Can linearized GR equations describe gravitational waves in static spacetime?
80 replies · 12K views
TrickyDicky
The usual derivation of the wave form equations from the GR field equations is done in the weak field, linearized approximation of the GR theory. In this limit, that ignores non-linear contributions and that gives accurate results when used to predict solutions for problems in the Newtonian limit (classical tests of relativity, more recently rates of orbital decay of binary system pulsar-see Hulse-Taylor pulsar..) the background space is the static flat Minkowski spacetime.
So this linearised EFE when used in the theory of gravitational radiation are mixing a static spacetime that by the Birkhoff's theorem doesn't allow gravitational radiation to exist(this is related to the specific features of static spacetimes that I won't go into in this post) and the interpretation that the equations similarity to wave equations and more specifically to the tranverse EM waves of Maxwell theory (see GEM equations, etc) must mean the existence of gravitational type of waves.
I see here, that at least theoretically, something doesn't fit completely, but maybe it's just my impression, I just would like to understand gravitational waves within the conceptual framework of GR. For instance, if the linearized EFE look like EM wave equations why not consider them EM radiation to begin with?
Moreover, if the background spacetime where the linearized equations are similar to wave equations forbids gravitational type of waves, is this not a sign that maybe they are not gravitational waves, but plain EM waves radiated from the mass quadrupole (which would justify the observed orbital decay in binary systems like the Hulse-Taylor pulsar?
Of course, I'm not proposing any alternative, just would like to know how is this addressed from the point of view of mainstream GR theory, or how any of my perhaps naive premises are not correctly applied to this subject (wich surely are not).
I found the derivation of GWs from the linearized theory somewhat unconviving, but there are exact (vacuum) solutions of the field equations that look like plane-fronted waves with parallel rays (pp-waves). These solutions have Riemann curvature associated with the waves.
What I've never seen is a solution for, say, an oscillating mass that radiates gravitationally. I'm not sure if such a solution can exist because the EMT of the source would not be conservative, whereas the Einstein tensor is guaranteed to satisfy Gmn;n = 0.
No, gravitational waves are very well understood by now, both theoretically and computationally. Including nonlinear effects, and coupling to a time-varying source. The linearized solutions look like electromagnetic waves only in the sense that they obey the wave equation. Apparently the derivations you've read are oversimplified.
Exact solutions tend to be unrealistic. The solution to the type of situation you describe will need to be done numerically. Several groups have now computed the collision of two black holes, including the gravitational radiation that is emitted. See http://www.nasa.gov/vision/universe/starsgalaxies/gwave.html.
Interesting, do you have any reference on those solutions?
Wikipedia has an article on them. As it says there, they were first written down by Hans Brinkmann in 1925.
This doesn't even try to answer in the context of what I posted.
What would you say about the background static spacetime being incompatible with gravitational radiation?
Well. I'd say the fact that they should propagate precisely at c, is another point to consider when referring to the similarity. But certainly they need not be EM waves. Still, since GW are so well understood by now, would you explain to me what exactly is oscillating in gravitational waves? curvature?
George Jones said:
Chapters 17 - 21 of Exact Space-Times in Einstein's General Relativity by Griffiths and Podolsky,
https://www.amazon.com/dp/0521889278/?tag=pfamazon01-20.
Thanks, still as Bill K has just pointed out exact solutions tend to be unrealistic, and I would add that those solutions referred to in the Podolsky book are not very realistic.
What this tells us is that being an exact solution of the EFE doesn't guarantee anything, as there are many unphysical solutions that have nothing to do with our universe.
Helicity. The polarization states of gravitational and electromagnetic radiation transform differently under rotations.
I'd like to emphasize this. There's really no doubt that Einstein's GR does contain gravitational waves. When we actually code in his equations and evolve the binary black hole spacetime, we get very clearly GW coming out. This is something I look at on a daily basis, so I'm quite confident in it :smile:
You mentioned Birkhoff's Theorem, but that applies only to spherically symmetric perturbations. Gravitational waves are quadrupole and higher.
