Around which points to make T=I(alpha)
  • Thread starter Karol
    Points
30 replies · 4K views · last reply
Karol
I was told that I can use the rigid body angular momentum formula T=I[itex]\alpha[/itex]
Aroud 3 points: a fixed one (I assume the temporary center of rotation), or the center of mass or a point moving parallel to the c.m.
I have tested it with the case shown in the picture: a cylinder rotating on a rough surface, a steady force acting on it's center.
When calculating the angular acceleration [itex]\alpha[/itex] round the points A and C I get the same result, but when calculating around B-a different one, meaning the above is correct.
Why is that? the formula L=I[itex]\omega[/itex] is derived this way:
[tex]L=\sum_{n=1}^N L_n=\sum_{n=1}^N m_nv_n\cdot r_n=\sum_{n=1}^N m_nr^2_n \omega=I\omega[/tex]
So, I understand, in order to get the velocity of the particle correct, I have to calculate only round the stationary point of rotation. The formula T=I[itex]\alpha[/itex] is only the derivative of the former.
Can anyone explain a bit, and give a name of a book that explains this in detail, since some ordinary books talk only in general about this.
  • Diagram of a circle representing a cylinder on a hatched floor, with center C marked, a leftward arrow labeled F from C, a dashed vertical line from C down to point B, point A at the contact point, and a curved arrow above showing rotation.
Hi Karol! :smile:
No, the velocity of B is parallel to that of the centre of mass (C), so the result should be the same.
Have you included the friction force at A (not in the diagram) … if there's no friction, then why would the angular speed change? :wink:
(and sorry, I don't know any book that goes into this :redface:)
There's friction and I included it in my calculation for point B. Around point A:
[tex]T_A=I_A\alpha[/itex]<br /> [tex]FR=(kmR^2+mR^2)\alpha\Rightarrow\alpha=\frac{F}{mR(k+1)}[/itex]<br /> <br /> I get the same [itex]\alpha[/itex] when I calculate round point C.<br /> What is the friction force f ?<br /> [tex]\sum F=ma\Rightarrow F-f=ma=mR\alpha=mR\frac{F}{mR(k+1)}[/tex]<br /> [tex]\Rightarrow f=F\frac{k}{k+1}[/tex]<br /> <br /> Around point B:<br /> <br /> [tex]T_B=I_B\alpha[/itex]<br /> <br /> [tex]F\frac{R}{2}+f\frac{R}{2}=(kmR^2+m\frac{R^2}{4})\alpha[/tex]<br /> [tex]\Rightarrow \alpha=\frac{2F(2k+1)}{mR(k+1)(4k+1)}[/tex]<br /> <br /> And it's not the same as the first.<br /> How do you, Tiny-Tim, know this subject with no book to offer?[/tex][/tex][/tex]
  • Diagram of a wheel of radius R with centre C, resting on a surface at contact point A, with point B on the vertical line between C and A. A red curved arrow shows rotation at the top. A leftward force F acts at the centre C and a rightward friction force f acts at the contact point.
Hi Karol! :smile:
Your formula τB = IBα is wrong :redface: …
The angular momentum about any point P is Iω about the centre of mass (C) plus the (ordinary) moment about B of the total momentum (mvc.o.m.) as if it were at C.
ie LP = ICω + m PC x vc.o.m.
If P is on the axis of rotation, then vc.o.m. = PC x ω, and so LP = (IC + md2)ω = IPω.
In any other case, LP is not IPω
(and τP is not IPα) :wink:
In other words:
The parallel axis theorem (IP = IC + md2) is only useful at the centre of rotation* (or, if you have a body made up of parts, you can apply it at the centre of mass of the whole body for each part for which you know the moment of inertia )
* to be precise: on the axis of rotation​
I assume LP = ICω + m PC x vc.o.m. comes from the transformation of vectors between moving coordinate systems:
[itex]\Vec{A_2}[/itex] is vector A2 relative to the ground
[itex]\Vec{A_1}[/itex] is vector A1 relative to the ground
[itex]\Vec{A_{21}}[/itex] is vector A2 relative to vector A1
[tex]\Vec{A_2}=\Vec{A_1}+\Vec{A_{21}}[/tex]
But I think you switched the places of the vectors in:
vc.o.m. = PC x ω
It should be:
vc.o.m. = ω x PC
Since then the direction of vc.o.m. comes out correct.
