Bat Force and Human Lifting Capacity in Softball Pitching
21 replies · 3K views
Mowgli
A 0.165kg softball is pitched to you at 20.0m/s. You hit the ball back along the same path, and at the same speed. If the bat was in contact with the ball for 9.90x10^-3 seconds,
a.) what was the average force the bat exerted on the ball?
b.) Could this force lift a 70.0kg person?
I believe the equation to use is
mass/change in time x (final velocity + initial velocity)
a.)
(.165kg (20 + 20 m/s)) / 9.90 x 10^-3
= .165(40) / .0099
= 666.7 N
= 6.70 x 10^3 N
b.)
How do I factor in a 70kg person? Do I use 70(40)/.0099 ?
Look at your equation again. Force is equal to the change in momentum over time. Change in momentum = final - initial.
you're hitting the ball back, so the final momentum should be negative.
Can someone confirm this?
That equation should be: mass/change in time x (final velocity - initial velocity)
But as mizzy says, the sign of the velocity changes since you're hitting the ball in the opposite direction. So 20 - (-20) = 20 + 20.
(All we care about is the magnitude of the change, so it doesn't matter which direction we call negative.)
a.)
= .165(40) / .0099
= 666.7 N
= 6.70 x 10^3 N
That's fine, except for the last step. (You have the wrong exponent.)
Oooh, okay. Yes I noticed it should be ^2
Thank you.
To figure out b.)?? Can this be used to lift a 70kg person? Anyone?
If the initial momentum was positive, then the final would be negative. (But all we really care about is the magnitude of the change.)
Make sure you understand the point that mizzy was making.
What force is required to lift a 70 kg person?
F= 70kg x 9.90x10^-3
= 70x.0099
= .693 N
.693 < 666.7 so less force is required to lift the person?
or by speed? I'm not sure what to use.
70.0kg x 20.0 m/s
= 1400
= 1.4 X 10^3
I'm not too sure. But in your previous answer, mass x time doesn't give you F. Force is in Newtons (kgm/s^2)
The answer to my question--What force is required to lift a 70 kg person?--has nothing to do with momentum, speed, or time.
How much does the person weigh?
Mowgli said:
the person weighs 70kg
That's his mass, not his weight. How do you calculate the weight?
Mowgli said:
into lbs? multiply by 2.20
so 154 lbs
Better calculate the weight in Newtons so you can compare it to the force you calculated in part a.
oooh! so 154lb x 4.448N
= 684.9N
= 6.80x10^2
and
6.70x10^2 < 6.80x10^2
therefore more force would be needed to life the 70kg person
= 684.9N
= 6.80x10^2
and
That's the idea.
But the easy way to calculate the weight is by using W = mg, where g = 9.8 m/s^2.
weight = mass x acceleration of gravity
