Solving Differential Equation xy'' - y' + 4x^3y = 0 with Self Adjoint Form
  • Context: Graduate
  • Thread starter Thread starter revolution200
The differential equation xy'' - y' + 4x^3y = 0 for x > 0 can be solved by converting it to self-adjoint form and using the auxiliary equation. The general solution is y = Acos(2x) + Bsin(2x). To find two independent solutions, one can set A = 0, B = 1 for y1 and A = 1, B = 0 for y2. The Wronskian must satisfy Abel's identity, which requires careful verification of the constants used in the general solution.
  • Understanding of differential equations and their solutions
  • Familiarity with self-adjoint forms and Abel's identity
  • Knowledge of Wronskian and its significance in linear independence
  • Experience with auxiliary equations in solving differential equations
  • Study the derivation and application of self-adjoint forms in differential equations
  • Learn how to compute the Wronskian for given solutions
  • Explore Abel's identity and its implications for linear independence
  • Investigate the method of auxiliary equations in greater detail
Mathematicians, students of applied mathematics, and anyone involved in solving differential equations, particularly those interested in self-adjoint forms and linear independence of solutions.
revolution200
I have got a general solution for the equation
xy'' - y' + 4x^3y = 0, x > 0
by converting to the normal version of the self adjoint form and solving with an auxiliary equation I have
It then asks to select two independent solutions and verify the wronskian satisfies Abel's identity.
Can I simply set A = 0, B = 1 for y1 and A = 1, B = 0 for y2
I did this and I got 1 for the wronskian and kx for Abel's which doesn't prove it!
Can anybody tell me where I'm going wrong please
If y= A cos(2x)+ B sin(2x), y'= -2A sin(2x)+ 2B cos(2x), and y"= -4Acos(2x)- 4Bsin(2x).
Putting those into the equation gives:
xy'' - y' + 4x^3y = -4Axcos(2)- 4Bxsin(2x)+ 2Asin(2x)- 2Bcos(2x)+ 4x^3Acos(2x)+ 4x^3Bsin(2x) which is definitely NOT equal to 0. y= Acos(2x)+ Bsin(2x) does NOT satisfy the equation.
Yes, dividing the equation by 1/x2 puts it into self-adjoint form but what did you do from there?
I put it into the normal version of the self adjoint form.
Where d/dx{p(x)dy/dx}+q(x)y=0
t = integral of 1/p(x) = x^3/3
dt/dx = x^2
dy/dx = dy/dt.dt/dx = dy/dt.x^2
etc.
Then solved using the auxiliary equation. It probably is my working that is wrong, however the question I really needed answering is; if I get a solution to the differential equation, to get two linearly independent solutions from the general solution can I simply assign values to the constants.
Thank you for your response
I get m=+-sqrt(-4)
=+-2i
y = exp(alpha*x){Acos(beta*x)+Bcos(beta*x)}
where alpha is real and beta is imaginary
therefore
alpha is = 0
beta is = 2
y = Acos(2x)+Bsin(2x)
my values were for t not x, I forgot to substitute them back in
y = Acos(2t) + Bsin(2t) where t = x^2/2
it works now
Thanks for your help
