Calculating 10% NaOH eqv. to 10% NH4OH
  • Thread starter Thread starter Delicieuxz
This discussion focuses on calculating a sodium hydroxide (NaOH) solution equivalent to a 10% w/w ammonium hydroxide (NH4OH) solution in terms of neutralizing power. The participants emphasize the importance of understanding molarity and dissociation constants to achieve accurate results. It is established that while both solutions will have equal amounts of dissociated hydroxide ions (OH), NaOH will release additional OH, leading to a higher pH. The conversation highlights the necessity of stoichiometry and concentration conversion for proper solution preparation.
  • Understanding of acid-base chemistry and dissociation constants
  • Knowledge of molarity and concentration calculations
  • Familiarity with stoichiometry in chemical reactions
  • Basic principles of pH and its measurement
  • Research the molarity of 10% NH4OH and how to convert it to percent concentration
  • Learn about the dissociation of NaOH and its implications on pH levels
  • Study stoichiometric calculations for acid-base neutralization reactions
  • Explore the concept of pH transitions during neutralization and how to manage them
Chemistry students, laboratory technicians, and anyone involved in preparing chemical solutions for neutralization reactions.
Delicieuxz
How to calculate 10% NH4OH eqv solution of NaOH, taking into consideration extra OH?
Hi, I'm wanting to make a solution of NaOH that has the same neutralizing power per quantity as 10% w/w NH4OH. Given that a 10% solution of both will have an equal amount of dissociated OH, but that NaOH will release additional OH as it is consumed, how should I go about this? Thanks.
Chemistry news on Phys.org
I'm not quite sure what you mean by "a 10% solution." In order to answer this question, you must first know the molarity of the solutions you want to use.
This is an acid dissociation problem, usually covered in general chemistry 3. If you're not familiar with dissociation constants and equilibrium, it could be a bit confusing for you.
10% NH4OH, 90% water, w/w. I'd like to know how to make a solution of NaOH that has comparable neutralizing power, without resulting in PH spikes from additional OH that is released.
No problem with preparing solution able to neutralize identical amount of acid (simple stoichiometry and concentration conversion problem, similar to the ones explained here: http://www.titrations.info/titration-calculation, you just need to convert molarity to percent concentration), but you can't expect identical pH, it will be much higher in the NaOH solution.
You must have the NH4OH solution and the NaOH solution reversed. There is no pH spike during neutralization, just a smooth transition from basic to neutrality. Near the neutralization point the pH changes rapidly though. Perhaps that is the spike you are referring to?
  • · Replies 22 ·
18K
