Calculating pH of the 1,96 % H3PO4 solution
  • Thread starter Thread starter brunetteangel
    Ph
3 replies · 4K views
brunetteangel
Calculate pH of the 1,96% solution of H3PO4 (ρ≈1 g/cm^3). Take in account only the first constant of dissociation (7,5 * 10^-3 mol/cubic dm). The reduction of the concentration of H3PO4 because of dissociation can be ignored.
% = 1,96%
ρ (H3PO4) ≈1 g/cm^3
K = 7,5 * 10^-3 mol/cubic dm
No equations in this task.
Couldn't even attempt to solve it, because I don't know how to put the information together.
Convert to the molar concentration first.
You don't know anything about calculating pH of a weak acid? Equilibrium? Dissociation constants?
I know a few formulas, but I think I can't use any of them in this task yet, because I don't have enough information.
And which formula is used for molar concentration, this one:
c (substance) = n (substance) / V (whole solution volume)
or this one:
b (substance) = n (substance) / m (mass of solvent)
I know that pH can be calculated as
pH = -log [H+] / mol dm^-3
but that doesn't help at the moment. :/
nor this one:
[H+] = Kw / [OH-]
I also know this:
K = alpha^2 * c
But none of this helps. :/
There is enough information.
First things first - you have to find a way to convert a %w/w concentration (given) to the molar concentration.
Then it will be about dissociation. Can you write reaction equation for the first step of the phosphoric acid dissociation? Can you write formula for the equilibrium constant for this reaction? This will be identical to the definition of the dissociation constant Ka1 (given in the question, just marked K).
