Can BEC experiments shed light on the mysteries of quantum gravity?
Bose-Einstein Condensates (BEC) are being explored for their potential to provide insights into quantum gravity, particularly through the study of vortices within these systems. Discussions reference key research papers, including arXiv:1002.2962 and arXiv:0911.1020, which investigate the implications of BEC in modeling gravitational phenomena. Participants raise critical questions regarding the limitations of current theories, such as the impact of infrared cutoffs and the constraints on Fourier components affecting energy shifts in BEC traps. The quantum Zeno effect, as discussed in a thesis from Ketterle's group, is also highlighted as a potential avenue for testing string theories and quantum gravity.
  • Understanding of Bose-Einstein Condensates (BEC)
  • Familiarity with quantum gravity theories
  • Knowledge of the quantum Zeno effect
  • Ability to interpret research papers in theoretical physics
  • Research the implications of infrared and ultraviolet cutoffs in quantum field theory
  • Explore the role of vortices in BEC and their analogs in gravitational studies
  • Study the quantum Zeno effect and its applications in quantum mechanics
  • Review the latest findings in quantum gravity from arXiv and other academic sources
Physicists, researchers in quantum mechanics, and students interested in the intersection of condensed matter physics and gravitational theories will benefit from this discussion.
lark
Might BEC give insight into how quantum gravity works? comment?
Laura
Is this what you are thinking about?:
Wikipedia said:
Vortices in Bose–Einstein condensates are also currently the subject of analogue gravity research, studying the possibility of modeling black holes and their related phenomena in such environments in the lab.
I wouldn't expect any fundamental insight on quantum gravity from bose-einstein condensates.
Torquil
Thanks for the references; it sure is interesting! After a quick look at the BEC article, there are a couple of points I would like to raise:
Ref: http://arxiv.org/abs/1002.2962
1) There doesn't seem to be any infrared cutoff on the effect contributing to the energy shift for the compact BEC trap. Shouldn't low frequency fluctuations of the gravitational field give no contribution since they simply "move the whole experiment around"?
2) In eq.6, shouldn't there be an upper limit for the value of 'r'? Or stated differently, surely the contributions in the <hh> factor here should contain only Fourier components with wavelengths larger than the value 'r'? This should be a much more restrictive ultraviolet cutoff than the Compton wavelength cutoff used to get eq.7. Thus the prefactor <hh> should decrease as one considers larger values of 'r', and the increase in observable effect should not be as apparent when increasing the size of the BEC examples at the end of the article.
I'll appreciate any clarification here.
Torquil
Also there was a thesis by somebody in Ketterle's group http://cua.mit.edu/ketterle_group/Theses/Streed%20thesis.pdf
about BEC and quantum Zeno experiments - the "quantum zeno effect" is the suppression of transitions between quantum states by frequent measurements. He says measurements of this effect can limit string theories or quantum gravity.
I can't answer your questions, I'm a total novice on this subject. I just saw a video by Ketterle on BEC's and I wondered about testing quantum gravity with them. I really wished I could have been there to ask, especially since nobody had a question after the talk!
Laura
  • · Replies 18 ·
