Can Zero Divisors in Polynomial Rings Be Characterized?
13 replies · 3K views · last reply
fishturtle1
Let ##R## be a commutative ring with unity. Let ##p(x) = a_nx^n + a_{n-1}x^{n-1} + \dots + a_1x + a_0## be an element of the polynomial ring ##R[x]##. Prove that ##p(x)## is a zero divisor in ##R[x]## if and only if there is a nonzero element ##b \in R## such that ##bp(x) = 0##. Hint: Let ##g(x) = b_mx^m + b_{m-1}x^{m-1} + \dots + b_1x + b_0## be a nonzero polynomial of minimal degree such that ##g(x)p(x) = 0##. Show that ##b_ma_n = 0## and so ##a_ng(x)## is a polynomial of degree less than ##m## that also gives ##0## when multiplied by ##p(x)##. Conclude that ##a_ng(x) = 0##. Apply a similar argument to show by induction on ##i## that ##a_{n-i}g(x) = 0## for ##i = 0, 1, \dots, n## and show that this implies ##b_mp(x) = 0##.
Proof: ##(\Leftarrow)## Suppose there exists non zero ##b \in R## such that ##bp(x) = 0##. Well, ##R \subset R[x]##, and so by definition of zero divisor, ##p(x)## is a zero divisor. (assuming ##p(x) \neq 0##).
##(\Rightarrow)## Suppose ##p(x)## is a zero divisor in ##R[x]##. Then we can choose a nonzero polynomial of minimal degree ##g(x) = b_mx^m + b_{m-1}x^{m-1} + \dots + b_1x + b_0## such that ##g(x)p(x) = 0##. From the reading, the coefficient of ##x^{m+n}## of ##g(x)p(x)## is
$$ \sum_{k = 0}^{n+m} a_kb_{n+m-k} = a_nb_m$$
since for ##k > n## we have ##a_k = 0## and for ##k < n## we have ##b_{n+m-k} = 0##. Since ##g(x)p(x) = 0## we can conclude ##a_nb_m = 0##, I think? Now, ##\deg a_ng(x) < \deg g(x)## and ##(a_ng(x))p(x) = a_n(g(x)p(x)) = a_n\cdot 0 = 0##. This implies ##a_ng(x) = 0## since it has degree less than ##g(x)## and thus is not a zero divisor of ##p(x)##.
We will show in general that for all ##i = 0, 1, \dots, n##, ##a_{n-i}g(x) = 0##. We've shown this for ##i = 0## and proceed by induction. I am stuck here. Any advice, please?
Also a question, is ##R[[x]] \subseteq R[x]## where ##R[[x]]## is the ring of formal power series with coefficients from ##R##? By the wikipedia, it seems every polynomial in ##R[x]## has finite degree, but I just wanted to confirm.
fishturtle1 said:
Homework Statement:: Let ##R## be a commutative ring with unity. Let ##p(x) = a_nx^n + a_{n-1}x^{n-1} + \dots + a_1x + a_0## be an element of the polynomial ring ##R[x]##. Prove that ##p(x)## is a zero divisor in ##R[x]## if and only if there is a nonzero element ##b \in R## such that ##bp(x) = 0##. Hint: Let ##g(x) = b_mx^m + b_{m-1}x^{m-1} + \dots + b_1x + b_0## be a nonzero polynomial of minimal degree such that ##g(x)p(x) = 0##. Show that ##b_ma_n = 0## and so ##a_ng(x)## is a polynomial of degree less than ##m## that also gives ##0## when multiplied by ##p(x)##. Conclude that ##a_ng(x) = 0##. Apply a similar argument to show by induction on ##i## that ##a_{n-i}g(x) = 0## for ##i = 0, 1, \dots, n## and show that this implies ##b_mp(x) = 0##.
Relevant Equations:: ,
This is more than confusing. We have ##g(x)p(x)=b_ma_nx^{n+m}+r(x)=0## with ##\deg r(x)<n+m## and so ##b_ma_n=0##.
Wrong. It is a zero divisor by assumption. The contradiction only requires ##\deg g(x)=0## since the argument needed an ##x-##term. We are done here. I don't understand neither the rest of this post nor the induction hint.
The proof goes:
##p## a zero divisor ##\Longrightarrow## ##g\cdot p=0## for some ##g##. Hence we can choose one of minimal degree. Assume ##\deg g > 0 ## then contradiction, ergo ##\deg g = 0##. Done. The other direction is trivial.
The proof goes:
Thank you for the response and the corrections. I'm sorry but I'm confused about the contradiction part.
