Asaad-Hamad
- 16
- 2
1. The Big Idea:
According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box.2. How It Works: The Two-Stage Process
Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V.Stage 1: Symmetric Launch
- Inside the craft, we use a spring or magnets to shoot two identical metal balls in opposite directions.
- From inside the craft, everything looks symmetric: both balls fly away at exactly 10 m/s in opposite directions.
- Now, each ball flies into a separate magnetic tunnel. These tunnels are identical and give each ball an identical extra push (a constant force over a fixed distance) in the direction they are already moving.
- According to standard relativity, since the experiment is symmetric from inside the craft, both balls should get the exact same extra speed boost (say, +5 m/s).
- The forward ball is already moving faster: its speed is (V + 10) m/s
- The backward ball is moving slower: its speed is (V - 10) m/s
- The faster (forward) ball zips through quickly.
- The slower (backward) ball takes longer to get through.
- The backward ball gets a larger speed boost.
- The forward ball gets a smaller speed boost.
3. What We Measure:
The experiment looks for three things:- Velocity Difference: A tiny difference in the final speeds of the two balls.
- Timing Difference: A difference in how long each ball was pushed in its tunnel.
- Craft Acceleration: Because the pushes aren’t equal and opposite, the whole spacecraft would get a tiny kick forward.
4. Why This Might Work:
It avoids the usual tricks that hide absolute motion (like time dilation) because it compares two events that happen at the same time and in the same place (inside the lab). It relies on a simple rule: The longer a force pushes, the more speed it adds.5. My Questions for You:
- Feasibility: Is it possible to measure the tiny time differences (probably nanoseconds) this would create?
- Hidden Flaws: What could go wrong? Could magnetism or vibrations accidentally create a false result?
- Interpretation: Does this logic make sense, or have I missed a reason why relativity would still make the outcomes equal?