Gravitational radiation is characterized by a 1/r term in the Riemann curvature tensor. Large amplitude waves need to be treated numerically, but for example you can talk about small amplitude perturbations of the Schwarzschild solution. In second order one sees that the Schwarzschild mass decreases with time, corresponding to the energy being carried away by the waves.
I've been reading back copies of 'Matters of Gravity' and there's a fairly detailed description of the numerical methods in this spring 2006 issue.
http://www.phys.lsu.edu/mog/pdf/mog27.pdf
Extract:
Simulating binary black holes has been a long-standing problem because it poses a number
of “grand challenges”. An incomplete list of these challenges includes the following
• Einstein’s equations form a complicated, coupled set of non-linear PDEs, and it is far
from clear which form of these equations is most suitable for numerical implementation.
• Somewhat related is the coordinate freedom, and the question what coordinate (or
gauge) conditions lead to a non-pathological evolution.
• Black holes contain singularities, which can have very unfortunate consequences for
numerical simulations.
• The individual black holes are much smaller than the wavelength of the emitted gravitational
radiation. The resulting range in length-scales is difficult to accommodate in
That's what I'm saying, that there seems to be some incompatibility between a background spacetime that is spherically symmetric and the fact that this kind of spaces don't admit GW kind of perturbations. But rephrasing it doesn't help me understand it.
Again, how can the Schwarzschild spacetime, which is also spherically symmetric and static say anything about GW? It's so confusing.
I know GW are postulated to have different helicity than EM waves, in fact the boson proposed for the grav. radiation, the graviton (that BTW hasn't been detected) has spin 2 in contrast with the spin 1 of the EM radiation boson (the photon) so it is straightforward that they should have different helicity.
The issue here would be how does that postulated difference translate to observational tests, and there one faces the problem that gravitational waves (or gravitons for that matter) have not been directly detected so far, and according to some people they might not be detected in many years if ever, so this raises problems with falsability, since the indirect observations that makes us suspect the existence of GW (orbital decay of certain binary sistems) can't distinguish helicity differences.
Bill_K said:
... but for example you can talk about small amplitude perturbations of the Schwarzschild solution. In second order one sees that the Schwarzschild mass decreases with time, corresponding to the energy being carried away by the waves.
Do the perturbations, in this case, destroy the spherical symmetry ? Like a short-lived dimple ?
Extract:
Thanks, at least someone else acknowledges that all is not so nice and easy with the BH binaries numerical simulations as Bill k and Nabeshin seem to imply
Any gravitational wave solution is not spherically symmetric or static, so you can't talk about gravitatational waves in the Schwarzschild spacetime; they are ruled out by definition. This solution is for a single static mass in an empty universe - not very interesting. It's like saying 'how can you have EM waves in a Maxwell solution for a single, stationary charge?"
Good point, and nobody seems to be aware of this.
This is from 2006, around the time when Pretorius made his breakthrough involving constraint damping parameters for numerical relativity. The field has advanced considerably since then, to the point where I feel like most groups doing numerical relativity have conquered many of the large issues quoted.
Extraction and analysis of gravitational wave signals from a binary inspiral is now quite routine (to the point where an undergraduate, namely myself, can do it).
I don't mean to imply that there are no difficulties with numerical relativity, just that extracting gravitational wave signals is not a very difficult problem. One problem encountered is that the waves are necessarily evolved on a finite grid and thus subject to 1/r gauge effects. But this isn't a big deal since there are schemes for extrapolating this out to infinity or using CCE to get the 'true' waveform. Similarly, there are all kinds of difficulties in simulating dynamical spacetimes and getting meaningful information once one has the waves, but I don't think the waves themselves are too difficult.
I don't see how you could interpret the wave equation for GW as possibly being EM waves when the linear EFEs in vacuum involve differential equations with a symmetric, second - rank tensor as opposed to EM's 4 - potential.
The Riemann tensor describes the curvature and has two components, the Ricci tensor and the Weyl tensor. The Weyl tensor carries the changes in curvature.
