Calulate rapid prototyping stl build time
  • Thread starter Thread starter SagarPatil
    Build Time
The discussion focuses on calculating the build time for a 3D printed part using a specific formula. The formula incorporates the area of the layer, scanning speed, spot size, and delay time between layers. Participants emphasize that while the formula can provide a theoretical time, actual print times may vary due to factors like infill percentage and part shape. To determine the total build time, one must calculate the number of layers based on the part height and layer thickness. The conversation suggests using slicer software for more accurate results, especially for complex shapes.
SagarPatil
I am not sure where this goes , if this is the wrong place sorry.
The question is asking for
Time required to build the part.
The 4 is the total length of the part.
It also says the scanning speed is 80ft/min
the spot size is 0.010 in
delay time is 7 sec/layer
The formula that is given
Ti=(Ai/(vD))+Td
Where
Ti= time to complete layer
Ai=area of the layer
v= average scanning speed of the laser beam at the surface
D= diameter of the spot size
Td= delay time between layers to re position the worktable
I want to know the steps of this forumla.
Are you familiar with how a 3D printer works?
If you put units into the formula and it should become clear.
Ti=(Ai/(vD))+Td
Time taken = (area to be covered / (speed of print head * width of printed line) + time to reposition for next layer
Seconds = m^2 / (m/s * m) + Seconds
If you know the layer thickness you can expand the formula to give a total time to make the part.
Of course most parts are not printed with 100% infill so actual time may be significantly shorter.
The actual time is difficult to calculate accurately (by hand) as it depends on the part shape, the slicing method, infill shape x, y, z max acceleration etc etc
Most slicer programs can calculate it for you.
Ti=(Ai/(vD))+Td
Yes, I am familiar how 3D printing works. I have printed a few parts. I know that the printer will calculate the time, but the question is asking to caclulate manually .
So when I calculate the time
(I am choose the bottom surface)
Ai=3*4 = 12
v=16in/second
D=0.01
Td=7
When I enter it in the formula I get
82 seconds
82 seconds gave me the time to build 1 layer
The question is asking how long will it take to build the whole part.
If the part is prismatic then each layer takes the same time so clearly:
total time = #layers * (time/layer)
To calc. #layers you need this information:
If the part is not prismatic, you'll need to derive an expression for area as a function of height. Then maybe a bit of integration.
Your formula assumes infinite acceleration of the print heat & 100% infill - not a realistic model and will give poor results.
Is this homework? If it isn't, why not just use the printers software? Or upload your STL to an on-line print calculator? Anything else will not be accurate.
This was a question from a exam where you have to calculate the time it takes. I know printers can calculate the time, but what can I do.
When you calculate the time which was 82 seconds
You divide the thickness/height by the layer thickness. The layer thickness can be any reasonable number.
So in this case 1/0.02 = 50
So 50*82 = 4100 seconds to make the bottom part
Do the same thing on the top part.
Yes, that's right. If you choose a better (ie prismatic) orientation you'll get the answer faster.
Let your image be the plan view/layer shape then layer area is constant and you have more time for other exam questions.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 96 ·
11K
