Calculating angle for trajectory with exit position not at 0,0
1 reply · 3K views
xal
I'd like to calculate the angle to shoot a projectile from a cannon in order to hit a target. However, the position that the projectile will be exiting from will not be at 0, 0 -- it will vary according to the angle of the cannon itself. The projectile will be exiting from the tip of the cannon, but the cannon will be rotated about a different point (both points, as well as the target position, will be on the same plane though).
If the projectile was exiting from 0, 0, then I could use this:
[tex]\tan \left( \theta \right) ={\frac {{{\it v0}}^{2}+\mbox {{\tt `\&+-`}<br /> } \left( \sqrt {{{\it v0}}^{4}-{g}^{2}{x}^{2}-2\,gy{{\it v0}}^{2}}<br /> \right) }{gx}}[/tex]
However, in this case, I was considering replacing [tex]x[/tex] and [tex]y[/tex] with [tex]x-l\cos \left( \theta \right)[/tex] and [tex]y-l\sin \left( \theta \right)[/tex] respectively, where [tex]l[/tex] would be the distance away the tip.
That results in this:
[tex]\tan \left( \theta \right) ={\frac {{{\it v0}}^{2}+\sqrt {{{\it v0}}^{<br /> 4}-g \left( g \left( x-l\cos \left( \theta \right) \right) ^{2}+2\,<br /> \left( y-l\sin \left( \theta \right) \right) {{\it v0}}^{2} \right) <br /> }}{g \left( x-l\cos \left( \theta \right) \right) }}<br /> <br /> [/tex]
Different form:
[tex]-1/2\,{\frac {g \left( x-l\cos \left( \theta \right) \right) ^{2}<br /> \left( \tan \left( \theta \right) \right) ^{2}}{{v}^{2}}}+x\tan<br /> \left( \theta \right) -1/2\,{\frac {g \left( x-l\cos \left( \theta<br /> \right) \right) ^{2}}{{v}^{2}}}-y+l\sin \left( \theta \right) =0[/tex]
But I am not sure if this is a way to do it, and I am not sure to go about solving for the angle either.
Any help would be greatly appreciated! The above equation can be solved for theta by using the Quadratic Formula. Specifically, you can rearrange the equation to the form ax^2 + bx + c = 0 and then solve for x. Once you have x, you can take its inverse tangent to find the angle theta.
