Calculating Vector Components: Finding B_y with A-B Parallel to -x Axis
To find the y-component of vector B (B_y), it's crucial to recognize that the vector A - B is parallel to the -x axis, indicating that its y-component must equal zero. The calculations for vector A's components yield A_x = 3.10 cm and A_y = 2.97 cm. Since A - B is parallel to the -x axis, the y-components of A and B must cancel each other out, leading to the equation A_y - B_y = 0. Thus, B_y can be determined as equal to A_y, which is 2.97 cm. Understanding vector subtraction and the implications of parallel vectors is essential for solving this problem.
jamesbrewer
The diagram below shows two vectors, A and B, and their angles relative to the coordinate axes as indicated.
[URL]http://loncapa.physics.mun.ca/res/mun/PHYSICS/msuphysicslib/Graphics/Gtype07/prob01a_vectors2.gif[/URL]
DATA: α=43.7°; β=53.4°; |A|=4.30 cm. The vector A−B is parallel to the −x axis. Calculate the y-component of vector B.
A_x = |A| cos \theta, A_y = |A| sin \theta
I easily found that A_x = 4.30 cm cos(43.7) = 3.10 cm and A_y = 4.30 cm sin(43.7) = 2.97 cm.
The problem I'm having is figuring out how to calculate B_x with only the information I have. If I had |B| then I could easily solve for B_x. The problem states that \vec{A-B} || -x-axis, but what role does this play in solving the problem?
Try drawing a picture. It can be very difficult to sort this sort of thing without a good reference.
The key to this problem is the statement that \vec{A} - \vec{B} is // to the -x axis. What does it mean if a vector is parallel to an axis? Also, how do you subtract two vectors? If you can answer these two questions, you should be able to figure out By.
A vector being parallel to an axis can tell you something about it's direction. In this case, the vector is parallel to the -x axis. Is the fact that it's parallel to the negative x-axis (as opposed to the positive x axis) important here? If so then that means that \theta_{A-B} = 180 deg.
When you subtract a vector \vec{A} from another vector \vec{B}, you are essentially adding the negative of \vec{B} to \vec{A}.
So, from this I gather that \theta_{A-B} = 180 deg, but I'm still having trouble seeing how that helps me find B_y. To find B_y, I need to find the magnitude of B, don't I?
Technically, the positive x-axis and neg x-axis would both be parallel. The fact that the problem specifies the negative is suggestive, but I would ask the professor if I were you. There's a more important point here though, and it has to do with how you subtract vectors.
Remember that you have to perform algebraic operations on the components of vectors. \vec{A} - \vec{B} is not the same as \vec{A-B}. So, if \vec{A} - \vec{B} is parallel to an axis, what does that tell you about the components? If your having a problem with this, I suggest drawing a picture or going over vector calculus (search the web, look to your textbooks or ask your professor).
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
