Calculating throughput for serial vs parallel
  • Context: Comp Sci
  • Thread starter Thread starter ver_mathstats
    Parallel Serial
9 replies · 3K views
ver_mathstats
We are given two choices for interfacing a serial interface with a latency of 20 microseconds and a parallel interface with a width of 16 bits and a latency of 200 microseconds. How long would it take to transfer 16 bits over each interface?
throughput = data item / latency
I know that a serial interface has a single data line whereas a parallel can have several data lines. Could someone check over my work please and thank you. Would it just be, a serial interface: 16 bits x 20 microseconds for 320 bits per microsecond, and then for parallel it would just take 200 microseconds to transfer 16 bits? So for this it would be better to go with parallel interface?
Thank you and help would be appreciated
Your serial answer should be 320 microseconds not 320 bits per microseconds.
20 usecs/bit x 16 bits = 320 usecs
so yes 200 usecs is faster than 320 usecs.
Reply
Sorry, I just realized that but thank you I got it now
Reply
And @ver_mathstats just to be sure you know, this is a textbook problem and VERY unrealistic. It would be a very odd circuit technology indeed that could manage 20 microseconds for a serial line but require 200 microseconds each for the parallel lines. PLUS, the serial has to be turned from parallel into serial, transmitted, then turned back into parallel.
Reply
  • Haha
  • Skeptical
Is that the brief on SATA vs PATA.:smile:
https://en.wikipedia.org/wiki/SATA
Reply
  • Haha
Oh dear, this seems to have gone off-track. I think the problem starts here:
ver_mathstats said:
Relevant Equations:: throughput = data item / latency
This is not correct. I don't know what "data item" means in this context, but throughput and latency are not related in this (or any similar) way.
Now
will take at least 200 μs to transmit a message of 16 bits. and
will take 20 μs to transmit a message of 1 bit, but in order to work out how long it will take to transmit a message of 16 bits we need to know its data rate, or throughput (also called, erroneously, bandwidth). If it has a data rate of 100 kbps (i.e. 1 bit every 10 μs) then it will take 16 x 10 μs + 20 μs = 180 μs to transfer 16 bits.
Reply
In case @256bits excellent piece of humour is lost on anyone, note that you can in general achieve much higher frequencies on serial cables than parallel cables because you don't have the problem of signals interfering with one another (crosstalk). Also, the "problem" of turning your data from (16 bits) parallel to serial and back again only exists if your data is 16 bits wide in the first place, and ends up 16 bits wide at the other end.
Reply
pbuk said:
Oh dear, this seems to have gone off-track. I think the problem starts here:This is not correct. I don't know what "data item" means in this context, but throughput and latency are not related in this (or any similar) way.
Now
I did not use the formula "throughput = data item / latency" for this problem in particular as I am told I have to calculate throughput in a different part. In my class, I was taught that the data item is denoted as d_i, and can be a bit, and then latency is denoted as delta t, then the throughput is calculated using the formula |d_i|/dt. You then get your answer as throughput in bits per millisecond in this particular problem.
pbuk said:
It is very difficult to understand what you are saying. Try separating different thoughts into different sentences. One thing that is clear is that you do not understand the difference between latency and throughput: this Wikipedia page is quite useful https://en.wikipedia.org/wiki/Network_performance#Performance_measures.
No, I do understand the difference between throughput and latency. Edited the other one as well.
