Calculating Tension in a Model Plane's Horizontal Circular Motion
The discussion revolves around calculating the tension in a cord connected to a model plane flying in horizontal circular motion. The plane has a mass of 0.75 kg, is tethered by a 30 m cord, and is at a height of 18 m while making 4.4 revolutions per minute.
  • Participants discuss the forces acting on the plane, including gravitational force and the need for centripetal force to maintain circular motion. There are attempts to relate the forces to Newton's second law and questions about how to approach the problem.
Participants are exploring the dynamics of the problem, with some offering hints about identifying forces and the nature of circular motion. There is a recognition of the need to clarify the roles of different forces, but no consensus has been reached on a specific approach or solution.
Some participants express frustration with the problem, indicating a potential lack of clarity in the setup or the relationships between the forces involved. The discussion reflects a mix of understanding and uncertainty regarding the application of concepts in this context.
st3dent
A model plane of mass .75 kg is flying at a constant speed in a horizontal circle connected to a 30 m cord and is at a height of 18 m. The other end of the cord is tethered to the ground as shown in the picture. The plane makes 4.4 revolutions per minute, and the force that the air exerts on the plane is perpendicular to the wings. What is the tension in the cord?
I can see that the ball moves in constant circular motion with r as its radius.
I know that since the ball makes 4.4 revolutions/minute means that the ball has a period(T) of 13.63 seconds.
I also realize that the sum of all forces = ma
As F = ma, Gm1m2/ r2 = ((m)(4 pi2)(r)) / T2
I see that the force of tension (Ft) has an upwards component of Ftsinx that balances the downwards mg and a left component of Ftcosx that directly causes the circular motion.
However, I do not know how to approach this problem.
Where do I start...your help is much appreciated.
Any object moving in a circle at constant speed must feel a force of mv2/r toward the center. In this case, what could be supplying that force?
Gravity...but how do I solve this damn problem?
Use Newton's 2nd law! First identify all the forces on the plane. Then realize that the acceleration is centripetal, as swansont explained. Hint: the air pushes up (and back) on the plane, gravity pulls down... what is pulling it toward the center?
NO! Gravity pulls downward. The plane is not going downward, it is going in a horizontal circle. What is keeping the plane in that circle?
