- 16,335
- 258
Yep.
Femme_physics said:Doesn't every D/A has a Vref? How can it function without a analogue input?
I like Serena said:I'm getting confused here.
In your problem statement there is no Vref.
And yes, a DAC would typically have a Vref connected.
Should I assume you mean the voltage that the maximum digital input maps to?
Either way, such a Vref is not really an input, since it is fixed and usually not shown.
Femme_physics said:So to find the resolution of the converter I just use Va Max?
In the absence of a specified Vx max (or Va max) you could express your answer in terms of "Vx max", the maximum analog output available from the DAC.I'm asked to calculate Va, if the counter output is (01101110)2
Femme_physics said:Suppose Va max is 5. The binary output of the converter in question (the one at the original message) is 01001101. I am asked to find Va in that case. You're asking me "what resolution", but You can't solve it without one because you have the formula Va = Resolution x Output in base 10Hmm... Do you follow me?