Proof: ##(\Rightarrow)## Assume ##p## is a zero divisor. Then we can choose a non zero ##g \in R[x]## of minimal degree such that ##gp = 0##. Assume by contradiction that ##\deg g > 0##. We have
$$p(x) = a_nx^n + a_{n-1}x^{n-1} + \dots + a_1x + a_0$$ and
$$g(x) = b_mx^m + b_{m-1}x^{m-1} + \dots + b_1x + b_0$$
and
$$g(x)p(x) = a_nb_mx^{n+m} + r(x) = 0$$
where ##\deg r(x) < n+m##. This implies ##a_nb_m = 0##. Why is ##a_ng(x)## is a zero divisor, if I understand your above post? I think ##a_ng(x) = 0## because we have ##\deg g(x) > \deg a_ng(x)##. My question is sincere, I understand I am wrong.
You can either say "Assume ##\deg g > 0##" (nothing with contradiction here) or distinguish cases: If ##g=b_0## we are done, otherwise there is a ##g## of positive degree. Out of all those we choose one of minimal degree. (That's important. And since the natural numbers - the possible degrees - are bounded from below, such a polynomial exists.)
We have
and
The way you have proven it in the original post. I just was lazy and didn't repeat it. Maybe I should have used dots. ##g## is a zero divisor per assumption. Then ##b_ma_n=0## as the highest degree of the zero polynomial ##0=gp##. Now as before: ##\deg (a_ng) < \deg g## and ##(a_ng)p=0## contradicting the minimality of ##\deg g##. Hence ##\deg g> 0 ## leads to a contradiction, or in case of prove by distinction of cases: such a case does not exist.
No, you were right in your argument, except that it was too long and had redundancies. Wrong was the phrase
fishturtle1 said:
... and thus [g(x)] is not a zero divisor of ##p(x)##.
It is, since we have chosen it as such. You cannot say it isn't. The contradiction is the minimal degree, not the zero dividing.
Sorry for the late response.
Proof: ##(\Rightarrow)## Assume ##p## is a zero divisor. Then we can choose nonzero ##g \in R[x]## of minimal degree such that ##gp = 0##. If ##\deg g = 0##, then we are done. Else ##\deg g > 0##. We have
and so ##g(x)p(x) = b_ma_nx^{m+n} + r(x) = 0## where ##\deg r < m + n##. This shows ##b_ma_n = 0##. We can conclude ##(a_ng)p = 0## and ##\deg a_ng < \deg g## and ##a_ng \neq 0##. This contradicts the minimality of the degree of ##g##.
We can conclude that ##\deg g = 0##.
##(\Leftarrow)## Suppose there exists nonzero ##b \in R## such that ##bp = 0##. Well ##b## is a nonzero element in ##R[x]##. We can conclude ##p## is a zero divisor in ##R[x]##. []
Is this correct?
Close. I think I start to understand the rest of the hint. ##a_ng=0## cannot be ruled out, which you correctly listed as necessary. What if ##a_n## kills all coefficients of ##g##?
Sorry, my bad. I haven't seen that. You can repair this by looking at the next term at ##x^{n+m-1}## and iterate.
Nope ##1+X+X^2+X^3+\dots \in R[[X]]\setminus R[X]##. The other inclusion holds though.
I'm not sure.. We have to consider the case where ##a_ng = 0##. We want to show ##a_{n-i}g= 0## for all ##i = 0, 1, \dots, n##. This holds for ##i = 0##. We proceed by induction on ##i##.
Well,
$$(a_{n-(i+1)}g)p = (a_{n-i-1}g)p = 0$$
and then I think I have to look at the coefficient of ##x^{n-i-1}##?
Hi, I'm still having trouble with the induction step. This is what I have:
Proof: ##(\Rightarrow)## Suppose ##p(x) = a_nx^n + a_{n-1}x^{n-1} + \dots + a_1x + a_0## is a zero divisor in ##R[x]##. Then we can choose a polynomial of minimal degree ##g(x) = b_mx^m + b_{m-1}x^{m-1} + \dots + b_1x + b_0## in ##R[x]## such that ##pg = 0##. If ##\deg g = 0##, we're done. Otherwise, we consider that ##pg = 0## implies ##a_nb_m = 0##. So, ##(a_ng)p = 0## and ##\deg a_ng < \deg g##. If ##a_ng \neq 0##, then we've reached contradiction.
Otherwise ##a_ng = 0## and we need to show ##a_{n-1}g = 0##? I'm not sure how to.
Edit: From the textbook,
##g(x)p(x) = \sum_{l=0}^{n+m} c_lx^l## where ##c_l = \sum_{k=0}^{l} a_kb_{l-k}##
Assume ##a_ng=a_nb_mx^m+a_nb_{m-1}x^{m-1}+\ldots+a_nb_1x+a_nb_0=0##. We also know that ##pg=a_nb_mx^{n+m}+(a_nb_{m-1}+a_{n-1}b_m)x^{n+m-1}+\ldots =0##.
