Calculating Variance: Sample vs Population
3 replies · 2K views
CAH
Member warned multiple times about not using the homework template
See the photo of the question+ mark scheme!
I don't understand a question on finding an expression for the variance of something...
Attempt at solution: also I worked out c as (3/2) previously, which is correct
Var(U) = (3/2)^2 x Var(Xbar) = 9/4n^2 x a^2/18
I'll attach a photo of this too if it's easier to read, my problem is that I thought var(Xbar) = var(x/n) = 1/n^2 x var(x)
... But they have done var(Xbar) = 1/n x var(x) ...?
Think about this:
[tex] Var\left(\bar X\right) = Var\left(\frac 1 n \sum_{i=1}^n X_i\right) = \frac 1 {N^2} \sum_{i=1}^n Var(X_i)[/tex]
What happens when you simplify the sum?
Ah I see so it's just sigma^2/n, is this the same for all cases as in, calculating the variance of a sample and estimating a population variance?.. In other words, kinda, will it ever (a level standard) be 1/n^2 x var(x)
Probably a stupid question, just checking
The only time you would have [itex]n^2[/itex] in the denominator is if you were (for some reason) considering mathematically a single observation [itex]X_1[/itex] and calculate
[tex] Var\left( \dfrac{X_1}{n}\right) = \dfrac{Var(X)}{n^2}[/tex]
"is this the same for all cases as in, calculating the variance of a sample and estimating a population variance?"
I'm not exactly sure what you mean by this, so if my response is off-target that's why.
If you've talked about sampling distributions for the sample mean, the expression [itex]\frac{\sigma^2}n[/itex] is the population variance for that sampling distribution. It will never have denominator [itex]n^2[/itex], since, as long as the distribution being sampled has a variance, the steps shown above apply.
The (sample) variance of a sample is a different beast. Essentially
* if the population variance is [itex]\sigma^2[/itex], then the sample variance
[tex] s^2 = \dfrac 1 {n-1} \sum_{i=1}^n \, \left(x_i - \bar x\right)^2[/tex]
is an unbiased estimator of the population variance
* If you refer to the variance of the sampling distribution of [itex]\bar x[/itex] - which is given above - then to estimate that you have two options
a) If you have a single sample, use the sample variance [tex]s^2[/tex] to estimate the sampling distribution's variance by calculating
[tex] \dfrac{s^2}{n}[/tex]
b) If you have a large number of samples, all the same sample size, from the same population, then calculate each sample mean and treat those sample means as a new sample. The sample variance of those (call it [itex]s_{\bar x}^2[/itex]) is the estimate of [itex]\dfrac{\sigma^2}{n}[/itex]
So there are several subtleties to wade through, but in none but the one unusual and unrealistic comment I made at the start will [itex]\frac{\sigma^2}{n^2}[/itex] play a role.
