Can Eigenvalues Be Shifted by a Scalar?
  • Thread starter Thread starter sana2476
    Eigenvalue Proof
10 replies · 3K views · last reply
sana2476
Let λ be an eigenvalue of A. Then λ+σ is an eigenvalue of A+σI
I'm guessing I need to use the fact that λ is an e.v of A to start with. But then when I add σ to both sides somehow I feel like I'm begging the question..
You know that if [itex]\lambda[/itex] is an eigenvalue of A, then [itex]A\boldsymbol{v}=\lambda \boldsymbol{v}[/itex] is the appropriate eigenvalue equation with v an eigenvector. So if [itex]\lambda+\sigma[/itex] is an eigenvalue of[itex]A+\sigma I[/itex],then what would the appropriate eigenvalue equation be?
The appropriate e.v equation would then be: Ax=(λ+σ)x..is that right?
No that eigenvalue does not belong to A but to [itex]A+\sigma I[/itex]. So replace A by [itex]A+\sigma I[/itex] then write out the left side of the equation and see if it checks out.
Yeah, Try adding sigma*x to both sides of equation if you're still stuck.
You want to solve the following equation [itex](A+\sigma I) \boldsymbol v= \eta \boldsymbol v[/itex] for [itex]\eta[/itex]. Do you understand why this is the relevant equation? Now write out the left hand side and use the information given in the exercise.
Thanks I did that...and here's what I have
Ax +σx=λx+σx
Then you have (A+σI)x=(λ+σ)x
and because x doesn't equal zero therefore (λ+σ) doesn't equal zero
which then means that (λ,λ+σ) is an eigenpair of A+σI
While the first two lines you wrote are correct I am not entirely convinced. Why is [itex]A \boldsymbol{ v}+\sigma v =(A+\sigma I) \boldsymbol{v}[/itex] ?
As for the rest. You are correct to say that x is not zero for if it was it wouldn't be an eigenvector. However 0 is a valid eigenvalue so the eigenvalue of [itex]A+\sigma I[/itex] could be zero.
Cyosis said:
While what you wrote is correct I am not entirely convinced. Why is [itex]A \boldsymbol{v}+\sigma \boldsymbol{v} =(A+\sigma I) \boldsymbol{v}[/itex] ?
Looks ok to me … distributive law. :smile:
[tex]x=Ix \Rightarrow \sigma x=\sigma (Ix) = (\sigma I)x[/tex]
