Can Quaternions Revolutionize Quantum Mechanics?
  • Context: Graduate
  • Thread starter Thread starter Karl G.
    Qm Quaternions
The discussion explores the potential application of quaternions and octonions in quantum mechanics (QM), examining both theoretical implications and practical challenges. Participants consider historical uses, mathematical properties, and the feasibility of integrating these mathematical structures into quantum theories.
  • Some participants propose using quaternions in QM, questioning why octonions are not also considered.
  • Others argue that quaternions do not simplify quantum mechanics and highlight the lack of a tensor product definition for quaternionic Hilbert spaces, which complicates multiparticle system descriptions.
  • A participant references a theorem stating that quantum logic axioms can only be satisfied in Hilbert spaces over real, complex, or quaternionic numbers, excluding octonions.
  • Some contributions mention historical uses of quaternions in physics, including Maxwell's work on electromagnetism and their application in geometric algebra.
  • Concerns are raised about the noncommutativity of quaternions and its implications for defining probability densities and wavefunctions in QM.
  • Participants discuss the potential advantages of quaternions in certain contexts, such as their relationship with Clifford algebras and their representation in differential geometry.
  • Some suggest that the complexity and notation associated with quaternions may limit their practical use in physics.
  • There are mentions of ongoing research and the need for further exploration of quaternionic field theories and their applications in quantum mechanics.
Participants express a variety of views on the relevance and utility of quaternions and octonions in quantum mechanics, with no consensus reached. Some see potential benefits, while others highlight significant challenges and limitations.
Limitations include unresolved mathematical steps regarding the tensor product of quaternionic Hilbert spaces and the implications of noncommutativity on quantum mechanical formulations.
This discussion may be of interest to physicists, mathematicians, and researchers exploring advanced mathematical frameworks in quantum mechanics, as well as those studying the historical context of mathematical physics.
Karl G.
Has anybody ever thought of using quaternions in QM? If so, why stop there? WHy not use octonions, etc. ? Just curious ...
I just recently ran across a http://arxiv.org/abs/hep-th/0607121" on that matter by Charles Schwartz (a Berkeley prof emeritus).
It's mostly a novelty, I think. It doesn't really make sense to do so unless it simplifies things, which it doesn't appear to.
There is a famous theorem, which says that axioms of "quantum logic" can be satisfied only in Hilbert spaces over R (real numbers), C (complex numbers) and Q (quaternions)
C. Piron, "Foundations of Quantum Physics", (W. A. Benjamin, Reading, 1976)
Octonions are not in this list. Nevertheless, there were attempts to build octonionic QM. See, for example,
http://arxiv.org/PS_cache/hep-th/pdf/9609/9609032v1.pdf
and references there.
Real and quaternionic QM were also investigated:
E. C. G. Stueckelberg, "Quantum theory in real Hilbert space", Helv. Phys. Acta, 33 (1960),
727
J. M. Jauch, "Projective representation of the Poncare group in a quaternionic Hilbert space",
in Group theory and its applications, edited by E.M. Loebl, (Academic Press, New York, 1971).
However, as far as I know, nothing exciting came out of that. The main problem with quaternions is that it is not possible to define the tensor product of two quaternionic Hilbert spaces. So, the description of multiparticle systems is questionable.
Why is that? (Is it explained in one of the references you mentioned? - I don't have Piron.)
Cheers.
Quaternions show up in physics whenever they make your life easy, which is relatively infrequently b/c of notation clutter. They show up from time to time when dealing with clifford algebras (so spinors and fermions), division algebras and so forth. I am unaware of a physical context where they absolutely must be used over anything else.
Quaternionic Quantum Mechanics and Quantum Fields by Stephen L. Adler,
https://www.amazon.com/dp/019506643X/?tag=pfamazon01-20.
Adler gives his answer in section 2.7 Nonextendability to Octonionic Quantum Mechanics.
It's been over ten years since I looked briefly at this book; I forget what's in it.
Cheers.
This is related to the non-commutativity of quaternions. I don't remember exact arguments now, and I don't have good references. The best thing would be to search the web for "quaternionic" "quantum mechanics" "tensor product". It yields a number of hits that look useful.
