wells
- 1
- TL;DR
- Holding 80ft pipe and pump at 450lbs without slipping with two clamped 1' 2x6 wood
I'm planning on lifting a submersed well pump that is hanging on a 80' 2" galvanized pipe. Total weight is estimated to be 447lbs based on:
pump ~ 50lbs
pipe 3.6lbs per foot
water 1.36lbs per foot
The plan is to use two pieces of wood (1 foot of 2x6) with two clamps to hold the pipe in place while getting a new grip with the crane.
To get more grip I'm thinking of applying a locking plyer around the pipe on top of the 2x6.
The question is that realistic? Can I readily get enough of a hold on the pipe to not have it slip?
Based on this professional clamp which can hold 3,000 lbs it should not be too hard.
http://waterbuckpump.com/kwik-klamp-1-drop-pipe-holder/
The lift is to be supplied by a small electric winch able to lift 3500 lbs. The plan is to build a tripod with 4x4's, braced at the top and towards the bottom. Add a 2x6 brace between two legs and mount the winch on it. Then use a winch pulley at the top for the winch cable to go through, thereby keeping the lift weight on the bottom of the tripod, vs having the winch mounted on, for example, a truck, which would add a sideways potential that could cause a failure should the friction build up on the pulley.
pump ~ 50lbs
