[assembly] Writing a simple i/o program
twoski
I have to write a simple program in NASM to read in a character then output what kind of character it is.
There are some things about NASM that confuse me so i marked them.
Code:
segment .data
	BUFFLEN equ 1 ; length of buffer
	CtrlMsg db "Control Character", 10 ;what does this 10 do?
	SymbolMsg db "Symbol", 10
	NumberMsg db "Number", 10
	CapitalMsg db "Capital Letter", 10
	LowercaseMsg db "Lower Case Letter", 10
segment .bss
	input resb 1 ; characters are 1 byte
segment .text
	global _start
_start: ; main function
	mov eax, 3
    mov ebx, 1
	mov ecx, input
    mov edx, BUFFLEN
	int 0x80 ; interrupt and get user input
	cmp byte [ecx],20h ; go through the ascii table ranges
	jb IsControl
	cmp byte [ecx],30h
	jb IsSymbol
	cmp byte [ecx],3Ah
	jb IsNumber
	cmp byte [ecx],41h
	jb IsSymbol
	cmp byte [ecx],5Bh
	jb IsCapital
	cmp byte [ecx],61h
	jb IsSymbol
	cmp byte [ecx],7Bh
	jb IsLowercase
	cmp byte [ecx],7Fh
	je IsControl
	jmp IsSymbol ; for anything else, assume it's a symbol
IsLowercase:
	mov	edx, len	; how do you get the length of a string in nasm?
	mov	ecx, LowercaseMsg
	jmp Print
IsCapital:
	mov	edx, len
	mov	ecx, CapitalMsg
	jmp Print
IsSymbol:
	mov	edx, len
	mov	ecx, SymbolMsg
	jmp Print
IsNumber:
	mov	edx, len
	mov	ecx, NumberMsg
	jmp Print
IsControl:
	mov	edx, len
	mov	ecx, CtrlMsg
	jmp Print
Print:
	mov	ebx, 1		; writing to screen
	mov	eax, 4		; sysout command
exit:
	mov eax, 1 ; Select system call 1
	xor ebx, ebx ; Set default exit code
	int 0x80 ; Invoke selected system call
What type of operating system is this running on? The '10' on the strings is an ASCII line feed.
If you want to generate a symbol for the length of a string, you can use an equate, in MASM, where $ means the current location, this would be:
Code:
CtrlMsgLen equ    $ - offset CtrlMsg
Code:
I'm doing all my debugging etc on Linux.
Is the '10' needed at all or is it just there to make the output pretty?
Code:
	CtrlMsgLen equ $ - CtrlMsg
	SymbolMsgLen equ $ - SymbolMsg
	NumberMsgLen equ $ - NumberMsg
	CapitalMsgLen equ $ - CapitalMsg
	LowercaseMsgLen equ $ - LowercaseMsg
If you output multiple messages, they'll all end up connected as one message on the screen if you don't have the '10'. For Windows / Dos, you need a carriage return and a line feed (13, 10). Usually control characters are written using hex notation, so line feed would be 00ah.