Yes, definitely the noncommutivity of quaternions would pose a problem, not to mention defining probability densities, wavefuctions, etc... Although the noncommutativity could shine some light on operators, (but then, the Hilbert space problem would come up again) I guess it would be generally infeasible. Thinking farther, complex numbers are open to a more 'natural' interpretation than quaternions, octonions, etc. (see for exp. Nahin's interesting book "Imaginary Tale: The History of the square root of -1"), so maybe this could partly explain my problem
I realize this thread is a bit old, but I would like to draw your attention to something related to quaternions and that is Geometric Algebra. You might be interested in the book Geometric Algebra by Chris Doran and Anthony Lasenby. Geometric algebra actually is one of the Cliffird algebras and quaternions fall under that heading as well. Doran and Lasenby give the details. David Hestenes and others have done a lot of work, with some success, in applying Geometric Algebra to quantum mechanics.
James Clerk Maxwell originally used quaternions in his work on Electromagnetism but there was a dispute/difference of opinion regarding their use that led him to use vectors later on. As Dr. David Hestenes points out in his many writings on Geometric Algebra and Geometric Calculus, quaternions have been popping up in quantum mechanics for many years but often disguised as matrices and spinors etc. so they were not recognized as quaternions.
You will find that there are several physicists that are using quaternions in their work. For example, Dr. Mendel Sachs used quaternions in his research program as a common mathematical language in which to write both Quantum Mechanical and General Relativistic equations (See "Quantum Mechanics from General Relativity") .
Another physicist that is using quaternions is Doug Sweetser (http://world.std.com/~sweetser/quaternions/qindex/qindex.html).
The authors of "The Vector Calculus Gap" have a paper on Octonions and the Standard Model (http://fqxi.org/large-grants/awardee/details/2008/dray)
I highly recommend approaching quaternions from the Geometric Algebra/Geometric Calculus side to avoid some of the problems cited by Dr. Hestenes with redundancy of formalisms in mathematical physics.
Thanks for the links!
To me it seems EM should be with Quaternions and only if you write at as components, it become vectors. Don't quaternions have a shorter notation?
Quaternions not having commutivity isn't as big as a problem as it sounds - neither do vectors and cross products. However, each "generation" of complex dimensions you add makes you lose additional mathematical properties. For example, octonions aren't associative. This property is one of the biggest reasons why generations beyond quaternions are relatively uncommon. You'd only use octonions (for example) if you actually want loss of associativity.
Imo, i think that quaternions (or more accurately, bivector-valued tensors) provide such a powerful bridge between differential geometry and complex operator theory (see e.g. http://modelingnts.la.asu.edu/html/GCgravity.html ) is because the clifford bivector is the pseudo-complex analogue of the real vector cross product, an anticommutative lie bracket. so every bivector corresponds to a unique topology representable as a traceless matrix (the trace part being the scalar inner product term of a given spinor).
As for multiparticle systems, ...errr...we're working on it. There's not really much support for field theories, partly because the Fourier analysis on clifford algebras is still being researched =). but electrodynamics shows promising results, and I'm doing my part with a bit of interesting new Bayesian theory (to appear in IJTP).
Physicists that think that quaternions are of no importance for quantum mechanics and that instead Clifford algebras must be used have never considered the effect of a quaternion waltz ab/a. This is in general not equal to b. b is precessed! (a part of b is rotated). The combination of a unitary transformation and an observation already involves a quaternion waltz. Physicists that stick to complex QM will never notice this effect. If you analyse it then you will encounter the source of relativity!
Ever heard of 2n-ons? See http://www.math.temple.edu/~wds/homepage/nce2.pdf
For Hilbert space on octonions see Horwitz : http://arxiv.org/abs/quant-ph/9602001
If you specify a Hilbert space over the quaternions, then that should not withhold you of using higher 2n-ons as eigenvalues of operators. How else would you get all fields represented in the action S, which according to Dirac appears in the argument of a 'unitary' transform?
The pairwise products of the Pauli matrices are basically the unit quaternions:
[tex]\mathbf{i} = \sigma_2 \sigma_3[/tex]
[tex]\mathbf{j} = \sigma_3 \sigma_1[/tex]
[tex]\mathbf{k} = \sigma_1 \sigma_2[/tex]
So technically speaking, quaternions show up in the theory of angular momentum; however, physicists prefer the matrix notation.
  • · Replies 63 ·
9K
  • · Replies 26 ·
