Calculating Resistance in Prototype Boat using Formula of Force
  • Thread starter Thread starter welovephysics
    Force Formula
27 replies · 4K views · last reply
welovephysics
A model boat 1/100 size of its prototype has 0.12N of resistance when stimulating a speed of 5m/s of the prototype , what is the corresponding resistance in the prototype ? water is the fluid in both cases and frictional forces can be neglected.
Why the author need to transform the force into ρ(L^2)(v^2) ?
I know the unit of force is kg(m)(s^-2) , so , IMO , F is directly proportional to L only , right . but , not (L^3)
Fr = Fp / Fm
Handwritten-style worked derivation of Froude number scaling: (Fr)p = Vp/sqrt(gLp) = (Fr)m = Vm/sqrt(gLm), then Lp/Lm = Lr, Vr = sqrt(Lr), Fr = (rho L^2 V^2)r = (rho_r L_r^3), density ratio 1, Fp/Fm = L^3, and Fp = (100/1)^3 x 0.12 = 120 kN.
That's for an accelerating mass, the mass being constant. Here, it's the water that is being moved, and the mass of that is related to the cross-sectional area (L2) and the velocity.
since we do not know the mass of water ( we only know the density of water) , so we use (rho)(L^3 ) to find the mass of water ?
That would be true if we were considering a cube of water of side L, but L is the characteristic dimension of the model/prototype. How does the mass of water displaced in time t relate to L, t, ρ and v?
ρ(L^3) [(L) / (T^-2) ] , which is ρ(L^3)v what are you trying to say ?
No, that's not it. The object moves at speed v. Think of it as a box of side L. What volume of water has to move aside to make way for it in time t?
L^3 ?
i don't really understand what you are trying to say , can you explain further ??
welovephysics said:
L^3 ?
How far does the box move in time t? What volume does the leading face of the box sweep through as the box advances that distance?
the box will move by L in time , t , am i right ? the volume that the leading face of the box sweep through as the box advances that distance is (L^3) ?
It is moving at speed v, not L/t.
so , what are you trying to say , i didnt get you
If a car length L moves at speed v for time t, how far does it go?
car move by vt
is it correct ??
welovephysics said:
car move by vt
Yes, so try answering my post #8 again.
distance moved = vt , volume of the leading face of the box sweep through as the box advances that distance is vt + L
How do you get vt+L? Maybe it would help you to think about a more solid analogy. You are digging a tunnel. The excavator is a cube LxLxL. If it advances a distance vt, how much soil does it have to excavate? Draw a picture.
Still vt + L
  • Hand-drawn sketch on lined paper of a rectangular block floating partly submerged, with a dashed waterline, a smaller box on top, and labels reading vt and L with a brace marking depth.
sorry , the volume of the leading face of the box sweep through as the box advances that distance is (L^3) , what are you trying to say ?
No.
Think about this... if it went for twice as long, 2t, still at speed v, would it still be the same volume?
haruspex said:
No.
no
welovephysics said:
no
So it can't be L3, right?
If the leading face is LxL and advances distance vt, what shape does it 'carve out'? What are the dimensions of that shape?
what shape ? i am getting more confused now
Lay a light box, LxLxL, on soft snow. Press down on it, pushing it down a distance vt. Remove the box. What shape hole have you made in the snow? What is its volume?
volume = (L)(L)( L +vt) , shape = rectangular , is it correct ?
Nearly right. But we are only interested in the volume swept out by the leading face. That moves a distance vt, not L+vt.
so the volume = (L)(L)(vt) ?