How is this equation derived?
LP = ∫∫∫ (r - rP) x ρ v dxdydz
= ∫∫∫ (r - rP) x ρ (ω x (r - rc.o.m.) + vc.o.m.) dxdydz
= ∫∫∫ (r - rP) x ρ (ω x (r - rc.o.m.) dxdydz + (∫∫∫ ρ (r - rP) dxdydz) x vc.o.m.
= ∫∫∫ (r - rc.o.m.) x ρ (ω x (r - rc.o.m.) dxdydz + (mvc.o.m. - mrP) x vc.o.m.
(because ∫∫∫ ρ (r - rc.o.m.) dxdydz = 0)
= Ic.o.m.ω + m PC x vc.o.m. :smile:​
More indirectly, but shorter (with vP being the velocity of the part of the body at position P) …
= ∫∫∫ (r - rP) x ρ (ω x (r - rP) + vP) dxdydz
= ∫∫∫ (r - rP) x ρ (ω x (r - rP)) dxdydz + (∫∫∫ ρ (r - rP) dxdydz) x vP
= IPω + m PC x vP​
and then applying the parallel axis theorem …
= Ic.o.m.ω + m PC x vc.o.m. :wink:​
(and if P is the centre of rotation, so that vP = vc.o.r. = 0, then:
= Ic.o.r.ω)​
First, Tiny-Tim, I thank you very much. You feed my curiosity...
But I don't understand the transition between:
And:
In the first integral, I guess you did:
r - rP=(rc.o.m.-rP)+(r - rc.o.m.)=PC+(r - rc.o.m.)
Taking PC and returning to the integral:
∫∫∫PC x ρ (ω x (r - rc.o.m.) dxdydz=
∫∫∫PC x ρ (ω x r - ω x rc.o.m.) dxdydz=
∫∫∫ρ PC x (ω x r) - PC x (ω x rc.o.m.) dxdydz
None of these yields ∫∫∫ ρ (r - rc.o.m.) dxdydz.
In the second integral:
∫∫∫ρrPdxdydz=mrP
But:
∫∫∫ρrdxdydz Is not equal to mvc.o.m.
Hi Karol! :smile:
In the second integral, you're right … I mistyped mvc.o.m. instead of mrc.o.m. …
the next line is correct, though, since (mrc.o.m. - mrP) x vc.o.m. = m PC x vc.o.m. :wink:
In the first integral, rc.o.m. rP and ω are all independent of x y and z, so they come outside the ∫∫∫, leaving only ∫∫∫ (r - rc.o.m.) dxdydx = 0 :smile:
∫∫∫ (r - rP) x ρ (ω x (r - rc.o.m.) dxdydz=
ρ ω x ∫∫∫ (r - rP) x (r - rc.o.m.) dxdydz=
ρ ω x ∫∫∫ r x (r - rc.o.m.)dxdydz - ∫∫∫rP x (r - rc.o.m.)dxdydz=
ρ ω x ∫∫∫ r x (r - rc.o.m.)dxdydz+0=
ρ ω x (∫∫∫ r x r - ∫∫∫ r x rc.o.m.)=
ω x ∫∫∫ ρ r x rc.o.m.
But this does not give ωIc.o.m., or does it?
You can't do that! :redface:
A x (B x C) is nothing like B x (A x C) :frown:
∫∫∫ (r - rP) x ρ ω x (r - rc.o.m.) dxdydz=
∫∫∫ r x ρ ω x (r - rc.o.m.) - ∫∫∫ rP x ρ ω x (r - rc.o.m.)=
∫∫∫ r x ρ ω x (r - rc.o.m.) - 0=
∫∫∫ r x ρ ω x r - ∫∫∫ r x ρ ω x rc.o.m.=
∫∫∫ r x ρ ω x r - (∫∫∫ r x ρ ω) x rc.o.m.
Please, Tiny-Tim, complete the explanation.
In my previous post I wrote the equations, but didn't get the required result: Ic[itex]\omega[/itex]
It's at the start of my post #8 …
you need to have an (r - rc.o.m.) on the extreme left for it to work (to get Ic.o.m.):wink: …
for some reason you decided not to do so! :confused:
But that's exactly my question!
At the extreme left on the first formula:
∫∫∫ (r - rP) x ρ ω x (r - rc.o.m.) dxdydz + ...
