Automorphisms of the complex numbers Aut(ℂ)
  • Topic:
  • Thread starter Math Amateur
    Groups
8 replies · 3K views · last reply
Math Amateur
MHB
I am reading Anderson and Feil - A First Course in Abstract Algebra.
I am currently focused on Ch. 24: Abstract Groups ... ...
I need some help in understanding some claims in Chapter 24 by Anderson and Feil ... ...Anderson and Feil claim that $$\text{Aut} ( \mathbb{C} ) $$is a group with only two elements $$\{i, f \}$$ ... ... where $$i$$ is the identity automorphism and $$f$$ is the complex conjugation map defined by $$f(a + bi) = a - bi$$ ... ...
... can someone please help me to prove the assertion that $$\text{Aut} ( \mathbb{C} ) $$is a group with only two elements $$\{i, f \}$$ ...
Peter
Hi Peter,
Could you check back Anderson and Feil to see if they meant the automorphisms of $\Bbb C$ fixing $\Bbb R$?
Euge said:
Hi Peter,
I am beginning to understand that whether the automorphisms of $\Bbb C$ fix $\Bbb R$ may be an issue ... but from my reading of Anderson and Feil they seem to imply that the the automorphisms of $\Bbb C$ actually fix $$\mathbb{R}$$ anyway ... but you seem to be implying that this is not necessarily the case ...
The relevant text from Anderson and Feil is as follows:First the example that started me thinking:
https://www.physicsforums.com/attachments/6855
Now the above example involves a Galois Group ... and in this group $$\mathbb{R}$$ is certainly fixed under Anderson and Feil's definition of a Galois Group ... which reads as follows:
https://www.physicsforums.com/attachments/6856
https://www.physicsforums.com/attachments/6857
Now, Example 47.3 refers to Exercise 24.14 which asserts that $$\text{Aut} ( \mathbb{C} )$$ has only two elements ... note the exercise does not mandate the fixing of $$\mathbb{R}$$ ... Exercise 24.14 reads as follows:View attachment 6858Hope that clarifies what Anderson and Feil have to say about the issue ... ...
Peter
If Anderson and Feil reject the axiom of choice, then it would make sense for them to say $\operatorname{Aut}(\Bbb C)$ has two elements. However, if they do accept the axiom of choice, their statement about $\operatorname{Aut}(\Bbb C)$ would be incorrect, for in that case, $\operatorname{Aut}(\Bbb C)$ would be uncountably infinite.
Thanks Euge ...
Well ... I am surprised by that ... can you please explain how the Axiom of Choice makes such a difference in this matter ...
... it is not obvious to me how the Axiom of Choice makes such a difference ...
Peter
With the axiom of choice, one can use the concept of a transcendence base to construct field automorphisms of $\Bbb C$ different from the identity and complex conjugation. More generally, it can be shown that the cardinal number of the field automorphisms of an algebraically closed field $\Bbb k$ is $2^{\text{card}(\Bbb k)}$. Since $\Bbb C$ has cardinal number $2^{\aleph_0}$, then with axiom of choice, the cardinal number of $\operatorname{Aut}(\Bbb C)$ is $2^{2^{\aleph_0}}$.
A natural question arises: how much choice is required for $\text{card}(\operatorname{Aut}(\Bbb C)) > 2$? I'm pretty certain you don't need the full AC for it to hold, but I don't know what the weakest choice assumption needs to be. Perhaps a logic expert like Evgeny.Makarov knows.
Thanks Euge ...
Still reflecting on this post ... need to read and think around this matter ...
Peter
I would advise you not to think too deeply about this, for these issues are difficult to deal with, even for professional mathematicians. Just ignore the exercise as it is a faulty one.
Thanks for the advice/warning Euge ...
I will now leave this matter and move on to more Galois theory ...
Thanks for your help on this issue/problem ...
Peter
