How Does Binding Energy Relate to Nucleon Distance in Atomic Nuclei?
  • Context: Undergrad
  • Thread starter Thread starter artis
    Binding energy Energy
The discussion focuses on the relationship between binding energy and nucleon distance within atomic nuclei, emphasizing that the mass of bound nucleons is less than the sum of their individual masses due to binding energy. Participants clarify that while the strong force diminishes with increasing nucleon separation, it does not behave like the electric field of charged particles. The mass defect, which is the difference in mass due to binding energy, remains constant regardless of nucleon distance until they are sufficiently separated, at which point they approach their individual masses. The conversation also touches on the implications of mass-energy conversion during nuclear reactions such as fusion.
  • Understanding of binding energy and mass defect in nuclear physics
  • Familiarity with the strong force and its role in atomic nuclei
  • Basic knowledge of quantum mechanics and particle interactions
  • Concept of mass-energy equivalence as described by Einstein's theory
  • Study Quantum Chromodynamics (QCD) to understand the strong force in detail
  • Explore the concept of mass-energy conversion in nuclear reactions
  • Learn about the implications of nucleon separation on nuclear stability
  • Investigate the differences between strong and electromagnetic forces in particle physics
Students and professionals in nuclear physics, particle physicists, and anyone interested in the fundamental forces and interactions within atomic nuclei.
artis
I always read that the weight of the protons and neutrons forming a nucleus is less than the weight of them if counted as standalone particles, the difference being the "mass defect" which goes into the binding energy to hold the nucleus together.
So I have two questions.
1) The elementary particle for the strong interaction being the gluon is responsible for the strong force, the strong force is coming from each nucleon within a nucleus, so if I say separate these nucleons far apart, do they still "exert" the same amount of strong force? Analogous to how a charged particle has the same strength E field around it whether being alone or close to other particles?
2) Now if there is a "mass defect" between individual protons and neutrons and the same amount of protons and neutrons in a nucleus then how does this mass defect change with distance, in other words at which point or how far do the nucleons need to be separated in order for them to change their mass as the result of less binding energy, how does this weight vs binding energy scale with distance? Does it happen gradually or is there a sharp boundary in terms of distance after which each nucleon "gets back" it's full weight?3) if composite particles like protons and neutrons have the strong force always "with them" then are the gluons always emitted from them and if so do they compare to virtual photons of a static charge in the EM field or actual photons of a changing EM field? Can a particle like a proton lose energy by this strong force field if being standalone?
Have you read the Wikipedia page on the strong interaction? It seems to answer a lot of your questions on nuclear forces.
On question 2: the mass of individual particles does not change, but when particles are bound together the mass of the bound system is less that the sum of the particles. The mass defect is the binding energy and not a mysterious physical change in the particle themselves.
If you separate the nucleons the force between them decreases. This is analogous to the electric interaction where the force decreases with increasing distance, too. For the strong force the scaling with distance is different, however, the force drops faster.
hmm , thanks @PeroK it wasn't that obvious to me before that as you say
Usually this is stated the other way around that "mass of nucleus is less than that of individual nucleons counted together". But I like the way you said better.
ps. yes I have read the wiki article.
Now as also @mfb said that separating the nucleons apart decreases the strength of the field much like with electric charge.
But electric charge always has the same strength irrespective of the distance between any such two charges, the strengh of the charge itself if measured a fixed distance from the say charged particle would be the same only the total E field strength would increase if many such charges were brought together, does the same rule apply to the strong force and measuring it a fixed distance from a proton for example, where the strong force is always the same a fixed distance from a proton or a neutron just that once together the total field strength increases because of the increase in particle count?
You seem slightly confused about the concept of electrostatic potential. Let's look at three examples:
1) A proton (positive charge) and an electron (negative charge). These attract each other and in QM they form a bound system (called a hydrogen atom), releasing energy in the form of a photon as they do. The mass of the hydrogen atom is the mass of a proton + mass of the electron - the released binding energy.
This forms a stable system because you need to input at least the binding energy to separate the two particles (this is called ionisation).
2) Two protons repel each other. They cannot form a bound system electrostatically. If you did hold them together, then they would separate naturally as soon as you release them.
