Calculate Card Draw Percentages (Aces) - 2/30 to 2/23
  • Context: Undergrad
  • Thread starter Thread starter Maccadin
The discussion revolves around calculating the probability of drawing at least one Ace from a deck of 30 cards, where 2 cards are Aces. Participants explore the sequence of draws, the impact of reshuffling, and the method for calculating the probabilities involved in this scenario.
  • One participant outlines the drawing sequence and initial probabilities for each draw, suggesting a method to calculate the overall chance of drawing an Ace.
  • Another participant proposes using a tree diagram to evaluate the probability of drawing an Ace, questioning whether the goal is to find the probability of at least one Ace or to stop drawing once one is obtained.
  • Clarification is provided that the goal is to determine the probability of having at least one Ace by the end of the drawing process, with the option to stop if an Ace is drawn.
  • One participant suggests calculating the probabilities by considering the chance of drawing an Ace multiplied by the probability of not drawing an Ace in prior draws.
  • A participant reports calculating a total probability of just over 50%, while another mentions a figure of almost 70% when summing base probabilities without weights.
  • One participant expresses confusion about the term "without weights" and seeks clarification on the concept.
  • Another participant proposes a solution using combinations to calculate the probabilities of drawing no Aces in the first two sets of draws and the last draw, arriving at a probability of approximately 0.4867.
  • A correction is made regarding the probability of the last draw, indicating it should be 2/30 instead of 1/30.
Participants express differing views on the calculation methods and results, with no consensus reached on the final probability value or the best approach to the problem.
Participants rely on various assumptions regarding the drawing process, reshuffling, and the interpretation of probabilities, which may affect the calculations presented.
Maccadin
Hey all,
I'm trying to figure out the percentage chance to draw a card based on the information below.
The deck has 30 cards. 2 of them are Aces and I just need to get 1 of them in my hand.
The draw goes like this, I draw 4 cards and if I don't have an ace I can put those 4 cards on the bottom (so no chance of being re-drawn yet) and draw 4 more.
After this the deck is shuffled and I get to draw 1 more card.
With these interactions in mind what is the percentage chance I draw an Ace with this sequence?
I believe the chance are as follows but i may be forgetting something
Draw 1 = 2/30
Draw 2 = 2/29
Draw 3 = 2/28
Draw 4 = 2/27
Draw 5 = 2/26
Draw 6 = 2/25
Draw 7 = 2/24
Draw 8 = 2/23
Draw 9 = 2/26
I for the life of me can't figure it out and would love to know the method to figure it out.Thanks in advance.
For your second draw, it should be 2/29*28/30 + 1/29*2/30. --You can draw a tree diagram to evaluate the probability of each branch.
Is the question asking the probability of at least one ace or do you stop once you have one?
Yes it is the probability of having one Ace at the end of the drawing and you also can stop if you get an Ace.
Okay, then just use the first term in my post #2.
For each draw the probability of drawing an ace is P(ace)*P(no ace in prior draws).
So, as you said, p(Draw 1) = 2/30. Draw 2 = 2/29*28/30 or 2/29*[1-p(Draw 1)]. etc.
It looks like the base probability you have in post #1 is good. Add the weights and the total probability will be the sum of all the cases.
When I did it, I got a total probability of just over 50%. Summing over the base probabilities without weights you had in post #1 gives almost 70%.
Thanks heaps RUber, I also came to the conclusion of ~51%, 50.98% to be exact.
Forgive me as I'm not the best with terminology (or math for that matter), but the 70% figure you propose 'without weights' is there a way to explain that to me?
Thanks again this has helped immensely.
No Problem, Maccadin. When I said without weights, I meant the raw probability of drawing an ace from the deck like you had listed in your initial post.
I was considering the probability of reaching a certain draw the "weight", so that you could use the information you already had and just add an additional factor.
May I offer my solution (I am actually checking my understanding of this type of problems)
The way I would tackle this problem is:
getting no ace in first four cards: q1 = C(28,4)/C(30,4). p1=1-q1
getting no ace on second four cards: q2 = C(24,4)/C(26,4). p2=1-q2
and the last draw:
p3= 1/30, as the whole deck has been reshuffled?
Hence, the p(At least 1 Ace) = p1 + q1*p2 + q1*q2*p3 = 0.4867
Please tell me where did I go wrong...
p3 should be 2/30.
ahh, yes of course 2/30.
thanks.
