Are T and T2 the Same in Physics Equilibrium Problems?
  • Thread starter Thread starter prakhargupta3301
    Tension
4 replies · 1K views
prakhargupta3301
In the figures:[/B]
Are T and T2 same?
This is just a yes and no answer[/B]
I don't want anything solved. I've actually solved it already and have gotten T2= T
NOTE( T≠T1 here)
I have solved it but I'm frequently paranoid regarding the errors I make while solving questions. So wanted to make sure.
That's why I needed your help.
CWatters said:
I've just suggested this method over on your other thread.
You can erase the 10kg mass and the 200n force and apply f=ma to what's left.
Well, this is quite obviously equivalent. The main point is that if you have a set of ##N## unknowns you need to draw the free-body diagrams of ##N## different systems where those unknowns (and no other unknowns) appear. In this case, you can draw the fbd of the full system (which in both cases result in the same) and then choose whether or not to draw the FBD of the latter part or the rightmost box. Since ##T_1## is internal it will not appear in any of those FBDs and you end up with two unknowns, ##T_2## and ##a## or (in the first case) ##T## and ##a##.