3) Protons and neutrons are also subject to the strong force, which is attractive. A nucleus generally needs neutrons to help hold it together and counteract the electrostatic repulsion between the protons. The strong force is short range. As the nucleus grows, each proton is effectively repelled by all the other protons, but only attracted (strongly) by the nearest neutrons and protons. Eventually, if it gets too big, the nucleus becomes unstable as the short range strong force cannot overcome the long range electrostatic repulsion of all the protons.
@PeroK I think you misunderstood my misunderstanding,
I do get that two like charges repel, maybe I should have pointed in my example that if they would be kept together somehow they would form a total E field which would be greater in magnitude than if there was just a single charge. An example I guess would be an electron potential well , where if the electrons are more and closer together they have a stronger field if measured some distance away from the well, than if they were less and further apart.
If this is correct which I think it is, then does the strong force act in a similar fashion where if not accounted for the electrostatic repulsion between protons, eventually more protons/neutrons together would have a stronger strong force field if measured a certain distance from the nucleus, than if there were fewer such particles?ps. in your examples , in example 1 when you say mass of proton + mass of electron - the binding energy I assume you are referring to the electrostatic binding energy, because as far as I know the electron has no strong force as it is an elementary particle, so the proton's strong force has nothing to bind to?
@artis what don't you understand about the concept of a force working over a shorter range? The rest is largely irrelevant.
As you were replying I was still writing see my last paragraph please.
Well I do understand that it works in a shorter range, I was just asking whether the total field adds up much like the electrostatic one if the number of particles is increased. I guess it does
I don't believe that the strong force admits a classical field theory - unlike the quantum electrostatic interaction. You can't talk about adding strong fields in that sense. Any calculations would have to be done on the basis of QCD.
ok,so far we have come to the conclusion that the strong force if measured as a total a distance away from certain number of particles doesn't add up like the electrostatic field would if measured a certain distance away from given number of charged particles.
@PeroK you said in post #3
So when the particles are in the bound system then each individual particle must weigh less because otherwise how come the total system weigh less ?
Or is it that each particle weighs the same also in the bound system just that the system together weighs less than it should if simply counted by the individual particle masses making up the system ?
If this is so then it seems like the individual particle masses within a bound system are in a sort of superposition if you will, where they weigh X if measured alone but X-Y if measured as part of the system?
The total mass of the system is not the sum of masses of the individual particles in it.
No.
@artis the concept of mass is more complicated than simply adding particle masses. Binding energy is not a particle mass but it is relevant to the mass of a system.
Ok I think I get the concept, the individual particle masses don't change, then when the particles make up a bound system the particles should not be considered anymore mass wise but now the whole atom should be looked at like one big "particle" having an emergent property which is that it's mass is not the same as that of is constituents.
And that I guess is because some amount of the mass/energy within the nucleus goes into keeping it together. Here I have two questions.
1) How would the mass ratio of the nucleus vs mass of it's individual particles combined change if each nucleon would be pulled so far apart that it would sit on the tail edge of the strong force, where separation can occur? What I'm asking is does the mass defect of the nucleus changes with nucleon distance from one another within the bound nucleus system or is it irrespective of that?2)This nucleus as a bound system mass defect is the same mass defect that is responsible for the mass into energy conversion during a nuclear reaction? For example fusion where the product of two fused lighter elements itself weighs less than the two atoms that made the heavier element before the reaction.
So say if I had protons and neutrons sitting around separated and then I somehow magically put them together so that all of them form say deuterium atoms at the same time this would then release a burst of energy similarly to how any other nuclear reaction releases energy whether fission or fusion ? By the principle of the mass to energy conversion?
You produce a really highly excited state or already independent nuclei. The ratio would get closer to 1. Where exactly depends on what exactly you do.
Sure.
Sure. You just had fusion reactions.
@mfb So if the nucleons would get pulled further apart the mass defect of the nucleus would start to disappear until at some point vanish completely?
You can't really do this in a classical way where you could have "more separated" nucleons.
@mfb I know ,I am just asking theoretically.
I guess you can't do that because the nucleons are either bound or not correct?
But in theory the amount of mass converted to binding energy for the bound system should depend on how "tightly" the particles are bound should it not ?
  • · Replies 28 ·
