Can Non-Smooth C^1 Knots be Orientable?
  • Level: Graduate
  • Thread starter Thread starter WWGD
30 replies · 5K views
Homework Helper
Hi, hope this is not too simple:
Are ##S^1 ## -knots (meaning homeomorphisms of ##S^1 ## into ## R^3## or ## S^3## , classified under isotopy) that are just C1 - knots orientable? If we were working " in the smooth category " , then we could just say that we can pushfoward the orientation form ##dx## by a diffeomorphism, and the diffeomorphism would give us a nowhere-zero form, which would be positive or negative depending on whether the diffeo. is orientation-preserving or not. But if we don't know if the embedding of the knot is a smooth embedding , can we still guarantee orientability? I think we can say that if ##S^1## is embedded, then it is a submanifold, and submanifolds admit tubular neighborhoods, meaning the normal bundle of the knot is trivial , which implies orientability. What if we only know that the embedding is a homeomorphism, but we do not address issues of degree of smoothness, i.e., we do not know whether the embedding is even ##C^1## , can we determine orientability?
Also: outside of the "smooth category", where we cannot work with differential forms, do we define orientability in terms of the fundamental class (i.e., the generator of the top homology class )? Then I guess we would have to decide whether the map induced in top homology preserves this class ?
Thanks.
I think C^1 suffices because it provides a continuous tangent vector field along the curve.
Thanks, lavinia. Do you have a nice definition of orientable bundle other than having a reduction of the structure group to O(n)? This definition makes sense, in that O(n) preserves orientation, but it does not seem very geometrically understandable.
Sorry about my typos WWGD. I just fixed them.
One definition of orientation for a k dimensional vector bundle is that the bundle of k-frames has a non-zero section. If the bundle is smooth over a manifold then this means that there is a non-zero k form on the bundle, just like in the case of an orientation for the tangent bundle.
This definition just says that one can pick an orientation for each fiber and that these orientations are consistent, that is that locally they vary continuously. The rigorous definition is that in an open ball,U, around any point there should be a bundle isomorphism from [itex]U \times E[/itex] into [itex]\pi^{-1}U[/itex] that is orientation preserving .
Another way to think of orientability of a fiber is to think of its unit sphere as being oriented. If you do not have a Riemannian metric then one can define an orientation as the orientation of a k- simplex that does not intersect the zero section. This is equivalent to choosing a generator of the cohomology group, [itex]H^{k}(E,E-0)[/itex].
Then the compaibility condition is that there is a cohomology class in [itex]H^{k}(\pi^{-1}U,\pi^{-1}U-0)[/itex]
that restricts to the chosen generator of [itex]H^{k}(E,E-0)[/itex] for each fiber above points in [itex]U[/itex].
The advantage of this way of defining it is that the cohomology groups can have different coefficients. With some coefficients the bundle may be orientable while with others it may not. For instance every vector bundle is orientable with Z2 coefficients. The usual way of defining orientability is equivalent to using Z coefficients.
Thanks. lavinia; I was thinking too, about a result that any closed curve without self-intersection living in a manifold is embedded. It seems little can go wrong with a one-dimensional subspace that does not intersect itself. But I can't think of a proof right now. Of course, C^1 does not guarantee that there is no self-intersection either.
I am not sure what embedding means but whenever you have a continuous bijection of a compact set onto a Hausdorff space it is a homeomorphism.The closed curve without intersection is a continuous bijection of the circle into the manifold which is a Hausdorff space and so is a homeomorphism onto its image( with the subspace topology). Is that what you mean?
BTW: What are you studying?
Thanks; good idea, the continuous bijection between compact+Hausdorff pulls you out of a lot of difficult places.
I'm doing some work on contact submanifolds of 4-manifolds, and some Lefschetz fibrations with open books.
I'm hoping to put it together towards a thesis soon. Thanks for your feedback; it's helped me clarify my ideas.
