Bullet hits target 2.0cm below aim point 50m away
  • Thread starter jarrellboog04
    Motion
24 replies · 8K views · last reply
jarrellboog04
A rifle is aimed horizontally at a target 50m away. The bullet hits the target 2.0cm below the aim point.
A. What was the bullet's fight time?
B. What was the bullet's speed as it left the barrel?
Please HELP!
Please HELP!
Welcome to PF.
How long does it take to drop 2 cm?
I have some equations but i am not sure how to use them
jarrellboog04 said:
It does not give me the time
Well then figure it out.
You know gravity.
You know the distance.
So ...
None of those are the equations i have for the problem i have the answer from the back of the book but that does not help if i do not no how to answer it i tried many differnet ways but still can not find the right way
Which of those equations relates gravity, time and position? That is of course if you dropped it from rest, Vo = 0?
jarrellboog04 said:
i changed the 2cm to .02m to get the same units
OK. That you have to do.
So which equation did you try?
I did conversion. I jus figured out the answer to part a i got .064s
i used the equarition
y^f=y^i + (v^y)i delta (t)-1/2g(delta (t)2
Right equation. Good result.
Now it traveled 50 m in that time.
How fast you figure it was going to do that?
jarrellboog04 said:
But now i am trying do part b but cant
I am going to use this equation and see if i can figure it out
x^f=x^i+(v^x)i delta (t)
OK. that works. Xi is 0 of course.
jarrellboog04 said:
i got Xi to be .02m
No. When it was aimed it was aimed toward 0. It dropped .02.
jarrellboog04 said:
u still can not figure it out
Which component are you talking about?
The time times x-Velocity is 50m.
x-Velocity is 50m/.064s
This is not rocket science. Oh, wait a minute, it is.