There is: (r - rP)
But then the extreme left member changes to: (r - rc.o.m.) in the next equation:
∫∫∫ (r - rc.o.m.) x ρ ω x (r - rc.o.m.) dxdydz + ...
And the rest of these two formulas is the same. how to make the transition of (r - rP) to (r - rc.o.m.)?
Because …
… (and rP is constant).
I now understand I shouldn't open the parentheses. I understand that From your second example with vP.
But in your first analysis I don't understand how you got the same member twice, as needed and as described in your second example.
That is, from:
There is: (r - rP)
But then the extreme left member changes to: (r - rc.o.m.) in:
And you write that
Where do you get this without opening parentheses?
I know the definition of C.M.. I ask how, in what way, you arrived to the partial expression:
From the formula:
But my main question is this:
You have changed the first member, (r - rP), in the formula:
To (r - rc.o.m.) In the formula:
By what right? what's the process you have made for that.
From there, I guess, I'll go on my own.
Thanks.
Because I subtracted ∫∫∫ (rP - rc.o.m.) x ρ ω x (r - rc.o.m.) dxdydz,
which is a constant "times" ∫∫∫ ρ (r - rc.o.m.) dxdydz, which = 0.
Thank you very much, Tiny-Tim. It's a relief.
I think you should add ∫∫∫ (rP - rc.o.m.) x ρ ω x (r - rc.o.m.) dxdydz, instead of subtracting, since then you get ∫∫∫ (r - rc.o.m.) x ρ ω x (r + rc.o.m.) dxdydz.
I try to calculate [itex]\alpha[/itex] around point P, as drawn.
I don't get the right answer, since I get a different [itex]\alpha[/itex] at points O and C, which is (round point O):
[tex]M_O=I_O\alpha\Rightarrow FR=(KmR^2+mR^2)\alpha<br /> \Rightarrow \alpha=\frac{F}{mR(K+1)}[/tex]
I take the derivative of LP = ICω + m PC x vc.o.m. and get MP = ICα + m PC x ac.o.m..
I find the friction force, with the help of [itex]\alpha[/itex]:
[tex]\Sigma F=ma \Rightarrow f=F\frac{K}{K+1}[/tex]
[tex]\Rightarrow\left(F\frac{R}{2}\cdot f \frac{R}{2}\right)\hat{z}=mR^2\left(K+\frac{1}{4}\right)\vec{\alpha}+\left(m\frac{R}{2}\cdot\frac{F}{m(K+1)}\right)\hat{z}[/tex]
[tex]\alpha=\frac{4FK}{mR(K+1)(4K+1)}[/tex]
Which is not the same as the previous I found.
  • Free-body diagram of a rolling wheel on a surface: center C with applied force F pointing left, point P above the center, contact point O at the bottom, and friction force f pointing right at the ground.
Hi Karol! :smile:
The dot should be a +, and the "+ 1/4" shouldn't be there.
Then your equation becomes
(2K+1)R/2(K+1) = (Rα/a)2KR/2(K+1) + R/2(K+1) :smile:
The "+ 1/4" should be there since point P is on the half of the radius.
And there is no F in your equation.
The (K + 1/4) is supposed to be part of IC not IP, so the "+ 1/4" shouldn't be there
(I canceled the Fs … ok?)
You cannot cancel the Fs, it doesn't appear in the α member:
[tex]\left(F\frac{R}{2}+f \frac{R}{2}\right)\hat{z}=KmR^2\vec{\alpha}+\left(\frac{R}{2}\cdot\frac{RF}{m(K+1)}\right)\hat{z}[/tex]
oh, that (Rα/a) shouldn't be there …
that should have been …
(2K+1)R/2(K+1) = 2KR/2(K+1) + R/2(K+1)
(using α = F/MR(K+1))
First, you can't use α = F/MR(K+1) since I have to find α.
Second, your last m PC x ac.o.m. member, R/2(K+1), is not correct.
It should be:
[tex]\left( \frac{R}{2}\cdot\frac{RF}{m(K+1)}\right)[/tex]
Which gives FR2/2M(K+1)
Yes, I can … you found α from calculations based on the centre of mass.
All I had to do was show that that was consistent.
Yes it is, it's exactly the same as yours, except for a factor of RF/M which I took out from the whole equation.
