Can Six Pencils Be Arranged to Each Touch the Other Five?
  • Context: High School
  • Thread starter Thread starter bob012345
The discussion revolves around the possibility of arranging six pencils such that each pencil touches the other five. This is framed as a three-dimensional geometric problem, inspired by a puzzle originally posed by Martin Gardner. Participants explore various configurations, assumptions, and potential solutions, while also considering the implications of different pencil shapes and arrangements.
  • Some participants suggest that the problem requires a three-dimensional arrangement, noting that a solution is impossible if all pencils are confined to a single layer.
  • There is a proposal that the pencils must be unsharpened, similar to cigarettes, to facilitate touching.
  • Several participants express skepticism about certain proposed solutions, arguing that the slope of the arrangement may prevent all pencils from touching.
  • One participant describes a potential non-planar structure that could allow all pencils to touch, but raises concerns about the convergence of adjustments made to achieve this configuration.
  • Another participant introduces a naming convention for angles in a proposed geometric arrangement, emphasizing the importance of symmetry.
  • Some participants mention the need for a more rigorous mathematical solution, suggesting that linear algebra might be useful due to the constraints involved.
  • There are claims of testing proposed solutions with real pencils, leading to observations of gaps that suggest not all pencils touch as required.
  • One participant references an article discussing solutions for seven pencils, indicating that complex computations are necessary for finding solutions to higher numbers of pencils.
Participants express a mix of agreement and disagreement regarding the feasibility of certain solutions. While some believe that a non-planar arrangement could work, others remain unconvinced and point out gaps in proposed configurations. The discussion does not reach a consensus on the validity of any specific solution.
Participants note that the original puzzle involved round cigarettes, while the adaptation to pencils introduces additional considerations regarding shape and contact points. The complexity of the problem is compounded by the three-dimensional nature of the arrangement and the potential for non-parallel configurations.
bob012345
TL;DR
Is it possible to arrange six pencils such that each one touches the other five?
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Mathematics news on Phys.org
Unsharpened pencils (like cigarettes), I presume.
This is a three dimensional problem. There is no solution if all six pencils occupy only one layer.
The source:
https://puzzleaday.wordpress.com/2022/11/23/six-pencils-all-touching/
I failed, and had to cheat. So there was no point in me responding and ruining the puzzle.
bob012345 said:
Did you figure this yourself before searching for the answer online?
No, I did not. Sorry for the spoiler bar.
By the way, there is another solution which can also be found by using Google.
In my opinion, this solution is not correct. What do others think?
I think you're right.
The slope prevents certain pencils from being touched.
I don't see why it would be incorrect.
Each pair of pencils is not 100% parallel in 3 dimensions, even though it may look like they are. They will be very slightly askew and only touch near their centres. This allows them to be in contact with two other pencils at each end.
Put another way, this structure might not work on a flat surface, where the four bottom pencils are fully in contact with the surface along their entire lengths. But it could be glued together so that all six touch each other; it just wouldn't sit flush with the four bottom pencils lying flat on the surface. It would rock a tiny bit.
You can edit your original answer so that anyone can see the solution if they click on the “spoiler” button.
Hidden content goes here
Below I misspelled it so you can see the code.
[SPOILERR]
[/SPOILERR]
There are other ways to solve this. Can anyone find different solutions for six pencils? Also, can it be done with seven?
Yes, my first guess. But then I thought:
And then:
Now I'm pretty confused. My intuition says it will work as a non-planar structure. But, every time you move a pencil to close the gap at a vertex, you change another vertex, creating another error to fix. Does this process converge? It seems like it ought to.
This sort of 3-D geometry hurts my brain, I'm not very good at these. Since I can't afford a Solidworks license, I may need to get 6 pencils...
BTW, in case anyone wants to use their brain and not glue. Let's make a naming convention. This is mine:
- Equilateral triangle, because symmetry is our friend.
