Calculating Coordinates of Spherical Triangles
  • Context: MHB
  • Thread starter Thread starter Kel1980
    Spherical Triangles
The discussion revolves around calculating the coordinates of points on a globe, specifically focusing on finding the halfway points (M and N) along a great circle path between two antipodal points (A and B) while passing through a third point (C). The scope includes mathematical reasoning and technical explanations related to spherical and Cartesian coordinates.
  • Participant kel1980 seeks assistance in calculating the coordinates of halfway points M and N on a great circle between points A and B, passing through point C.
  • Some participants suggest converting spherical coordinates to Cartesian coordinates to facilitate calculations, using vectors from the Earth's center to the points.
  • One participant proposes using the cross product of vectors to find points M and N, indicating that M can be calculated as (a x c) x a, where a and c are vectors to points A and C, respectively.
  • kel1980 describes the conversion process from degrees/minutes/seconds to decimal degrees and then to Cartesian coordinates, expressing uncertainty about the correctness of the results.
  • There is a mention of using online calculators for the cross product and converting back to spherical coordinates, but kel1980 expresses confusion regarding the results, particularly the radius of point M.
  • kel1980 raises several possible mistakes in the calculations and questions whether the steps taken align with the goal of finding point M on the same great circle as points A, B, and C.
Participants have not reached a consensus on the correct method to calculate points M and N, and there are multiple competing views regarding the steps and calculations involved. The discussion remains unresolved as kel1980 continues to seek clarification and validation of the approach.
There are limitations regarding the assumptions made in the calculations, the dependence on the accuracy of the conversion processes, and the potential for errors in the mathematical steps taken. The discussion does not resolve these uncertainties.
Kel1980
Hello,
I'm not a student, I'm just trying to figure out how to calculate coordinates on a globe, and I would like to ask for some help.
Let's say I have POINT A on the globe with the following coordinates:
POINT A
Latitude 45° 27' 50.95" N
Longitude 9° 11' 23.98" E
Also I have POINT B which is the Antipode:
POINT B
Latitude 45° 27' 50.95" S
Longitude 170° 48' 36.02" W
Given we are on a sphere (globe), from Point A to Point B for example I can draw 360 great circles, one for each single degree of the sphere:
- and the distance to go from Point A to Point B is 180° (first semi-circle)
- and the distance to go back from Point B to Point A is also 180° (second semi-circle)
Now let's say I have POINT C with the following coordinates:
POINT C
Latitude 45° 26' 48.53" N
Longitude 9° 1' 58.11" E
Given these information, THERE IS ONLY ONE GREAT CIRCLE which:
START IN POINT A
GOES THROUGH POINT C
ARRIVE IN POINT B (completing the first semi-circle of 180°)
COME BACK IN POINT A (completing the second semi-circle of 180°)
My problem is to find the formula to calculate the coordinates of the 2 Points which are half-way (90°) from Point A to Point B.
Let's call these 2 Points as M and N:
START in POINT A
PASS THROUGH POINT M (at 90°)
PASS TO POINT N (at 270°)
Which is the formula to calculate M and N?
On a - plain surface - i would have used the simple proportion of triangles to calculate them, but given is a sphere I don't know the formula to be applied.
I did some online search but I find a kind of difficult to figure it out.
I have been out of school from 15 years now, so I would like to ask if somebody can help me.
I hope my explanation is clear, thanks a lot if you can help!
Cheers
Hi kel1980! Welcome to MHB! (Smile)
I'm on my phone right now, so I'll keep it short.
We can calculate the cartesian coordinates from the spherical coordinates.
Let a be the vector from the center of the Earth to point A.
And let c be the vector to C.
Then we can find M and N with the cross product.
That is (a x c) x a.
Convert back to spherical coordinates and we're done. That is, we have M, and N is its opposite.
Hello Serena!
Thank you soo much for your very fast answer!
I'm trying to do something according to your directions, but I'm not sure I understood them correctly (probably not).
Also still I'm stucked with the formula.
SPHERICAL COORDINATES - I found this on internet: (r, θ, φ) where:
r = Earth radius
θ = altitude
φ = longitude
SO FIRST
I converted my coordinates FROM degress/minutes/seconds TO decimal degrees.
