blaziken's_charizard
- 33
- 0
1. I have to study for a test. To prepare to study, I decided to look around in my bookshelf for textbooks and to my surprise, found an old handout. I've typed out the questions and my response (answer) to those questions as itactalized. Please feel free to correct/help me :)
PS: Ignore grammatical erros as I've typed it out in a hurry after finding it.
2. The attempt at a solution:
SECTION A- Please tell me which is corect/incorrect and please sugest/help me to correct my wrongs.
1. A car is traveling on a level road. The driver has to stop quickly. Which of the following has the greatest effect on the stopping distance
a. The kinetic energy of the car
b. The potential energy of the car
c. The straightness of the road
d. How far the driver can see
2. Which of the following depends on the atmosphere exerting a pressure
a. A ball falling from the ground
b. Drinking through a straw
c. The spray from a can of cola
d. Bath water emptying down a plug hole
3. A ball attached to a string is whirled round at a constant speed in a horizontal circle. Is it true to say that
a. The velocity is constant
b. They are no forces acting on the body
c. The motion is accelerated
d. If the string breaks the ball drops vertically downwards
4. If an object has kinetic energy, then it must also have
a. Acceleration
b. Force
c. Momentum
d. None of the above
5. Two forces of magnitude 8N and 6N act on the same body at right angles to each other. The magnitude of the resultant of the force is
a. 7N
b. 10N
c. 14N
d. 48N
6. A wire is stretched by a load to a point beyond its elastic limit. It follows that
a. The wire will break if the load is increased any further
b. If the load is removed the wire will resume its original length
c. The extension will no longer be proportional to the load
d. The wire cannot be extended any further if the load is increased
7. A rock of mass 2kg falls 125m form a cliff top into the sea. Its momentum just before it hits the water is
a. 20 kg m/s
b. 50 kg m/sc. 100 kg m/s
d. 200 kg m/s
8. As a brick falls to the ground, it
a. Loses potential energy and gains kinetic energy
b. Loses kinetic energy and gains potential energy
c. Gains both kinetic and potential energy
d. Loses both kinetic and potential energy
9. A mass M moving in a straight line with velocity v1 collides with a stationary mass m, and sticks to it. They continue to move in the same straight line with velocity v2. The equation from which the correct value of v2 may be obtained is
a. Mv1 = mv2
b. Mv1 = (M+m)v2
c. ½ Mv12 = ½ mv22
d. ½ MV12 = 1/2mv22
10. A small marble of mass 10g is dropped form a height above a floor. After striking the floor, the marble rebounds to a height of 1m above the floor. The kinetic energy of the marble just after striking the floor is
a. 0.02J
b. 0.1J
c. 0.2J
d. 20J
11. An electric drill fitted with a blunt bit is used in an unsuccessful attempt to drill a hole through a steel plate. The energy changes involved are best summarized by
a. electrical kinetic heat/internal energy
b. electrical heat/internal potential
c. kinetic electrical potential
d. kinetic potential heat internal
12. The relationship between the volume and the pressure of a fixed mass of gas at constant temperature is called
a. The kinetic theory
b. Boyle’s Law
c. Charles’ Law
d. Pressure Law
13. Which of the following statements about temperature is not true
a. It represents the amount of heat contained in a body
b. It is a measure of the degree of hotness or coldness in a body
c. It is a property which determines the direction of heat flow in a body
d. It measure the average kinetic energy of the particles of which matter is composed
14. Which of the following scientists provided quantitative evidence for the law of conservation of energy
a. Einstein
b. Joule
c. Newton
d. Rumford
15. A detector of thermal energy is placed an equal distance in turn form each of the four faces of a hollow metal cube full of water. the reading on the detector is the greatest when the detector is turned to the face which is
a. painted silver
b. painted shiny white
c. painted dull black
d. highly polished
16. When illuminated smoke is viewed through a microscope, small bright specs can be seen moving in a jerky haphazard manner. These specks are
a. atoms
b. molecules
c. smoke particles
d. light particles
17. Which of the following is not implied by the kinetic theory?
a. The internal energy of a gas depends only on the gas temperature
b. The pressure of a gas is caused by the gas molecules bombarding the containing surfaces
c. The volume of the particles is negligible
d. They are strong intermolecular forces between two molecules in a gas
18. According the kinetic theory, what is the pressure of an ideal gas at absolute zero
a. 1atm
b. 760mmHg
c. 101.3 kPa
d. 0 mmHg
19. Heat is transferred from the sun by
a. Conduction
b. Convection
c. Radiation
d. All of the above
20. A 0.460Kilowatt water heater is used to boil water. Assuming no thermal energy loss, what mass of steam will it produce in 10minutes. The Specific latent heat of vaporization of water is 2300000J/kg
a. 105800000000J
b. 6348000000000J I THINK THIS WAS AN ERROR, A ‘0’ IS SUPPOSED TO BE REMOVED?
