Chemistry Calculating Polystyrene Mv Using GPC
  • Thread starter Thread starter NotJohnson
The discussion focuses on calculating the weight-average molecular weight (Mv) of a polystyrene polymer using GPC data. Initial calculations yielded an Mv of 880.62, which raised concerns due to its significant deviation from the number average molecular weight (Mn) of 23097 g/mol. It was clarified that the lab manual's instructions were misleading, and the correct approach involved using the Mark–Houwink-Sakurada equation with the GPC values. After following the proper procedure, a more reasonable Mv of 38419 was obtained. This highlights the importance of accurately interpreting lab instructions and using appropriate equations for molecular weight calculations.
NotJohnson
I am trying to calculate Mv as part of a lab using GPC data for a polystyrene polymer that I produced with a known polystyrene standard. for the produced PS I have a = .678 and K = .00018 and the standard has a = .725 and K = .011. intrinsic viscosity was measured as .2346
Mn for the polymer from GPC is 23097 g/mol (for reference)
The solvent is THF, I'm not sure if the GPC is conventionally or universally calibrated
IV (eta) = K*Mv^a (Mark–Houwink-Sakurada equation)
ln (Mv) (of PS produced) = 1/(asa + 1) * ln (Kst/Ksa) + (ast + 1) / (asa + 1) * ln (Mvst)
(sa = produced sample, st = standard) (equation correcting for GPC universal calibration)
I used the Mark–Houwink-Sakurada equation and got Mv = 68.08 for the standard
I then used the below equation to solve for my sample and got Mv = 880.62
I am confused as to why this number is so much lower than the Mn or Mw. Is this normal or am I using the wrong procedure or equation to calculate this value?
Never mind, apparently the lab manual worded this question very strangely. We were supposed to compare a and K from the literature to the ones from the GPC but only use the Mark–Houwink-Sakurada equation using the GPC values. Doing this gets an Mv of 38419 which is much more sensible (and ignore the effects of calibration method).