- Each side of the triangle is named 0o, 120o, or -120o. I wouldn't complain if you shortened this to 0, +, or -.
- Each leg of the triangle has inner and outer pencils. So, a pencil could be labeled "Inner 120o", or "I+".
I'd vote to give you a fields medal if you could find all of the angles without computers or protractors.
And then:
Glueing a gap in my mind is not a solution since these are mathematical pencils.
Of course. But it means you're really close to a solution. Maybe pretend that your mathematical pencil has a diameter of pencil plus glue thickness. Caulking would definitely be cheating.
The original puzzle was for round cigarettes. I changed it to pencils but I realize some pencils are hexagons. One edge could be higher than another for two adjacent pencils but I think this is not in line with the spirit of the puzzle.
Somehow I knew I would end up with this. Now I'm 99.9% sure it works.
Plus (bonus!) I used up some of the very many old broom sticks I am compelled to save. Also, I avoided painting my bathroom for at least an hour.
  • Haha
I’m not convinced they all touch.
It would be nice to have a more rigorous solution. Maybe some linear algebra since there are so many constraints?
I can tell you that the solution in the Martin Gardner book matches the solution in post #3 above but hints there are others.
Here are 2 solutions with 7 infinite cylinders.
https://www.sciencedirect.com/science/article/pii/S0925772114000819
Major computation is needed to find solutions of 20 non-linear equations with 20 variables.
The only thing in that article that's easy, is that if you have 2 parallel infinite pencils, the maximum number is 4, so the solution from Gavran in post #6 with two pencils on the table, next to each other can't work.
I tested "solution" #6 with real pens and can confirm that they don't all touch each other.
There's a small, visible gap. And I can slide a piece of paper into it.
Here is Martin Gardner’s solution for 7 which also is a solution for 6 along side his original solution for 6.
Remove #7 and it is a different solution for 6 pencils.
"The case of parallel cylinders (lines) is excluded from our analysis. It is left to the reader to show that if two cylinders are parallel, then the maximum number of mutually touching cylinders is four."
Yes, but that doesn't address the non-planar case where the pencils that look parallel are not, they only touch in the middle. As described in post #8.
And... Version 2. Now I'm 99.9% sure it doesn't work. Although it's hard to show in a photo. The cable ties are a nice easy solution which allows you to slide and rotate the sticks. There's always 1 gap you can't get rid of where an inner stick misses an outer stick (you get to choose which one, of course).
Also, no surprise, the asymmetric configuration with one leg below the other four crossing sticks doesn't work. But it's a lot closer, which surprised me.
Still not painting my bathroom, but I'm rapidly running out of excuses.
Unless you the foresight to cut the sticks from your paintbrush handles. :-p
I think there is no loss of generality by using square pegs which lay flat in the plane. Then the gap would be quite easy to see.
Which plane? No two sticks are coplanar, everything's twisted a bit. Anyway, the gap is easy to see in person, particularly because you can slide and twist things around without improvement. It's just hard to demonstrate here.
Bending, twisting, forcing and distorting the pencils is not allowed. In the original puzzle with cigarettes it was a rule that they could not be bent or distorted to make it work.
I was under the impression that this post: The Secrets of Prof. Verschure's Rosetta Stones was the geekiest thread on the site but this one clearly rivals it. Not only topically but also in enthusiasm and work done. On the other hand there are so many, which is one of the reasons I like this forum so much!
[TONGUE-IN-CHEEK]I still think the site needs a, say, monthly price or mention of the geekiest thread or topic![/TONGUE-IN-CHEEK]
o0)
The question now (nearly 3 months later) is, has @DaveE painted his bathroom yet?
I guess that was an esoteric backhanded compliment directed at me for answering a year-old thread. OTOH I don't think age is an argument for not adding information to a topic. (OK maybe I didn't add much, but you get my drift.) :smile:
  • · Replies 38 ·
13K
  • · Replies 17 ·
