Mentor
- 37,524
- 14,407
- TL;DR
- Could a hierarchical structure of protons, muons and positrons be stable without the weak interaction?
Summary: Could a hierarchical structure of protons, muons and positrons be stable without the weak interaction?
This discussion started here, I quote the relevant previous comments and then reply:
@Vanadium 50:
(mu- e+) is muonium, not true muonium - it is hydrogen-like where the muon replaces the (anti)proton, it has nearly the same binding energy as regular hydrogen, 13.6 eV. The binding energy decreases a tiny bit as the reduced mass decreases, but that is a ~0.5% effect.
I don't understand your scaling argument. If we shrink all wave functions by a factor 200 then all energies increase by a factor 200, this includes the difference between the potential energy the outer lepton has from proton and inner lepton.
mfb said:A positron could be in a stable orbital around a proton+2muon combination which itself would be stable similar to a hydrogen anion. But then the muons decay...
Vanadium 50 said:You're correct that this doesn't last any longer than the muons do, but I don't think this configuration is even stable. It is energetically favorable for it to rearrange to a muonic hydrogen atom and a (anti-)muonium atom. The H- ion is barely bound and both the muonic hydrogen atom and muonium atoms are deeply bound.
mfb said:The binding energy of another electron is 0.75 eV, for the muon it should be 200 times that, or 150 eV, unless I miss some nonlinearity. The binding energy of muonium is just ~14 eV, similar to regular hydrogen. In addition you would miss most of the ~13.6 eV the positron has in the initial state.
Vanadium 50 said:We're getting off the track, but...
There is definitely a non-linearity (you can see it in the Hamiltonian), but you can see how the H- is bound semil-classically: one electron is near the proton forming an Hydrogen-atom like state, and the other is far away. The wavefunction is such that the expectation value of the distance between the far electron and the proton is slightly less than the expectation value of the distance between the far electron and the near electron, so you have a net attraction. (Pauli blocking is also important here, but I'll ignore it.) If I replace the electrons with negative muons, the first muon gets bound 200x deeper, but also has a wavefunction 200x closer (on average) so the second muon is bound ~200x deeper because of the mass, but only ~1/200 as deeply because muonic hydrogen is smaller. So I would expect binding of the outer muon to be of order eV (if it's bound at all).
But this is a detail. Even if you just scale everything up by 200, you can see the energetic instability. If you have (p mu- mu-) e+, the 1st muon is bound by 2.8 keV, the second by ~150 eV and the positron by 13.6 eV. If you rearrange to (p mu-) (mu- e+), the (p mu-) is bound by 2.8 keV, the (mu- e+) by half that, 1.4 keV, and if the two neutral "atoms" are bound at all, it will be of order eV. So the rearrangement is energetically favored by more than a kilovolt. Again, it's clearest semi-classically: the outer muon feels a much stronger attraction to the positron than it does to the neutral muonic hydrogen, so that's where it goes.
@Vanadium 50:
