Calculating Time Deviation Inside the Sun
4 replies · 3K views
Bjarne
How much slower is time ticking inside the Sun, compared to the surface, and how can it be calculated?
How far inside the sun? The rate at which time moves depends upon the gravitational force at the point and that varies from the value at the surface to 0 at the center.
Bjarne said:
The math shown at the link below is above my head, but i guess the time diviation inside the Sun must be about 300000 times larger inside as inside the Earth (the mass difference between the sun and the Earth) ?
https://www.physicsforums.com/showthread.php?p=1543402#post1543402
No, time dilation isn't proportional to mass difference in that way. Just use the following equation from George Jones' link, giving the ratio of a clock at the center to a clock at the surface:
[tex] <br /> \frac{d\tau_{centre}}{d\tau_{surf}}=\left( \frac{d\tau_{centre}}{dt}\right) \left( \frac{d\tau_{surface}}{dt}\right)^{-1} =\frac{\frac{3}{2}\sqrt{1-\frac{2GM}{c^{2}R}}-\frac{1}{2}}{\sqrt{1-\frac{2GM}{c^{2}R}-v^{2}}}<br /> [/tex]
With G=the gravitational constant (6.67428 *10^-11 m^3 kg^-1 s^-2), M=mass of the Sun (2 * 10^30 kg), R=radius of the sun (6.955 * 10^8 m), c=speed of light (299792458 m s^-1), and v set to zero (assuming someone at rest on the surface). There's an online calculator http://www.math.sc.edu/cgi-bin/sumcgi/calculator.pl if you need it.
