How Do You Calculate Frictional Force for Moving Boxes?
This discussion focuses on calculating the frictional force for three identical boxes weighing 30 lbs (133 N) each, with coefficients of static friction (μs) of 0.74 and dynamic friction (μk) of 0.64. The applied horizontal forces are 80 N for Box 1, 100 N for Box 2, and 120 N for Box 3. Box 1 does not move as the applied force (80 N) is less than the maximum static friction (99 N), while Boxes 2 and 3 move, with dynamic friction calculated as 64 N and 76.8 N respectively. The calculations utilize the equations Fmax = μs * RN and dynamic friction = μk * RN.
  • Understanding of Newton's laws of motion
  • Knowledge of static and dynamic friction coefficients
  • Ability to calculate normal force (RN)
  • Familiarity with basic algebra for force calculations
  • Study the principles of friction in physics, focusing on static vs. dynamic friction
  • Learn how to calculate normal force in various scenarios
  • Explore real-world applications of friction in engineering
  • Practice problems involving multiple forces and frictional calculations
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone interested in understanding the principles of friction in practical applications.
vrobins1
Three identical boxes sit on concrete floor, each box weighs 30 lbs (133 N). Each has a coefficient of static friction of 0.74 and a coefficient of dynamic friction of 0.64. Horizontal force of 80 N is applied to Box 1, horizontal force of 100 N is applied to Box 2, and horizontal force of 120 N is applied to Box 3.
a.) Do any of the boxes move?
b.)Calculate the actual frictional force elicited between the ground and box in each case. If the boxes move, compute the dynamic friction that resists the sliding. If the boxes do not move, compute the static friction that resists the applied force.
Note: frictional force is not always the maximum.
a.) F = ma
RNormal- W = ma
RN = W
Fmax = \mus (RN)
b.) not sure
a.) I used RN = W to determine that RN = 133 N
Then I used Fmax = \mus (RN)
Fmax = 0.74 (133)
Fmax = 99 N, the force required to move the box
So Box 1 would not move, Boxes 2 and 3 would move.
b.) This is where I am most confused, I am not sure how to calculate the static and dynamic friction, but I tried anyways:
For Box 1: static friction = \mus (Fapplied)
=0.74 (80 N)
=59.2 N
I did the same for Box 2 and Box 3, but I multiplied their applied forces times the coefficient of kinetic friction given, 0.64.
Box 2 = 64 N
Box 3 = 76.8 N
Can anyone offer any insight into what I did wrong, or if I did this correctly? Thank you.
Fmax = 0.74 (133)
Good.
Hints:
Static friction ≤ μsRN
Dynamic friction = μkRN
10K
