing that initial fit is with a second fit on a restricted set of variables oftentimes does the trick (e.g. as was done in this paper) . That polishing is admittedly a bit ad hoc. If that adhocery doesn't work I either resort to something even more ad hoc or I back up and try again with a drastically different technique.
Cool, we are getting to an aggreement. Hotvette got the two and three parameter fits to agree. Hotvette, on the website you found the actual document on, there is a link to a page called manual.
Search for this line
t0: time of initial revolution
in the chapter called 3. Set Ball.
That is why i think T0 is just the time for the initial timing.
D H
If you would like to move it, do so by all means. Apart from it being specific to parameter estimation, I think the computing side of this problem could allow it to be considered as engineering, however i am not bothered. I don't even know if you have already moved it...
Your point on second fits. How do you know when a fit is good enough to not need a second fit? He does one yes, however the curve looks so good that is there some way to determine whether a second fit is necessary?
Once we do/dont do a second fit, the next problem is equation 42. Can we talk about what he does here. He uses a and b and some approximations for theta_f to optimize for the three parameters.
However he says he can solve it for the one nonlinear parameter first, and the linear parameters linearly.
I have read about this, but I am not sure how the method changes.
What is the method of trisection here? Google can't find much on it, but i suspect its similar to the golden section search as in it finds a minimum as you vary the non linear parameter of 2pi there will be a minimum error to try and find...
Out of interest if you have linear and non linear parameters, can you solve for all of them non linearly and still get the correct linear parameters or does it have to be done the way he mentions - that's only a side note, just wondering...
then the linear parameters can be found by any old meansin the linear equation 43.
Guys, I have tried to use the golden section search for equation 41. It runs successfully but doesn't seem to produce a 'better' fit. What do you reckon. I used beta as ab^2 like he said, and c is a constant from the solution of the first part (attached)
hey guys, you gone on holiday?
In my case it was because I wasn't sure there was anything more I could add that would be useful. I reviewed the paper one more time and am convinced of the following (others may disagree).
1. Step 1: equation #40 is intended to obtain initial estimates of all three parameters (not two) based on equation #35. Subsequent discussion refers to further refinement steps and has nothing to do with equations #35 and #40.
2. Step 2: parameter refinement for a & b using equation #41 (and definition for c0) isn't intended to get a better fit for equation #35. It is meant to get better estimates of a & b for use in step 3.
3. Step 3: using the refined esimtates for a & b from step 2, obtain estimates for the remaining parameters using equation #43
I believe the intention is to discard the previous equations at each new step. Re why the author chose the particular optimization method for each step, it is difficult to say. Perhaps the author tried several methods each time and found one that seemed to work better in each case.
I seem to recall you asking a question about a curve fitting situation where some parameters are linear and others are non-linear. As far as I know, even if only 1 parameter is non-linear they all need to be treated as non-linear. Even if a least squares problem is linear in all unknowns, it can still be approached as a non-linear problem (and solved in a single iteration).
Hope this helps. I really don't think there is anything more of use I can add.
Great thanks Hotvette, however after equation 42, before 43, the author writes that using the method of trisection the value for phi can be found and then the equation becomes a linear equation (43). How would you find the value of phi without also finding the other parameters - or is this what you are saying. solve it completely non linearly and then using the value of phi improve the other approxiomations linearly?
Did you see my graph above, trying to improve the parameter a, gave a worse fit?
It's difficult to unambiguously interpret the paper . I think it's clear that equation #40 is a 3-parameter problem. It clearly says S(a,b,c0) = xxx and all three are mentioned in the next sentence.
Beyond that it's a bit fuzzy. Equation #41 looks like a single parameter problem (i.e. S(a) = xxx) to refine the value of 'a', thus the use of golden section or trisection. Beta is fixed using the values of a & b that were determined from equation #40. What isn't clear is whether c0 is considered fixed using the same values of a & b that were used for Beta or whether 'a' is still considered a variable. Once you solve equation #41, forget about #40 and #35, they no longer apply (that was my point in the previous post).
What's the ultimate goal of this? Predict where the ball will land?
