Assuming Lorentz transform is affine
26 replies · 3K views
Split from https://www.physicsforums.com/threads/question-about-relativity-of-simultaneity.847761/
Alonso has in fact raised a relevant issue. Given any clock synchronization in the embankment frame, there is a unique pair of points at the embankment with coordinates x=a and x=b, and a unique time t=T, such that at t=T in the embankment frame, these points are next to the back end and the front end of the train, respectively, and x=0 in the embankment frame is next to the midpoint of the train.
In this case, it is assumed that a=-b, that is, that the midpoint between the two points at t is next to the midpoint of the train. But in fact, this cannot be proved from the two postulates alone. We need also use that the Lorentz transformation is linear to prove this (more precisely, affine, if the origins (0,0) are not mapped to each other), and this linearity cannot be proved from the postulates alone. I think that sweet springs with "homogeneity" and FactChecker with "uniformity" mean the same thing.
To derive the linearity from more fundamental or intuitively obvious principles is a very tricky issue. See https://www.physicsforums.com/threa...formations-are-the-only-ones-possible.651640/
In the larger context of curved space-time, I don't know if it is even correct to talk about linearity. I would call the linearity a simplifying assumption, rather than something to be proven from basic principles. But that does not hurt the logic of relative simultaneity. The distances can be made arbitrarily small so that any non-linearity can be ignored.
You are undoubtedly correct, FactChecker, but here we are dealing with Special Relativty, in which there is no curvature. But even in this case, the linearity cannot be proved from the two postulates alone.
Yes, it can be proved from the postulates. Specifically, the postulates describe transformations between inertial frames. Inertial frames map straight lines to straight lines. Transformations which map straight lines to straight lines are affine.
The property you say is not proven is, in fact, contained in the word "inertial" in the postulates.
The logic of relative simultaneity holds in any case. The Lorentz contraction is first order and any non-linearity, if it exists, is second order. The effect of any non-linearity can be made arbitrarily small compared to the Lorentz contraction by considering small distances. At high speeds, the Lorentz contraction can be made large and the local effect of non-linearity can be made small.
1. We had a discussion in an old thread
whether transformations which map straight lines to straight lines must be affine. I accept that this is true, although it seems exceptionally hard to prove. Someone dug up a proof which was completely unintelligible. (Btw, it is false in one dimension.)
2. Inertial systems are usually characteritzed by the requirement that the laws of physics take the same form in all of them. How does this imply that transformations between inertial systems must map straight lines to straight lines?
The principle of inertia is that free objects travel in a straight line at constant speed. This is a straight line in spacetime.
Inertial transforms preserve which objects are inertial, and therefore map straight lines through spacetime in one frame to straight lines through spacetime in another frame.
DaleSpam and Ibix, your argument seems very convincing, but there is a possible loophole. We are talking about transformations which map all straight lines to straight lines (in 4d-spacetime). Therefore, your argument is only valid if all straight 4d-lines represent possible paths of a physical objects. If this is true, then physical objects can move with any speeds, including speeds greater than c (light speed), even infinite speed (a line in spacetime with constant time coordinate). But we cannot assume this, and it also turns out to be wrong.
So, your argument does only prove that lines representing possible motions of physical objects are mapped to other lines, and this might not (and does not) include all lines.
I think this is a non issue. We haven't discovered tachyons (and many believe that they do not exist) but there is no reason that you could not have inertial tachyons and no reason that an inertial transform should be restricted from mapping a tachyonic straight line to a straight line in another frame.
Is there anything wrong with this argument: a rod that is straight in some inertial frame lies along a straight spacelike line. If a straight spacelike line does not map to a straight line then the rod is curved in some other frame, and we need an explanation for that.
DaleSpam said:
You would have to make it an inertial rod, because otherwise it can indeed be curved in other frames.
So: a rod that is straight and moving inertially in an inertial frame lies along a straight spacelike line. If a straight spacelike line does not map to a straight spacelike line the rod becomes curved in another frame and we would need forces to appear to explain this.
Well, we could possibly say that since tacyons are supposed to not interact with other objects/fields, if the law of inertia applies to them, they must move with constant speeds in straight lines, if they exist at all, that is...
But I don't think that this interpretation is the only logically possible one.
The problem is that there is no really stringent definition of inertial system (at least no one I know of).
Perhaps one way would be to define the class of Inertial systems as a class of reference frames which is closed under the family of transformations which map lines to lines, and such that the laws of physics holds in one of them (recall that also Einstein in his 1905 article singled out one of them and called it "stationary").
But this is not fully stringent either, since it invokes "the laws of physics" and that is quite vague...
This is true, but not really a problem IMO. The two postulates are fairly "casual" statements, intended to convey the physical intuition behind the theory.
To do proofs you establish the rigorous mathematical structures that are most convenient and then informally identify them with things in the postulates. We have considerable freedom there, so we use it to make things easier later.
It doesn't have to be the only logical interpretation. We can pick for convenience whenever there is more than one logical possibility.
