Can square roots be simplified without a calculator?
13 replies · 2K views
littlemathquark
##\sqrt{\dfrac{3^8+5^8+34^4}2} =?##
None
I can't find a short solution without using calculator.
Consider the prime factors of all the components
Oh, that only works if the 3 upper terms are multiplied.
Adding them makes only for a big unwieldy number. Don't see how to simplify it at all.
Ibix said:
Do 3, 5, and 34 (or their prime factors) have any properties in common that might help? Especially helpful if there are terms that might cancel when expanded.
##3^8+5^8+34^4=9^4+25^4+34^4=9^4+25^4+(9+25)^4##
That's all and I'm stuck.
Interesting! Not what I had in mind at all, but it also works.
What do you get if you expand that? I found it helpful to write ##x=3## and ##y=5## so I didn't lose track of my special numbers among all the other ones.
If the expansion is going to help you in this particular problem, what has to be true about it?
This is a good starting point! Just go ahead by this method.
\begin{align*}
3^8+5^8+34^4&=9^4+25^4+(9+25)^4\\
&=9^4+(16+9)^4+(9+16+9)^4\\
&=9^4+(2\cdot 9+7)^4+(3\cdot 9+7)^4\\
&\ldots
\end{align*}
I put ##9^4## out of it and called ##7/9=c## and then ##2+c=25/9=d## and so on. The highest product I finally had to calculate was ##25\cdot 34=25(25+9)=625+225.##
Reply
\begin{align*}
&\ldots
\end{align*}
Sorry I don't understand your solution. Can you give more detail please?
\begin{align*}
&=9^4\cdot (1+(2+c)^4+(1+2+c)^4)\ ,\ c=7/9\\
&=9^4\cdot (1+d^4+(1+d)^4)\, , \,d=2+c=25/9\\
&=9^4\cdot \left(1+d^4+d^4+4d^3+6d^2+4d+1\right)\\
&=9^4\cdot \left(2+2d^4+4d^3+6d^2+4d\right)\\
\dfrac{3^8+5^8+34^4}{2}&=9^4\cdot \left(1+d^4+2d^3+3d^2+2d\right)\\
&\ldots
\end{align*}
The only critical part now is figuring out that ##1+d^4+2d^3+3d^2+2d=1+d^4+d^2+2d^3+2d^2+2d## is a square. I admit, I used WA for it, but more out of laziness.
Vanadium 50 said:
That seems kind of out of the blue.
My starting point would be to replcae 3 with 4-1, 5 with 4+1 and use that to get rid of the 2. Then see what I had left.
That's what I did, additionally noting that ##34=2(4^2+1)##. That gave me a polynomial expression in powers of 4 that can be factorised (and there's an obvious factorisation that we want). OP's approach with ##3##, ##5##, and ##34=3^2+5^2## can be made to work similarly.
Reply
Another solution
$$3^8+5^8+34^4=9^4+25^4+34^4=9^4+25^4+(9+25)^4$$
$$\frac12\left(a^4+b^4+(a+b)^4\right)=\frac12(a^4+b^4+a^4+4a^3b+6a^2b^2+4ab^3+b^4)$$
$$=(a^2)^2+(b^2)^2+(ab)^2+2(a^2b^2+a^3b+ab^3)=(a^2+b^2+ab)^2$$
$$(\forall a,b\in\mathbb{R}$$ $$a^2+b^2+ab\geq0 )$$,
$$\sqrt{\dfrac{a^4+b^4+(a+b)^4}2}=a^2+b^2+ab$$
$$ \sqrt{\dfrac{3^8+5^8+34^4}2}=9^2+25^2+9\cdot25=931$$
Reply