(I used this website https://www.latlong.net/degrees-minutes-seconds-to-decimal-degrees)
POINT A
Latitude 45° 27' 50.95" N -------> Decimal Degrees Latitude 45.46415278
Longitude 9° 11' 23.98" E -------> Decimal Degrees Longitude 9.19000000
POINT B
Latitude 45° 27' 50.95" S -------> Decimal Degrees Latitude -45.46415278
Longitude 170° 48' 36.02" W -------> Decimal Degrees Longitude 170.81000000
POINT C
Latitude 45° 26' 48.53" N -------> Decimal Degrees Latitude 45.44681389
Longitude 9° 1' 58.11" E -------> Decimal Degrees Longitude 9.03277778The conversion allowed me to have the SPHERICAL COORDINATES (r, θ, φ):
POINT A (6,371, 45.46415278, 9.19000000)
POINT B (6,371, -45.46415278, 170.81000000)
POINT C (6,371, 45.44681389, 9.03277778)
SO SECOND I converted the SPHERICAL COORDINATES into CARTESIAN COORDINATES (X, Y, Z)
(using this website: Spherical to Cartesian Coordinates Calculator)
POINT A (4,483.03, 725.29, 4,468.34)
POINT B (4,483.03, -725.29, 4,468.34)
POINT C (4,483.67, 712.77, 4,469.71)
SO THIRD, even if my guess about the coordinate conversion is correct (which I believe not), than how can I calculate the vector??
Thanks a lot if you can help me,
Cheers
Sure!
I didn't check your results, but they do look correct.
The next step is to calculate the so called 'cross product'. I think we can find online calculators for that as well.
I like Serena said:
Sure!
Thx again for your fast reply! (Smile)
When you wrote "cross product" in your first message I didn't really get the meaning of it (I'm not english), so I googled it again now and I found out it is the name of the operation / formula!
(Also I found a website to calculate it! Online calculator. Cross product of two vectors (vector product))So I did it:
POINT A
(r, θ, φ) (6,371, 45.46415278, 9.19000000) <--- the spherical coordinates
vector a = (4,483.03, 725.29, 4,468.34) <--- the cartesian coordinates
POINT C
(r, θ, φ) (6,371, 45.44681389, 9.03277778) <--- the spherical coordinates
vector c = (4,483.67, 712.77, 4,469.71) <--- the cartesian coordinates
USING the website i calculated (a x c)
a x c = (56937.2641, -3282.0135, -56591.7212)
NOW that I have (a x c), using the website again I calculated (a x c) x a
(a x c) = (56937.2641, -3282.0135, -56591.7212)
(a x c) x a = (257.266558; -508117438.55983; 56009393.259994)
Which if is correct it means it is M:
M = (257.266558; -508117438.55983; 56009393.259994) <--- the cartesian coordinates
USING the website I converted POINT M Cartesian Coordinates in Spherical Coordinates as follow:
POINT M
from Cartesian Coordinates (X, Y, Z) (257.266558, -508117438.55983, 56009393.259994)
to Spherical Coordinates (r, θ, φ) (511,195,054, 83.71, -90)
THEN using the website I converted the coordinates FROM decimal degrees TO degrees/minutes/seconds as follow:
POINT M
LATITUDE 83.71 ----> 83° 42' 36'' N
LONGITUDE -90 ----> 90° 0' 0'' W
----- CONCLUSION / ISSUE -----
POINT M looks just as a random point on the map.
As I said before I need to find POINT M which is Half-Way between POINT A and POINT B, and at the same time on the same Great Circle of POINT C.
----- POSSIBLE MISTAKES -----
1) The steps I used and described in this last post are wrong.
2) In order to calculate the "cross product" (a x c) x a I first calculated (a x c) and than I "cross product" the result with a as (a x c) x a. Is that correct?
3) Maybe I did some calculation errors in this post or in the previous posts.
4) I started with the following Spherical Coordinates:
where 6371 Km is Planet Earth Radius
After all the steps I end up with Spherical Coordinates:
POINT M (511,195,054, 83.71, -90)
Instead of Radius 6,371 I end up with Radius 511,195,054. Does this Radius make sense?
5) I need POINT A, POINT B, POINT C, and POINT M, to be all of them on the same Great Circle.
You told me to calculate Point M as:
"(a x c) x a"
I'm wondering, is this correct? Or is there something missing? Will the formula take in account that also "b" is on the same Great Circle?That's all.
Hope you can help!
Thx again!
r = Earth radius
θ = altitude
φ = longitude
I'm afraid that θ is the so called colatitude.
That is $θ = 90^\circ - \text{latitude}$.
Oh, and it is not altitude. That's something else again.
So this is not correct after all. On that website for spherical coordinates we need to fill in $θ = 90^\circ - \text{latitude}$.
They do look all right, although I didn't check them.
Yes.
Yes, there is a mix-up between latitude and co-latitude.
Yes, this is expected, and it's not a problem.
It's because the cross product multiplies the length of the vectors.
And to be fair, we're not interested in the radius, just in the latitude and the longitude.
So we can completely ignore the radius of the earth, and just fill in $r=1$.
"(a x c) x a"
Yes.
Points A and C define the great circle uniquely.
And B is just opposite of A. Any great circle through A will therefore go through B anyway.
Hello Serena,
today I have spent some more time trying to figure out the problem.
I found out I several mistakes both of concept and of calculus that I did yesterday.
Now will follow the revised version.