Preservation of the spacetime interval between any two events, infinitesimally $$dS^2=dS'^2$$, and uniformity of spacetime which means no special point cooridinate and no special direction appears results Lorentz transformation whose only parameter is magnitude of velocity divided by light speed. This is my interpretation from Landau textbook.
Erland said:
The problem is that there is no really stringent definition of inertial system (at least none I know of).
Heh, I arrive late to this conversation, but... what's wrong with simply specifying it via non-acceleration? Then the transformations we're interested in are those which map solutions of $$\frac{d^2x^i}{dt^2} = 0$$ among themselves. That leads one to fractional-linear transformations, and (many pages of) further analysis yields both a universal speed constant, and a universal length constant (related to the cosmo constant). But we've had this conversation before in that older thread you linked earlier. :oldbiggrin:
We normally assume in SR that spacetime has the structure of a vector space. We can construct a basis for this space that consists only of future-timelike vectors. Therefore preservation of the straight-line property for timelike lines implies the same thing for lightlike and spacelike lines.
The broader issue in this discussion is that issues like these can never be resolved using an axiomatic system that is formulated as informally as Einstein's 1905 axiomatization of SR. A nice treatment that takes some care with these fundamentals is Bertel Laurent, Introduction to spacetime: a first course on relativity.
Another thing to realize is that a transformation can have the property of preserving geodesics while not having the property of being a linear operator on the coordinates, or vice versa. For example, we can apply a Lorentz transformation in Rindler coordinates.
How does this follow?
Take a two-dimensional space for simplicity. When we say that an operator ##\Lambda## is linear when it acts on vectors ##e_1## and ##e_2##, we mean that for any real numbers ##u## and ##v##, ##\Lambda(ue_1+ve_2)=u\Lambda(e_1)+v\Lambda(e_2)##. If this holds for vectors ##e_1## and ##e_2## that are linearly independent, then you can easily check that it holds for the whole space.
Erland said:
Yeah, but the problem was to prove that the Lorentz transformation is linear.
No, I wasn't addressing the general problem. I was addressing a subproblem, which was the issue you raised in your #9. That's why I quoted your #9 in my #18. You objected that linearity on timelike lines didn't imply linearity on all lines. Linearity on timelike lines does imply linearity on all lines.
Excellent point! So simple and clear in retrospect that I cannot believe I didn't see that earlier.
You mean something like this: Given two linearly independent vectors: If all lines which are parallell to any of those are mapped to lines, then so does all lines parallell to any linear combination of these vectors? Ok, I think that is correct...
If a rod contracted before, a rod contracts now and will contract in future.
If a rod here contracts, a similar (be careful to the direction) rod there also contracts.
If 1 m rod contracts to 0.8 m rod, 10 m rod contracts to 8 m.
Such anytime, anywhere and same proportion conditions seem reasonable.
Ok, so reading this old thread
and using bcrowells idea (as I understand it), I can now prove the following:
Assume that ##L:\Bbb R^4 \to \Bbb R^4## is a mapping such that:
a) ##L## is a bijection,
b) there is an ##m>0## such that all straight lines in ##\Bbb R^4## with direction vectors ##(v_1,v_2,v_3,u)## such that ##u>0## and ##v_1^2+v_2^2+v_3^2<m^2u^2##, are mapped by ##L## onto straight lines in ##\Bbb R^4##,
c) if ##p##, ##q##, and ##r## are points in ##\Bbb R^4##, such that ##q## lies on the line segment with endpoints ##p## and ##r## and between those, then the same relation holds between ##L(p)##, ##L(q)##, and ##L(r)##.
Then, ##L## is an affine transformation, that is, there exists a linear transformation ##A: \Bbb R^4\to \Bbb R^4## and a ##b\in \Bbb R^4##, such that ##L(x)=Ax+b##, for all ##x\in \Bbb R^4##.
Some comments:
a) Since this is supposed to apply to the Lorentz transformation, it seems impossible to have two inertial frames such that some events in one of them correspond to several events or no events in the other one, and still maintain that the laws of physics holds in both of the frames. So, it seems unavoidable that ##L## is a bijection.
b) The physical interpretation is that world lines of objects moving with sufficiently small constant velocities are mapped onto world lines of objects moving with constant velocities. This means that if no forces are acting upon an object, it moves with constant velocity in both frames (although it is an idealized situation, the motion continuing eternally, in both time directions). The speed limit ##m## rules out "tachyonic" motion, but the limit ##m## needs not be ##c## but can be much smaller, the proof will work anyways. The idea is bcrowells, I think. And this certainly holds for small velocities (in less idealized situations). The general proof idea must be attributed to Fredrik, micromass, and/or strangerep, I think, in the old thread I linked above.
c) This is actually equivalent to the continuity of ##L##, and it seems physically obvious. I am not able to prove this without an assuption equivalent to this one. There was no real proof of the continuity in the old thread linked above.
I plan to give the proof here, but it will take some time...
It turns out that c) is not necessary. It can be derived from a) and b), which I should have understood by reading the previously linked thread more carefully...