Hey, lavinia, I think this works, tho it is not geometrically too nice: I think a homeomorphism (the knot being a homeomorphic copy of ## S^1 ##) would send the top homology class of an orientable manifold ( the fundamental class ) , to the fundamental class. Doesn't a homeomorphism induce an isomorphism in homology?
Yes. There are actually much weaker conditions (like weak equivalence) that induce isomorphisms on homology.
WWGD said:
I think this (set of maps that induce an isomorphism in homology ) is a group; the Torelli group.
This is definitely false in the topological and homotopy categories. The problem is that weak equivalences in general have no homotopy inverse (although in the CW category they do). Yet they certainly induce isomorphisms on homology.
jgens said:
This is definitely false in the topological and homotopy categories. The problem is that weak equivalences in general have no homotopy inverse. Yet they certainly induce isomorphisms on homology.
Yes, my bad; I was thinking of the subgroup of the mapping class group that induces the identity
on homology; not the ones that induce isomorphisms. I deleted my previous answer after you saw it, sorry.
No worries. We all make mistakes sometimes and quickly realize the error.
It is true that a homeomorphism induces an isomorphism of homology groups but when you embed one manifold in another the induced map on homology may be zero. For instance, if you embed a circle as the boundary of the closed disk. Any knot in Euclidean space is homologous to zero because Euclidean space has zero homology except in dimension zero.
In your case, there is a homeomorphism of the circle onto a submanifold of Euclidean space. In Euclidean space theis submanifold's homology classes are all zero.
But is this also the case for the top homology (when embedding ## S^1 ## in Euclidean n-space)? I agree the circle embedded as the boundary of
a disk is (n-1)- homologous to zero (i.e., its (n-1)-st homology is zero), since it bounds the disk. But I think this is not so for the top homology, when embedding in Euclidean n-space since an n-knot cannot bound an (n+1)-submanifold. Still, there are no ## S^1## knots in ## \mathbb R^n ## beyond ## \mathbb R^3 ## ; there is enough space to uknot everything , tho I don't have a good proof of this last (only for n=2, we have Schoenflies, but Schoenflies does not hold for n>2, I'm pretty sure; for n=3, there is the Alexander Horned Sphere).
But it's a good point. I guess, e.g., on a torus you can have meridians or parallels as homologically non-trivial embeddings of ##S^1 ## , and non-meridional , and in general loops that are neither homologous to merdians nor homologous to parallels ( whose removal disconnects the torus) as cases where the inclusion induces the zero map in homology.
I wonder if the definition of submanifold I'm familiar with implies that a submanifold is oriented -- ##N^n ## is a submanifold of ##M^M## ; (## n \leq m ##) if N is embedded in M like ## \mathbb R^n ## is "standardly-embedded" in ##\mathbb R^M## , (meaning ## (x_!,x_2 ,..,x_n) \rightarrow (x_1,x_2,..,x_n,0,0,..,0)##) i.e., there are subspace charts ## (U_i, \phi_i) ## for ## N^n ## with ## \phi_i(U \cap N)=(x_1,x_2,..,x_n,0,..,0)## . But I may be wrong, since this seems to be almost precisely the way the projective spaces are embedded in higher-dimensional ones; no cells beyond a certain dimension.
Nah. Your definition (that of an embedded submanifold) does not imply orientability. Another standard definition (that of an immersed submanifold) is strictly weaker and the primary difference is that the topology on your submanifold may actually be finer than the subspace topology.
Well, yes, I guess we first need to make sure the submanifold is embedded to talk about orientability, so that the manifold is a subspace.
Euclidean space has zero homology in all dimensions greater than zero. So the top homology class of an embedded submanifold is zero.
Not every manifold can be oriented. But every manifold (compact) can be embedded as a submanifold of Euclidian space. For instance, the Klein bottle and the projective plane can both be embedded in Euclidean 4 space but neither can be oriented.
What does this have to do with orientability of the manifold?
All that you need is an immersion to talk about orientability.
