Calculating Paint Usage on a Cube with Differentials
5 replies · 3K views
Martin Spasov
A coat of paint of thickness 0.02 in is applied to the faces of a cube whose edge is 10 in, thereby producing a slightly larger cube. Use differentials to find approximately the number of cubic inches of paint used. Also find the exact amount used by computing volumes before and after painting.
V = x3
f'(x) = 3x2
dy = f'(x)dx
dy = 3*102*0.02 = 6
However the actual solution is 12 (from the answers). Even when doing it manually :
6 * 102 * 0.02 = 12
When I compute the volume before and after I get the same result as before :
10.023 - 103 = 6.012008
I can clearly see that there is factor of 2 difference, but why ? I used the formula and did not get the solution, what exactly was not ok ?
p.s. first post, if I did something wrong, please point it out :)
V = x3
f'(x) = 3x2
dy = f'(x)dx
dy = 3*102*0.02 = 6
6 * 102 * 0.02 = 12
For sides of length ##x## the total surface area is ##A = 6 x^2##, because there are 6 faces of area ##x^2## each. What is ##dA##?
Ray Vickson said:
I'm leaving that up to the OP to think about.
That's how it was meant. You beat me while I was typing it. But have you noticed that the OP now has solutions in 1,2 and 3 dimensions? Sorry, someone deleted the 3-dimensional one.
Edit: What a pitty. It was a funny situation.
Thanks guys, the problem was hat i was equating dx to 0.02 and not to 0.04. Now everything worked out fine :)
