Ball tossed from window at 15° below horizontal
6 replies · 2K views · last reply
physics_geek
A ball is tossed from an upper-story window of a building. The ball is given an initial velocity of 8.20 m/s at an angle of 15.0° below the horizontal. It strikes the ground 3.00 s later.
(a) How far horizontally from the base of the building does the ball strike the ground?
4.90wrong check mark m
(b) Find the height from which the ball was thrown.
wrong check mark m
(c) How long does it take the ball to reach a point 10.0 m below the level of launching?
i think the equations are r= v^2(sin2theta)/g
h= v^2(sintheta)2/2g
i tried pluggin in the values to get how far it traveled and the height..but I am getting it wrong
any help would be appreciated
Work out the velocity component downward.
Then it's just the normal moving object equations except the initial velocity isn't zero.
im not sure wat you mean by that
make the velocity -8.2?
im so confused
You need to resolve the velocity vector into horizontal and vertical components. Then, what mgb is saying, is you consider the vertical component.
o ok into two different components
so they give me 8.2 m/s
thats my resultant vector rite?
so i just do 8.2(cos15) ??
Draw a diagram (triangle) - it should be obvious how much of the diagonal speed goes horizontally and how much vertically.
