Can you prove this trigonometric inequality?
10 replies · 3K views
MarkFL
MHB
Show that :
[math]\left( {\sin x + a\cos x} \right)\left( {\sin x + b\cos x} \right) \leq 1 + \left( \frac{a + b}{2} \right)^2[/math]
Mathematics news on Phys.org
MarkFL said:
Show that :
left side=
[math]\left( {\sin x + a\cos x} \right)\left( {\sin x + b\cos x} \right)\leq \sqrt{1+a^2}\times \sqrt{1+b^2}[/math]
$\leq\dfrac{1+a^2+1+b^2}{2}=1+\dfrac {a^2+b^2}{2}$
Are you sure , right side is correct ?
Albert said:
left side=
Yes, it is correct...it appears you are assuming the two sinusoidal factors are in phase with one another, that is for $a=b$. In this case, then your result is equivalent to that which I gave.
if it is correct then ,we must prove
$\dfrac {a^2+b^2}{2}\leq (\dfrac{a+b}{2})^2=\dfrac {a^2+b^2}{4}+{ab}$
for all $a,b \in R$
${\therefore \dfrac {a^2+b^2}{4}\leq ab}$
how about if ab<0,then it does not fit
for all $a,b \in R$
It appears you are on the right track here, but have made some algebraic errors.
sorry ,I have made some algebraic errors:o
I will try to use another approach
Your errors are quite minor, and in fact leads to a much simpler approach than I have. (Nod)
I think ,I should take a rest ,and have a cup of tea or coffee
for some x,and a,b if left side $\leq 0$
then it holds naturely
now we assume both sides are positive
if a=b then the original inequality holds
if a>b then :$1+b^2\leq left \,\, side \leq 1+a^2$
$1+b^2\leq right \,\, side \leq 1+a^2$
if a<b then :$1+a^2\leq left \,\, side \leq 1+b^2$
$1+a^2\leq right \,\, side \leq 1+b^2$
My solution:
I first expand the LHS of the inequality and get:
$$( {\sin x + a\cos x} )( {\sin x + b\cos x})=\sin^2 x+(a+b)\sin x \cos x+ab\cos^2 x$$
$$\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;=(1-\cos^2 x)+(a+b)\sin x \cos x+ab\cos^2 x$$$$\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;=\frac{ab+1}{2}+\left(\frac{a+b}{2}\right)\sin 2x+\left(\frac{ab-1}{2}\right)\cos 2x$$
Next, by applying the Cauchy-Schwarz Inequality to the part $$\left(\frac{a+b}{2}\right)\sin 2x+\left(\frac{ab-1}{2}\right)\cos 2x$$ yields
$$\left(\frac{a+b}{2}\right)\sin 2x+\left(\frac{ab-1}{2}\right)\cos 2x\le\sqrt{\left(\frac{a+b}{2}\right)^2+\left( \frac{ab-1}{2}\right)^2}\cdot\sqrt{\sin^2 2x+\cos^2 2x}$$
$$\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\le \sqrt{\left(\frac{a^2b^2+a^2+b^2+1}{4}\right)}$$
$$\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\le \frac{\sqrt{(1+a^2)(1+b^2)}}{2}$$Also, AM-GM inequality tells us that
$$\frac{(1+a^2)+(1+b^2)}{2}\ge\sqrt{(1+a^2)(1+b^2)}$$ or
$$\frac{(1+a^2)+(1+b^2)}{4}\ge\frac{\sqrt{(1+a^2)(1+b^2)}}{2}$$
$$\frac{2+a^2+b^2}{4}\ge\frac{\sqrt{(1+a^2)(1+b^2)}}{2}$$Finally, by combining all that we found in the above steps, we can now conclude that
$$( {\sin x + a\cos x} )( {\sin x + b\cos x})$$
$$=\frac{ab+1}{2}+\left(\frac{a+b}{2}\right)\sin 2x+\left(\frac{ab-1}{2}\right)\cos 2x$$
$$\le \frac{2+a^2+b^2}{4}+\frac{ab+1}{2}$$
$$\le \frac{2+a^2+b^2+2ab+2}{4}$$
$$\le \frac{4+a^2+b^2+2ab}{4}$$
$$\le 1+\frac{a^2+b^2+2ab}{4}$$
$$\le 1+\frac{(a+b)^2}{4}$$
$$\le 1+(\frac{a+b}{2})^2$$ (Q.E.D.)
This is my proof:
Let:
[math]A=\tan^{\small{-1}}(a)[/math]
[math]B=\tan^{\small{-1}}(b)[/math]
Using a linear combination, we may write the inequality as:
[math]\sqrt{(1+a^2)(1+b^2)}\sin(x+A)\sin(x+B)\le1+\left(\frac{a+b}{2} \right)^2[/math]
Let:
[math]f(x)=\sin(x+A)\sin(x+B)[/math]
Thus:
[math]f'(x)=\sin(2x+A+B)[/math]
[math]f''(x)=2\cos(2x+A+B)[/math]
Then $f(x)$ has its maxima for:
[math]x=\frac{(2k+1)\pi-(A+B)}{2}[/math] where [math]k\in\mathbb Z[/math]
We then find:
[math]f\left(\frac{(2k+1)\pi-(A+B)}{2} \right)=\sin\left(\frac{(2k+1)\pi-(A+B)}{2}+A \right)\sin\left(\frac{(2k+1)\pi-(A+B)}{2}+B \right)=[/math]
[math]\sin\left(\frac{(2k+1)\pi+A-B}{2} \right)\sin\left(\frac{(2k+1)\pi-A+B}{2} \right)=[/math]
[math]\frac{\cos(A-B)-\cos((2k+1)\pi)}{2}=\frac{\cos(A-B)+1}{2}=[/math]
[math]\frac{\cos(A)\cos(B)+\sin(A)\sin(B)+1}{2}=[/math]
[math]\frac{1+ab+\sqrt{(1+a^2)(1+b^2)}}{2\sqrt{(1+a^2)(1+b^2)}}[/math]
Now, we need only show:
[math]\sqrt{(1+a^2)(1+b^2)}f\left(\frac{(2k+1)\pi-(A+B)}{2} \right)\le1+\left(\frac{a+b}{2} \right)^2[/math]
[math]\frac{1+ab+\sqrt{(1+a^2)(1+b^2)}}{2}\le1+\left( \frac{a+b}{2} \right)^2[/math]
[math]2+2ab+2\sqrt{(1+a^2)(1+b^2)}\le4+a^2+2ab+b^2[/math]
[math]2\sqrt{(1+a^2)(1+b^2)}\le2+a^2+b^2[/math]
[math]4a^2b^2+4a^2+4b^2+4\le a^4+2a^2b^2+4a^2+b^4+4b^2+4[/math]
[math]2a^2b^2\le a^4+b^4[/math]
[math]0\le(a^2-b^2)^2[/math]
