B-spline with 5 control points and degree 2
  • Thread starter basty
14 replies · 2K views · last reply
basty
Moved from a technical math section
Hi all,
The control points are five and they are:
b0 = (0,0)
b1 = (1,3)
b2 = (3,0)
b3 = (4,3)
b4 = (6,0)
The degree d is 2.
The number of knots t are 8 and they are:
t0 = 0
t1 = 1
t2 = 2
t3 = 3
t4 = 4
t5 = 5
t6 = 6
t7 = 7
What is the next step to solve this b-spline?
Thank you
It's not clear what you mean when you say, "What is the next step to solve this b-spline?"
You should see the theory to understand what I'm asking about:
Page of printed mathematical text with numbered definitions and examples on B-spline basis functions, including Definition 2.1 and Example 2.1 with a figure of B-spline basis functions and their derivative graphs.
Looks to me like that's a lot of algebra to crank thru.
Step 1: define your ##N_{i,0}## basis functions.
Step 2: define your ##N_{i,1}## basis functions in terms of your ##N_{i,0}## basis functions.
Step 3: define your ##N_{i,2}## basis functions in terms of your ##N_{i,1}## basis functions.
Step 4: sum them up to make your ##\mathbf{B}## spline.
If you are comfortable with linear algebra, this looks like something a computer would do a lot faster.
What I suppose to do with the below equation (the example 8.3)?
##N_{0,1}(t) = \frac{t-t_{0}}{t_{1}-t_{0}}N_{0,0}(t)+\frac{t_{2}-t}{t_{2}-t_{1}}N_{1,0}(t)##
##= \frac{t-2}{4-2}N_{0,0}(t)+\frac{5-t}{5-4}N_{1,0}(t)##
##= \frac{t-2}{2}N_{0,0}(t)+\frac{5-t}{1}N_{1,0}(t)##
##= \frac{t-2}{2}N_{0,0}(t)+(5-t)N_{1,0}(t)##
I can't multiply them because of the ##N_{0,0}(t)## and ##N_{1,0}(t)##.
What is the value of the ##N_{0,0}(t)## and ##N_{1,0}(t)##?
For example, if the value of the ##N_{0,0}(t)## and ##N_{1,0}(t)## is 3 and 4 respectively, then the equation will be:
##\frac{t-2}{2}N_{0,0}(t)+(5-t)N_{1,0}(t)##
##= (\frac{t-2}{2})3+(5-t)4##
##= \frac{3t-6}{2}+(20-4t)##
btw, honestly, this is not a homework.
First, define all your ##N_{i,0}## functions. Notice that these are only non-zero over the single unit ##[t_i,t_{i+1}]## and on that unit they are 1.
Then, define your ##N_{i,1}## functions.
For example, ##N_{0,1} =\frac{t-0}{1-0}N_{0,0}+\frac{2-t}{2-1}N_{1,0}=t \text{ on }[0,1), = 2-t \text{ on }[1,2)##.
Notice that these are continuous linear functions interpolating your points.
Also, ##N_{1,1} =\frac{t-1}{2-1}N_{1,0}+\frac{3-t}{3-2}N_{2,0}=t-1 \text{ on }[1,2), = 3-t \text{ on }[2,3)##.
Moving on the the ##N_{i,2} ## quadratic basis functions, you have:
##N_{0,2} =\frac{t-0}{2-0}N_{0,1}+\frac{3-t}{3-1}N_{1,1}=\frac{t^2}{2} \text{ on }[0,1), = \frac{2t-t^2}{2}+\frac{(3-t)^2}{2} \text{ on }[1,2)##.
If you are doing this with a computer, it should be much faster than doing it by hand.
Just pay attention to where the functions are non-zero and sum the pieces appropriately.
Why ##\frac{1}{6}(7-t)^2(1,2)+\frac{1}{3}(-t^2+12t-34)(3,5)+\frac{1}{6}(t-5)^2(6,2)## on ##5≤t<7##?
Why not
##5<t≤7##
or
##5≤t≤7##
or
##2≤t≤4##
or
##?≤t≤?##
and so on?
Piecewise formula B(t) equals a sum of control points (1,2), (3,5), (6,2), (9,4) weighted by N terms, followed by two-case piecewise expression: one for 5 ≤ t < 7 and one for 7 ≤ t ≤ 8, labeled equation (8.3).
All the functions should be equal at the nodes, so it is just a matter of only defining each point once. Though for implementation it doesn't impact the method.
I am sorry but I still do not understand. Please use a basic english which is easy to understand as english is not my native language.
Why chose 5 <= t < 7 and 7 <= t < 8 (see the image below) for the final step?
RUber said:
It does not matter.
What is does not matter?
RUber said:
Both should be equal at t=7.
Why?
Does not matter means the result will be te same either way.
A spline is designed to be a continuous function. If they were different at t=7, it would not be continuous.
In any case, if you find it easier to define the point by the right function rather than the left, there should be no problems.
Reading definition 8.2 in the material posted above, it says that the final answer will be defined from ##t_d## to ##t_{n-d}##.
Since in this example (8.3), d=2, your interval for the spline will be from ##t_2## to ##t_{6-2}##, which covers the points 5, 7, and 8.
Was this the heart of your misunderstanding?