c. 6348000000J
d. 105800000J
21. Geiger and Marsden were student of who?
a. Thompson
b. Rutherford
c. Bohr
d. Dalton
22. Which of the following would be true of the Geiger Marsden experiment – (I) it established that an atom has a positively charged nucleus, (II) it demonstrated that alpha particles are positively charged, (III) it shows that alpha particles were never deflected
a. I only
b. I and II only
c. II and III only
d. I II and III
23. Which of the following statements about eh expression E = mc2 is true? (I) it defines the maximum energy light can have, (II) it represents the fact that mass can be converted into energy, (III) it represents one of the major achievements of Rutherford
a. II only
b. I and II only
c. II and III only
d. I, II and III
24. Which of the following may be used to define the term half-life. (I) it is half the time required by a nucleus to decay, (II) it is the time for half the nuclei of a sample to decay, (III)it is the time for an activity of any random process to fall to one half its original value>.
a. I only
b. I and II only
c. II and III only
d. I, II and III only
25. Which of the three types of radiation carry’s an electric charge
a. alpha and gamma
b. Beta
c. Alpha and beta
d. Beta and gamma
26. An alpha particle is
a. A proton
b. A helium atom
c. A helium nucleus
d. An electron
27. Which of the following uses radioactive cobalt – 60
a. Tracers
b. Radiotherapy
c. Carbon Dating
d. The Dating of Rocks
28. Which of the following isotopes of Carbon is used in Carbon dating
a. 147C
b. 146C
c. 126C NOT SURE WHICH ONE, IF ANY AT ALL! PLEASE HELP
d. 127C
29. Which of the following contributes the most to Background radiation
a. Radon gas from ground COMPLETE GUESS, NOT SURE
b. Buildings
c. X-Rays
d. Nuclear Waste
30. Which of the following is the most dangerous to living organisms
a. alpha
b. beta
c. gamma
d. they are all equally dangerous
SECTION B- please tell me if I'm correct/incorrect and also feel free to help/suggest for my wrongs.
1. In a vacuum, a feather will not fall at the same rate as a stone FALSE
2. Free Fall and The Pendulum Swing are not the only methods that can be used to determine the value of gravity..FALSE
3. The equation s = ½ (v + u)t is not an accurate equationTRUE
4. If a body is project horizontally off of a cliff the horizontal distance is equal to the distance it would have traveled if on a straight planeFALSE, NOT SURE
5. The equation E=mc2 invalidates the law of conservation of massFALSE
6. A stiletto heel shoe will cause more damage to a polished floor than a flat heelTRUE? NOT SURE, LOL.
7. The potential energy and 1/3 height is equal to the kinetic energy at 4/6 heightFALSE..EH?
8. The mercury in glass thermometer can be used to measure bother very high and low temperaturesFALSE..NOT SURE
9. The Higher the specific heat capacity of a substance, the longer it will take to change its temperatureTRUE...EH?
10. Both evaporation and boiling of a liquid involves a change in temperatureFALSE
Even though I might not have said that I am not sure, please tell me which questions are correct/incorrect. Thanks alot
a. Acceleration
b. Force
c. Momentum
a. 7N
b. 10N
c. 14N
d. 48N
a. 20 kg m/s
d. 200 kg m/s
a. Mv1 = mv2
b. Mv1 = (M+m)v2
c. ½ Mv12 = ½ mv22
d. ½ MV12 = 1/2mv22
a. 0.02J
b. 0.1J
c. 0.2J
d. 20J
b. Boyle’s Law
c. Charles’ Law
d. Pressure Law
a. Einstein
b. Joule
c. Newton
d. Rumford
a. painted silver
d. highly polished
a. atoms
b. molecules
c. smoke particles
d. light particles
a. 1atm
b. 760mmHg
c. 101.3 kPa
d. 0 mmHg
a. Conduction
b. Convection
c. Radiation
d. All of the above
a. 105800000000J
c. 6348000000J
d. 105800000J
a. Thompson
b. Rutherford
c. Bohr
d. Dalton
a. I only
b. I and II only
c. II and III only
d. I II and III
a. II only
b. I and II only
c. II and III only
d. I, II and III
a. I only
b. I and II only
c. II and III only
a. alpha and gamma
b. Beta
c. Alpha and beta
d. Beta and gamma
a. A proton
b. A helium atom
c. A helium nucleus
d. An electron
a. Tracers
b. Radiotherapy
c. Carbon Dating
a. 147C
b. 146C
d. 127C
b. Buildings
c. X-Rays
d. Nuclear Waste
a. alpha
b. beta
c. gamma
