Can all quadratic equations be factorised?
Not all quadratic equations can be factorized into the form (ax+b)(cx+d) using real or rational coefficients. While some quadratics can be factored easily, others require complex numbers for factorization. The condition for real factorization is that the discriminant (b²-4ac) must be non-negative. For rational factorization, the discriminant must be a perfect square. Therefore, the ability to factor a quadratic depends on the nature of its coefficients and the discriminant.
Kyoma
Is it true that all quadratic equations (ax2+bx+c) can be factorised into this form: (ax+b)(cx+d)?
I think so, but I'm not certain.
If d is just some arbitrary number and you didn't accidentally duplicate your letters, then no.
Example:
y = x2-2x+1
So a = 1, b = -2, c = 1
So y = (x-1)(x-1)
a, c and d are fine, but you have a -1 instead of b.
As gb7nash said the coefficients a, b, and c, in (ax2+bx+c) are not, in general, the same as those in (ax+b)(cx+d).
So, can (ax2+bx+c) always be factored into the form, (px+q)(rx+s)?
The answer is ... maybe.
If you allow q and s to be complex numbers, then the answer is yes.
If you restrict q and s to be real numbers, then you must have \sqrt{b^2-4ac}\ge0
If q and s must be rational numbers, then you must have \sqrt{b^2-4ac} be a perfect square.​
This all assumes that a, b, and c are rational numbers.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