You do know there is a tensorial formulation of electromagnetism, don't you? The electromagnetic tensor is antisymmetric but remember that in the derivation of GW from the linearized EFE a Lorenz (aka "de donder") gauge condition is imposed that symmetrizes the tensor.On the other hand, I'm not asserting that the waves derived from the linearized EFE have to be EM waves, but merely suggesting that interpreting them as a new form of radiation is just a model-dependent interpretation of GR, that is not without a number of theoretical problems that have not been fully solved and yes, so far it appears as the most correct, but this might be just because there is no other model around to fit a different interpretation in.
The main problem I pointed out was a problem of coherence that has not been satisfactorily answered so far, that of deriving gravitational waves from spacetime models that don't admit that kind of radiation.
After reading some more, there seems to be different approaches to this problem, for instance the "Bondi radiation coordinates" and similar that deal with things like a pulsating kind of universe that alternates from a static configuration when there is no GW perturbation and a different configuration when the perturbation is produced. Not very physical kind of scenarios apparently, but maybe I'm not understanding them well.
Perhaps somebody is more versed in these and could explain them to me.
This seems to be unrelated to my question, I asked what oscillates in a gravitational wave?
For instance when it is said that GW are ripples of curved spacetime, I find very difficult to picture it, because one would think that it would have to ripple wrt something, if the ripple describes some kind of motion-like process, how can curved spacetime move?
In the case of EM waves there is a fixed background space with respect to which one can say waves propagate, but when what propagates is the very curved spacetime is hard to see what can be the reference for that motion.
Maybe someone can clarify this point?
Picture a balloon filled loosely. Tap it and wave motion will propagate. To a 2-d being living in the balloon surface, you have ripples of geometric distortion. That the balloon is embedded in 3-space in inconsequential (esp. for 2-d being). Generalize this analogy to 4-d.
Also, I seem to recall MTW has a long section on how an array of spaceships would perceive a passing gravitational wave. I don't have time right now to find the section number.
There are several problems I have to generalize it to 4-d:
First, the perturbation in this picture comes from the ambient 3-space and needs an ambient time but in the real case an ambient 5-space is not the source of the perturbation, instead the perturbation arises within the 4-spacetime manifold.
Also the main difference with an actual metric (curved 4-spacetime) perturbation is that in the case of the balloon the wave motion propagates as a function of ambient time that is not part of the perturbation but a parameter, so the 2-d beings living in the surface are able to perceive the tap because time is not included in the geometrical perturbation but is the reference wrt which the motion is perceived.
The same happens when we perceive a sismic wave, which is 3-d wave motion wrt time, not a 4-d perturbation like in the case of GW where is curved spacetime what is supposed to propagate.
The curvature as expressed by the Weyl tensor.
Right, that is where my doubt enters, since curvature includes the spacetime, with respect to what does curvature oscillate? It would seem as if another dimension was needed as reference for spacetime curvature to oscillate. Or how else would we notice that the geometry of our universe (the curvature) is oscillating?
For instance, we notice that the universe is expanding because it is only the spatial part that is expanding wrt time. If spacetime (both space and time) expanded we wouldn't be able to notice.
TrickyDicky said:
Right, that is where my doubt enters, since curvature includes the spacetime, with respect to what does curvature oscillate? It would seem as if another dimension was needed as reference for spacetime curvature to oscillate. Or how else would we notice that the geometry of our universe (the curvature) is oscillating?..
Just a layman on this topic, but isn't it so curvature is detectable (in principle - there is no direct proof to date) as effect of gradient, not as 'absolute' value? My main problem with GW's in GR setting is the absurdity imo of there being no assigned value for gravitational energy density in the case of a static gravitating mass, but as a freely propagating disturbance, gravity 'magically' acquires energy density, a la binary pulsar data and it's interpretation. Where is consistency here?
Unless I have it completely wrong, that is not true. Hubble redshift is equivalent to saying the universe was 'slower' (lower clock rate) back then relative to now, no?
