Basic Complex Analysis: Maximum Modulus?
5 replies · 2K views · last reply
snipez90
Let f and g be two holomorphic functions in the unit disc D1 = {z : |z| < 1}, continuous in D1, which do not vanish for any value of z in the closure of D1. Assume that |f(z)| = |g(z)| for every z in the boundary of D1 and moreover f(1) = g(1). Prove that f and g are the same function.
Maximum modulus?
Last one for now.
Okay I had enough sense to gather from the hint that f and g don't vanish that I should define h = f/g. Then h(1) = 1, |h(z)| = 1 for z on the boundary of D1. Now I feel like maximum modulus will give that h(z) = 1 on D1, but I'm making a logical leap. Can someone help me out here? Thanks.
Since |h(z)|=1 on the boundary, what does that tell you about |h(z)| in the interior? Since |h(z)| then achieves its maximum in the interior, what does that tell you about h(z)? Now use h(1)=1.
By maximum modulus, [itex]|h(z)| \leq 1[/itex] in the interior. But why does |h(z)| achieve a maximum in the interior?
There's an analogous minimum modulus theorem as well isn't there? Since h(z) doesn't vanish, replace h(z) with 1/h(z).
Gotcha, I considered 1/|h| and things came together, but yes that does give you minimum modulus I guess. Thanks.
If you don't mind could you take a look at
https://www.physicsforums.com/showthread.php?t=484067
to spot check the proof? The method I chose seemed like the easiest way to estimate the derivatives.
Also that Frobenius eigenvalue problem that I showed you awhile back had a deeper solution than the method we agreed on (which was like raising the linear operator to the 7th power). I think I also made a miscalculation but I might post again if I get around to thinking about it again. Of course nothing of the sort actually showed up on the final.
I don't remember any Frobenius eigenvalue thing. Can you remind me?
