Azimuthally Symmetric Potential for a Spherical Conductor
The discussion focuses on solving problem 2-13 from "Principles of Electrodynamics," specifically determining the azimuthally symmetric potential for a spherical conductor. The potential is expressed as a series involving Legendre polynomials, with boundary conditions applied for regions inside and outside the conductor. The user initially struggles with evaluating integrals for even values of n but later discovers that only the n=0 and n=2 terms are necessary to solve the problem effectively, simplifying the solution process.
  • Understanding of azimuthally symmetric potentials in electrostatics
  • Familiarity with Legendre polynomials and their properties
  • Knowledge of boundary conditions in electrostatic problems
  • Ability to perform integral calculus involving polynomial functions
  • Study the properties of Legendre polynomials in detail
  • Learn techniques for evaluating integrals of polynomial functions
  • Explore boundary value problems in electrostatics
  • Review series solutions for potential functions in spherical coordinates
This discussion is beneficial for physics students, particularly those studying electrodynamics, as well as educators and researchers focusing on electrostatic potentials and boundary value problems.
Loonuh
[/B]
I am trying to solve problem 2-13 from my textbook "Principles of Electrodynamics" (see image below).
I believe that I should be solving the potential as
<br /> \varphi(r,\theta) = \sum_{n=0}^\infty (A_n r^n + \frac{B_n}{r^{n+1}})P_n(\cos\theta),<br />
where A_n and B_n are determined by the boundary condition of the conductor. For r &lt; R we should have that B_n = 0 to make sure the potential is finite and for r &gt; R we should have that A_n = 0 to ensure that the potential goes to 0 at infinity. That being said, at r=R, we can apply the boundary conditions such that we
A_n^{in} = \frac{2n+1}{2a^n}\int_{-1}^{1}\varphi(R,\theta)P_n(\cos\theta)d\cos\theta
and
B_n^{out} = \frac{2n+1}{2}a^{n+1}\int_{-1}^{1}\varphi(R,\theta)P_n(\cos\theta)d\cos\theta.
Now, my problem comes when I want to solve these two integrals because it appears to me that if I apply the boundary condition, namely that
<br /> \varphi = 0 \;\;\;\; \frac{3}{2} &lt; \cos\theta &lt; 1\\<br /> \varphi = \varphi_0 \;\;\;\; \frac{-\sqrt{3}}{2} &lt; \cos\theta &lt; \frac{\sqrt{3}}{2}\\<br /> \varphi = 0 \;\;\;\; -1 &lt; \cos\theta &lt; -\frac{3}{2}<br />
then the above two integrals reduce to
A_n^{in} = \frac{2n+1}{2a^n}\int_{-\frac{\sqrt{3}}{2}}^{\frac{\sqrt{3}}{2}}\varphi_0P_n(\cos\theta)d\cos\theta
and
B_n^{out} = \frac{2n+1}{2}a^{n+1}\int_{-\frac{\sqrt{3}}{2}}^{\frac{\sqrt{3}}{2}}\varphi_0P_n(\cos\theta)d\cos\theta
respectively.
Now, since P_n are odd functions for odd n, A_n^{in} and B_n^{out} appear to be 0 for all of the odd values of n. However, the problem arises now when I am trying to evaluate these integrals in general for even values of n, in this case the results seem intractable because I am trying to integrate the Legendre Polynomials over a symmetric interval where the limits are not -1 and 1.
From my understanding, this problem should be as straightforward as applying the boundary conditions as I have done to solve for the potential, is there something that I am overlooking?
Note that cos(60o) ≠ √3/2.
You say the integrals appear to be intractable. Did you write out the integrands explicitly for n = 0 and n = 2?
Whoops, limits should be +-1/2. I meant that
the general solutions to the integrals seem intractable, but I turns out that you only need
the 0 and 2 terms to answer all of the parts of the problem, so then this is actually very easy.
OK. Good!
  • · Replies 16 ·
  • · Replies 19 ·
