Can a Path Integral Formulation for Photons Start from a Massless Premise?
The discussion revolves around the possibility of formulating a path integral for photons starting from a massless premise, rather than deriving masslessness from Maxwell's equations. Participants explore the implications of using a specific action for photons and the challenges associated with it.
  • One participant proposes an action for photons that includes a frequency as a Lagrange multiplier, questioning if this can be used in a path integral formulation.
  • Another participant suggests that since light has zero world interval, a different parameter than proper time should be used for integration, referencing Fermat's principle.
  • A third participant discusses the action for a relativistic particle, emphasizing the need to reformulate the problem as a constrained system and noting that the massless limit can be achieved, but questions the justification for identifying such a particle as a photon.
  • Another participant states that there is no particle action for a massless vector theory, indicating limitations in formulating actions for massless particles compared to massive ones.
Participants express differing views on the feasibility of starting from a massless premise for photons and the appropriate formulation of actions. There is no consensus on the validity of the proposed actions or the implications of masslessness.
Participants highlight various assumptions, such as the need for a different parameter for integration and the constraints involved in formulating actions for massless particles. The discussion remains open regarding the implications of these assumptions.
gerald V
TL;DR
Can one do first quantization of electromagnetism starting from a photon action?
I am aware that one usually starts from the Maxwell equations and then derives the masslessness of a photon. But can one do it the other way round? The action of photon would be ##S = \hbar \int \nu (1 - \dot{x}^2) \mbox{d}t##, where ##\nu## is the frequency acting as a Lagrange multiplier, forcing the velocity squared to be unity and the action to be null.
Does it make sense in principle to use this action for a path integral formulation?
If yes, how to deal with the factor ##\nu##? Can one assume it to be constant if the photon is free?
Can one add to the action a hypothetical „potential“ making the frequency vary, for example to let the photon couple to some electromagnetic current? How then to deal with the frequency inside the path integral?
Thank you very much in advance
Light path has zero world interval s or proper time so we cannot take s as parameter for integral. We should find other parameter than s. Fermat's principle or geodesic of light would suggest you a hint to your question.
The action for a relativistic particle is
##S = - m \int ds = - m \int \sqrt{-\dot{x}^2} d \tau##
This clearly assumes ##m \neq 0##, however we must also recognize that the system is a constrained system since ##p_{\mu}## satisfies ##p^2 = m^2##, so one should really first reformulate the problem as a constrained system. On doing this one can show the action can be reformulated as
##S = \frac{1}{2} \int e (e^{-2} \dot{x}^2 + m^2) d \tau##
where ##e## can be interpreted as a metric. This action reproduces the original action on using the equation of motion for ##e##, and it also encodes the ##p^2 = m^2## constraint directly in the action rather than as a constraint. This form of the action admits a massless limit ##m \to 0##. Quantizing the action in this form results in the Klein-Gordon equation applied to a quantum wave function, which all free particle wave equations must satisfy. Why such a particle is a photon as opposed to simply a scalar, starting from the classical picture, requires justification.
There is no particle action for a massless vector theory. One can only build that for a massive scalar (einbein formulation, see the post by @throw ), or a massive spin 1/2 particle (the Brink-Howe-DiVecchia action for a fermionic elementary particle).
  • · Replies 19 ·
  • · Replies 58 ·
  • · Replies 157 ·
17K
