Calculating the conversion of potential energy to thermal
The discussion centers on calculating the conversion of potential energy to thermal energy for 1 kg of water falling 53 meters at Horseshoe Falls. The potential energy is calculated to be 519.4 Joules, which converts to approximately 0.492 BTU. Participants clarify that the specific heat capacity (Cp) of water is necessary for determining the temperature change, with Cp being approximately 4.186 J/g°C. The final conclusion is that with 0.454 BTU available, the temperature of the water increases by approximately 0.25 degrees Celsius.
  • Understanding of potential energy (PE = m x g x h)
  • Knowledge of thermal energy conversion (change in Eth = m Cp change in T)
  • Familiarity with specific heat capacity (Cp) of water
  • Basic unit conversions between Joules and BTU
  • Research the specific heat capacity of various substances
  • Learn about energy conversion between Joules and BTU
  • Explore the implications of potential energy in hydroelectric power generation
  • Study the principles of thermodynamics related to heat transfer
Students in physics or engineering, educators teaching energy conversion concepts, and anyone interested in the thermodynamic properties of water.
jongood
Horseshoe Falls, one of the Niagara Falls, has a 53 m drop. Consider one kg of water that
falls over the falls. If, upon hitting the bottom of the falls, all of the water’s potential energy
is converted to thermal energy and this heats the fallen water, calculate the increase in the
water’s temperature.
Ek = ½ m v2
PE = m x g x h
Thermal: change in Eth = m Cp change in T.
So I should be calculate the potential energy of 1 kg of water falling 53 m. Then that that number and convert it to thermal energy. Use the thermal energy number to calculate the change in water temperature?
I calculated the potential energy to be 519.4 J.
Convert Joules to BTU=
519.4 joules = 0.492296212 btu
Now to calculate the increase in the water's temperature, I am not sure if that's the whole fall? I don't think that is possible since the amount of water is always changing. Now if they are talking about the increase in temp of that 1 kg of water... then i have no idea...
Am i on the right track? Thanks
Yep, sounds like we assume that the kinetic energy of that particular kg of water is used to heat just that bit.
You quoted a formula:
What does Cp stand for?
Cp is for constant pressure. I copy and pasted it from a PDF lecture so it got jumbled up.
So thermal is heat already right?
As for the water, should i just assume it is 25 c since that is the standard. How would I convert Btu to C?
Actually Cp is the heat capacity of water - it's a number that says how much Joules you need to heat 1 kg of water by 1 degree Kelvin (or celsius) - look it up!.
You don't need to assume any temperature, the formula says "change in T", right? Well, that's exactly what you're asked for.
Oh yeah. sorry I knew that. It was in my notes but I read it too quickly.
so I am kind of lost here. I know that 1 Btu is what will increase 0.454 kg of water 1 degrees.
Since I have approx .5 Btu of energy but 1 kg of water...
I don't know what formula to use...
If 1 Btu will increase 0.454 kg of water by 1 degree, then how many Btu do you need to increase 1 kg of water by 1 degree?
2.20264317 Btu will be needed. but since I only have .454 Btu, then the water will only increase by approx. .25 degrees C?
I got a slightly different number, but yes - that is the idea.
If you want to use the internationally accepted SI units rather than the weird British units, you could look up Cp in a standard resource and use the value in Joules :D
