Calculating area using sigma notation
8 replies · 2K views · last reply
Zack K
The question involves using sigma notation of Riemann sums to find the area under the graph of ##x^2+\sqrt {1+2x}##. I managed to calculate most of the values and I have ##16+\frac 8 3 + \Sigma {\frac 2 n \sqrt {9 + \frac {4i} n}}##
[/B]
##\Sigma i= \frac {n(n+1)} 2##
##\Sigma i^2= \frac {n(n+1)(2n+1)} 6##
What I can think of doing to get rid of the root is to square the whole expression, since the area is equal to the expression and I will get area2. Then I can just square root my final answer to get the actual area. But I'm not sure if that will work.
Wouldn't that area be infinity ? Please post a complete problem statement
Sorry my bad. It's between the interval [4, 6]. and n→infinity
First term alone should already yield around 50. Whence the 16 ? the 8/3 ?
Please post your steps in more detail.
O, is that so ? So the area of ##\sin^2 x## is the area of ##\sin x## squared ?
[/B]
No: it won't work. We have ##(\sqrt{a}+\sqrt{b})^2 \neq (a + b)##, so it does not even work for just two terms.
So what's recommended that I do? I know that I have to isolate i, but I can't seem to figure it out.
If you are given a value of ##n##, such as ##n = 30##, you can compute the 30-term sum numerically. If you use something like a spreadsheet, or Matlab, or Maple, or Mathematica, etc., it should not be hard. Even summing ##n = 1000## or more such terms should be do-able in a second or two, but doing it manually might take a few hours.
Paradoxically, in this case doing the ##n = \infty## sum (= the integral) is quite easy, but the finite sums are much harder.
You could set up a Riemann sum using horizontal rectangles, i.e., integrate with respect to y, to avoid the square root.