In this revised version I'm pretty confident that the Conversion from Spherical Coordinates to Cartesian Coordinates is accurate 100%.
To make sure that the Conversion is correct, I used 2 different Conversion Methods.
POINT A
LATITUDE 45° 27' 50.95" N
LONGITUDE 9° 11' 23.98" E
- FIRST METHOD -
I converted both Latitude and Longitude from DMS (Degrees Minutes Seconds) to Degree:
LATITUDE 45° 27' 50.95" N -----> 45.464
LONGITUDE 9° 11' 23.98" E -----> 9.190
(I used this website for the conversion: https://www.latlong.net/degrees-minutes-seconds-to-decimal-degrees)
Than in order to transform the (r, θ, φ) Spherical Coordinates, in (x,y,z) Cartesian Coordinates, I applied this formula:
where
r is Earth radius 6.371.008
θ is latitude
φ is longitude
PLEASE NOTE:
Latitude (θ) goes from 0° to 90°.
Point A latitude is 45.464 which it means it goes from 0° to 45.464°
In order to apply the formula I need the distance from 45.464° to 90° (see θ on the image above above)
So: θ = 90° minus 45.464° = 44.536° So I converted (r,θ,φ) (6.371.008, 44.536, 9.19), in (x,y,z), applying the formula using this website: Spherical to Cartesian Coordinates Calculator
The Cartesian Coordinates obtained are:
POINT A
X: 4,410,997.72
Y: 713,635.70
Z: 4,541,317.67
PLEASE NOTE:
For any Point that I convert from Spherical to Cartesian with this formula, i always use the same Radius (6.371.008).
This imply that the assumption of this first method is that Earth is a perfect sphere with Radius 6.371.008.
- SECOND METHOD -
The second method is faster.
As you can see from the image below I simply have to fill the DMS (Degrees/Minutes/Seconds) Cordinates, and the website calculate the Cartesian Coordinates.
PLEASE NOTE:
As you can see from the Image above, this website use the Ellipsoid WGS World Geodetic System (which is an International standard used also by Google Earth). The "Ellipsoid WGS" keep in consideration the ellipsoid shape of earth, so the result is more accurate.
Over and above of using an ellipsoid shape instead of the sphere, it is possible to adjust even more the Geodetic Height, according to ASL (Above Sea Level) or BSL, to have a much more accurate result. But in my calculation I left "h" empty as I don't need such level of accuracy.
This is the website link for the conversion: APSalin - Free Online Tools - Geodetic To Cartesian Convertor
POINT A
X: 4,423,451.03
Y: 715,650.02
Z: 4,523,675.82
- CONCLUSION -
CARTESIAN COORDINATES (x, y, z) OF POINT A with 1st METHOD (4,423,451.03, 715,650.02, 4,523,675.82)
CARTESIAN COORDINATES (x, y, z) OF POINT A with 2nd METHOD (4,410,997.72, 713,635.70, 4,541,317.67)
As we can see there is a very small difference in the results of the 1st Method VS 2nd Method.
The difference is due to the fact that
- in the 1st Method we are assuming Earth is a perfect sphere with radius 6,371,008
while
- in the 2nd method the website calculator takes in account the fact tha Earth is an ellipsoid according to international standard WGS.
The difference is so small - around 0.3% - that is not relevant for my porpouse, but agreeing to the same results with 2 different methods, it means that the my conversion now are 100% correct.
So, as it is faster, I used the second method to calculate all of my Cartesian Coordinates (x,y,z):POINT A (4,410,997.72, 713,635.70, 4,541,317.67)
POINT B (-4,423,451.03, -715,650.02, -4,523,675.82)
POINT C (4,426,754.09, 703,727.61, 4,522,324.06)
Now that the Coordinates Conversion should have been sorted out, I can procede to try to calculate POINT M and POINT N.
I will do it in the next post!
Please let me know what you think. Thx a lot!
Cheers
Oh Serena, thanks a lot for this post!
I saw it just now. You posted it while I was writing my last post!
It took me a while to make it, and if I would have seen your post earlier, I would have finished earlier! ghghghg (Smile)
r = Earth radius
θ = altitude
φ = longitude
yep! I corrected the formula according to the co-latitude. Now the Cartesian Coordinates in my last post should be all of them calculated correctly!
I like Serena said:
Yes.
Perfect. I'm going to calculate it, and I will make a new post as soon as I finish!
I'm not sure I got this, btw, i will make some tests first, and i will ask in the next post if the case. Thx!
"(a x c) x a"
Yes.
Yes, now is clear. If I have A and B antipodes, and I pick any point C of the globe, if I make a great circle though A and C, it will go now matter what also through B.
But still I find strange that the cross product beetwen A and C will give me a result which is 90° far away from A. Btw I will make the calculation again with the correct Cartesian Coordinates and I will make a new post later!Thx again!
Cheers
  • · Replies 18 ·