Suppose f: M ->N is an immersion and that N is oriented. Let E denote the tangent bundle of N
Then the induced bundle, f*(E), over M splits into a Whitney sum of the tangent bundle of
M and the normal bundle to the immersion. Suppose that the normal bundle can be oriented - which for instance will be true if it is a trivial bundle. Then M can also be oriented using the orientation of N and the orientation of the normal bundle.
Both the orientability of N and the normal bundle to the immersion are required. A counterexample would be any unorientable n manifold that is the boundary of an n+1 dimensional manifold. For example, the Klein bottle is the boundary of a 3 manifold. The normal bundle of the bounding manifold is always orientable because it is always a trivial line bundle. This is true because on the boundary, the idea of an inward pointing direction is well defined.
So the 3 manifold that the Klein bottle bounds is itself, non-orientable.
Nothing. I was just pointing out to WWGD that the two "standard" definitions of embedding in manifold theory in no way imply orientability.
Yes, sorry, I meant that I was looking for different definitions used of what a submanifold is, and together with that, additional conditions that would guarantee orientability of t6he submanifold. Of course one can define orientation of a subspace S without S being a submanifold, but the goal of the thread was precisely to study the interplay. There are other definitions of submanifold I have seen , which include/entail the existence of a tubular neighborhood, so that S is orientable.
Clearly, being a submanifold in the sense I described is not enough, because of the examples I, and I think lavinia gave here: odd-dimensional projective spaces embedded in even-dimensional ones; pretty sure the lower-dimensional ones satisfy the definition I gave of orientability, since , e.g., we can express these lower projective spaces without having cells in higher dimensions. At any rate, I think I found an additional condition needed for S to be orientable: S being compact. Then the Tubular 'Hood Theorem kicks in, and we can guarantee orientability, having a nowhere-zero continuous normal vector field.
And this is a good point, because it shows that "embeddability" does not imply orientability, as you said, re the case of the Klein bottle. But I was referring to other definitions; that of being a submanifold, which is defined differently in different sources, one definition implying the existence of a tubular 'hood, which w
Re homology, I agree with you except for the top-dimensional case; I agree that if we had non-trivial ## H^{n-k} (S;\mathbb Z )## for S embedded in ## \mathbb R^n ##; k>0 integer, that this would imply that there is a non-trivial cycle in ## \mathbb R^n ## . But for the top homology, being non-zero does not mean the existence of a non-trivial cycle; it only means ( in the case of a simplicial complex) , that the higher-dimensional complex can be given a coherent orientation; the generator of the top homology in this case is the formal sum ( as a union ) of the boundaries of the top-dimensional simplices. This is not a non-trivial cycle, since there aren't , by construction, any higher-dimensional objects that the subspace can bound, so this does not imply the existence of non-trivial cycles in ## \mathbb R^n ##.
This is not quite right. For example the n-sphere embeds in Euclidean space of dimension n+1 and has non-zero top homology. I assume you mean that the induced map Hk(M;Z)→Hk(Rn+1;Z) is zero for all k > 0. That seemed to be the point you were making earlier at least.
Just a quick note that you can actually remove the compact hypothesis in the embedding theorems (as long as we assume our manifolds are Hausdorff and second countable).
There is a technical condition (that I never can remember) guaranteeing that an embedded submanifold has a tubular neighborhood. The one easy case I do remember is that an embedded submanifold (without boundary) of Rn has a tubular neighborhood. Since every nonorientable manifolds embeds in some Euclidean space, and therefore has a tubular neighborhood, this condition is clearly not enough for orientability. The idea lavinia mentioned about orientability of the normal bundle is good. Use that instead.
Again this does not work. Any nonorientable compact (without boundary) manifold embeds in some Rn and has a tubular neighborhood. So these conditions are not sufficient.
The other point worth mentioning is that noncompact manifolds can be orientable. You probably knew this already, but in light of the comment that an additional condition needed for orientability is compactness, I figured it best to at least make a note.
