Birth Death Model: M/M/C Queueing System
1 reply · 3K views · last reply
MCooltA
So for M/M/C queueing systems, I have two types of problems that I have been asked to deal with.
For the first question I am given in my notes, is where the arrival rate is constant λ=10 and service rate is μ=5.122 with 2 servers, i.e. C=2. For this question, I have used the formula to determine the steady state probabilities Pn, which denotes the probability of having n customers in the system.
[tex]p_{n} = (\rho^{n} / n!)(1/S), n ≤ c[/tex]
[tex]p_{n} = (\rho^{c} / c!)(\rho/c)^{n-c} (1/S), n ≥ c+1[/tex]
where [tex]S = \sum_{n=0}^{c} \rho^{n}/n! + (\rho^{c}/c!)((\rho/c)/(1-(\rho/c))[/tex]
On another question, I am given the arrival rate λ=4/(n+1) where n is the number of customers in the system, and μ(the service rate) =2, C(servers) =3 with the system being full once there are 4 customers in the system.
To calculate the steady state probabilities for this question, we have used the formula;
[tex] S=1 + λ_{0}/μ_{1} + λ_{1}/μ_{2} + ... = 1/p_{0}[/tex]
[tex]p_{n} = (λ_{0}λ_{1} + λ_{2}... λ_{n-1})/(μ_{1}μ_{2}μ_{3}...μ_{n})[/tex]
I am having difficulty understanding which formula I should use, depending on the problem. Is the first formula only required when I have an M/M/C queue and the arrival rate is constant.
Right. So that means you cannot use the first formula in the second problem, because: (i) the arrival rate is not constant; and (ii) the queue capacity is finite. (Note: the first formula does not apply either if the queue capacity is finite. There are fancier formulas you can use instead.)
I cannot make any sense of your pn formula in the second case; it looks wrong to me.
It is a mistake to use canned formulas for problems like the second one (unless it, too, happened to be done in your notes). Instead, start from first principles. (1) You have a birth-death process. (2) Draw the transition diagram. (3) Write down in detail, one-by-one, the steady-state equations. (4) Solve the equations [NOT difficul!].
