Basic Mathematical Induction w/ n In the Exponent
The discussion focuses on the application of mathematical induction to prove the formula for the sum of a geometric series involving powers of 4. The user successfully verifies the base case for n=1 and establishes the inductive step for n=k. The confusion arises during the manipulation of the expression for n=k+1, specifically in combining terms with a common denominator. The correct approach involves recognizing that adding one instance of 4^(k+1) to three instances results in four instances, leading to the conclusion that the expression simplifies correctly.
  • Understanding of mathematical induction principles
  • Familiarity with geometric series and their summation formulas
  • Basic algebraic manipulation skills, including working with fractions
  • Knowledge of exponential functions and their properties
  • Study the principles of mathematical induction in detail
  • Learn about geometric series and their summation techniques
  • Practice algebraic manipulation involving fractions and exponents
  • Explore examples of mathematical induction proofs for different series
Students studying mathematics, particularly those learning about mathematical induction, algebra, and geometric series. This discussion is beneficial for anyone seeking to strengthen their understanding of these concepts.
DDNow
All I am trying to do is the basic mathematical induction routine: n=1, n=k, n=k+1 and how n=k proves n=k+1. The problem I am having is with the algebra.
4+16+64+...+4^{n}=\frac{4}{3}(4^{n}-1)
2. Homework Equations and Attempts
For n=1
4=4 That's OK
For n=k
4+16+64+...+4^{k}=\frac{4}{3}(4^{k}-1)
For n=k+1 by Substitution
4+16+64+...+4^{(k+1)}=\frac{4}{3}(4^{(k+1)})
To Prove by Adding K+1 to S_{k}
4+16+64+...+4^{k}+4^{(k+1)}=\frac{4}{3}(4^{k}-1)+4^{(k+1)}
It took me a minute to figure out how \frac{4}{3}(4^{k}-1) became \frac{4^{(k+1)}}{3}, but I got that part.
= \frac{4^{(k+1)}}{3}+4^{(k+1)}-\frac{4}{3}
This is where I am stuck. I gather that I am supposed to multiply 4^{(k+1)} by \frac{3}{3}, and then combine like terms. I am confused about this because I don't know how to multiply the term by 3 (I probably learned it, I'm just stumped).
Please help me understand what to do next. As long as I can understand how to manipulate the exponential terms with the fractions, I can complete this. Thanks for your time.
Check this expression.
Once you have the correct target expression, the next part should work out.
ummm...when you multiply 4^{k+1} by \frac{3}{3} you just get \frac{3(4^{k+1})}{3}...and since you now have two terms with the same denominator, you can add the numerators to get: \frac{4^{(k+1)}+3(4^{(k+1)})}{3}-\frac{4}{3}
what do you get when you add one of 'something' to 3 of 'something'?
I'm not sure how that is incorrect.
I get it now. When I look at it like 1[4^(K+1)]+3[4^(K+1)], it makes sense. I was trying to multiply, which was wrong, and didn't let me pull out 4/3.
Thanks, everyone.
When you substitute n=k+1,
right hand side of the expression should be 4/3(4^{k+1} -1)