Again for manifolds embedding in Rn this notion of submanifold coincides with embedded submanifolds.
This is crazy talk. The n-sphere Sn embeds in Rn+1 and Hn(Sn;Z) = Z but this in no way implies the existence of non-trivial homology in Rn+1. In the event you really meant cohomology for your statement above a slightly different choice of sphere will provide you with the desired counter-example in that case as well.
For any manifold M embedded in Rn+1 its (n+1)st homology group vanishes. When dim M < n+1 this is trivial. There are lots of direct arguments establishing this or one could just appeal to Poincare duality instead. When dim M = n+1 and M is without boundary the invariance of domain theorem guarantees that M is an open subset of Rn+1. Note that M can be written as a countable union {Uk} of open balls in Rn+1. By a Mayer-Vietoris argument any finite union of these open balls has trivial (n+1)st homology. Now these open balls give us a natural filtration of M (by taking finite unions) and since homology commutes with colimits on filtered spaces this means that (n+1)st homology group of M vanishes. Alternatively one could appeal to a general theorem stating saying noncompact manifolds of dimension n+1 have trivial (n+1)st homology group. The case when M has boundary is now an easy consequence of the work above.
jgens:
You should read what I wrote more carefully: I said that the implication does _not_ hold for top homology, i.e., an orientable n-manifold has top homology Z ( with Z as coefficient ring ). So
my "crazy talk" comes from your crazy (mis)reading. I even elaborated on why this is not so.
Besides: what do you mean by "non-compact manifolds can be orientable"? I never claimed that compactness
is necessary. I thought it (together with being a submanifold) was sufficient , but, e.g., the Whitney Embedding Theorem shows otherwise, by , e.g., embedding even-dimensional projective spaces, the Klein Bottle, etc.
And I think the condition that guarantees the existence of a tubular 'hood is a version of the inverse function/
implicit function theorem.
First I want to note that an orientable n-manifold has top homology Z if and only if it is compact. If you assumed the compactness part in your statement then you are all good. In any case the "crazy talk" remark was directed at your statement:
As I mentioned before this is clearly false. Spheres are embedded in Rn and provide examples with nontrivial (co)homology in the range you mentioned, but they do not imply the existence of non-trivial cycles in Rn. Perhaps you meant something else, but I responded to what you wrote quite literally. My reading seems fine.
Besides: what do you mean by "non-compact manifolds can be orientable"? I never claimed that compactness is necessary.
You mentioned that another condition needed was compactness. This makes it sounds like a necessary condition. I assumed you knew otherwise, but felt it best to include a remark to make sure.
WWGD said:
And I think the condition that guarantees the existence of a tubular 'hood is a version of the inverse function/implicit function theorem.
No. The condition I am thinking of concerns boundaries. I think the statement is that every embedding f:(M,∂M)→(N,∂N) has a tubular neighborhood. In other words we just need the boundary to map into the boundary.
What do you mean by spheres having non-trivial homology ( I don't know enough about cohomology, other than some basics, like Poincare duality) , but AFAIK, the homology of ## S^n ## is zero for dimensions different from n . Still, the IFTheorem is not necessary here, but I believe it is sufficient; you may get the tubular neighborhood by different means. The claim about compactness was within a different context; not a general one.
Anyway, thanks to both; this exchange has helped me clarify some ideas; sorry if I have been sloppy at times.
WWGD said:
What do you mean by spheres having non-trivial homology ( I don't know enough about cohomology, other than some basics, like Poincare duality) , but AFAIK, the homology of ## S^n ## is zero for dimensionas different from n .
Non-trivial means it has homology different than the homology of a point. And the homology of Sn is Z in dimensions 0,n and is 0 otherwise.
O.K, you got me; it is true for dimension 0 , since it is connected, so I should have stated for 0,n. Here again, the 0-th condition only has to see with basic connectedness, path-connectedness issues. Can you find some embedded n-submanifold with non-zero homology in the range {1,2,..,n-1}?