The first equation gives us ##a_nb_{m-1}=0## and the second ##(a_nb_{m-1}+a_{n-1}b_m)=0##. Combining both yields ##a_{n-1}b_m=0##. Now consider ##a_{n-1}g=a_{n-1}b_mx^m+a_{n-1}b_{m-1}x^{m-1}+\ldots = a_{n-1}b_{m-1}x^{m-1}+\ldots## which is again a zero divisor of ##p## of less degree than ##g##. If it is different from zero, we are done.
Assume ##a_{n-1}g=a_{n-1}b_mx^m+a_{n-1}b_{m-1}x^{m-1}+\ldots+a_{n-1}b_1x+a_{n-1}b_0=0##. We also know that ##pg=a_nb_mx^{n+m}+(a_nb_{m-1}+a_{n-1}b_m)x^{n+m-1}+(a_nb_{m-2}+a_{n-1}b_{m-1}+a_{n-2}b_m)x^{n+m-2}+\ldots =0##. Now we look at ##a_nb_{m-2}+a_{n-1}b_{m-1}+a_{n-2}b_m = a_{n-2}b_m=0## and ##a_{n-2}g## etc.
This is the idea. I'm sure it can be written in a better, less algorithmic way.
Thank you. We have
$$f(x)g(x) = \sum_{l=0}^{n+m}c_l$$
where $$c_k = \sum_{l=0}^{k}a_lb_{l-k}$$
We've shown ##a_{n-i}g = 0## for ##i = 0##. We want to show this for ##i = 0, 1, 2, \dots, n##. We proceed by induction on ##i##.
Well, $$c_{n+m-i} = \sum_{k=0}^{n+m-i}a_kb_{n+m-i-k} = \sum_{k=n-i}^{n}a_kb_{n+m-i-k} = a_{n-i}b_m + a_{n-i+1}b_{m-1} + \dots + a_{n-1}b_{m-i+1} + a_nb_{m-i} = a_{n-i}b_m= 0$$
This completes the induction. This implies ##a_{n-i}b_m = 0## for all ##i## and so ##b_mp(x) = 0##. []
i'm not super confident what I've written is correct, but this is what I have so far.
I would rewrite it from scratch.
Let ##gp=0## with ##g=b_mx^m+\ldots+b_0 \neq 0## of minimal degree with these properties.
Statement: ##b_0p=0##.
If ##\deg g = 0## then there is nothing to show.
Now let's test the prototype for the induction step.
If ##\deg g = 1## then ##0=b_1xp+b_0p##, i.e. ##b_1a_n=0##. Then ##a_ngp=0## and ##\deg (a_ng)<\deg g##. By minimality of ##\deg g## we get ##a_ng=0## and so ##a_nb_1=a_nb_0=0##.
How would you go on? If you can prove it for this ##g##, then assume it for all ##g## with ##\deg = k <m## and show it for ##\deg g = m##. It is a bit tricky, as more than one method of proof is involved. That's why I would start from the beginning. Otherwise there is a chance to build in flaws.
Thank you for the response.
Can we possibly avoid doing a proof by contradiction like this?
Proof: ##(\Rightarrow)## Let ##p(x) = a_nx^n + a_{n-1}x^{n-1} + \dots + a_1x + a_0 \in R[x]## and suppose ##p## is a zero divisor. We can choose an element ##g(x) = b_mx^m + b_{m-1}x^{m-1} + \dots + b_1x + b_0## of minimal degree such that ##gp = 0##. This implies ##a_nb_m = 0##. So ##\deg a_ng < \deg g## and ##(a_ng)p = 0##. Thus, ##a_ng = 0##. In particular ##a_nb_m = a_nb_{m-1} = \dots = a_nb_{1} = a_nb_0 = 0##. We'd like to show ##a_{n-i}g = 0## for ##i = 0, 1, \dots, n##. Suppose ##a_{n-j}g = 0## is true up to some ##j = i-1 \ge 0##. We'll show ##a_{n-i}g = 0##. Observe,
$$p(x)g(x) = \sum_{k=0}^{n+m}c_kx^k$$
where $$c_k = \sum_{l=0}^k a_lb_{k-l}$$
Since ##pg = 0## we have
\begin{align*}
c_{n+m-i} &= 0 \\
\sum_{k=0}^{n+m-i}a_kb_{n+m-i-k} &= 0 \\
\sum_{k=n-i}^{n}a_kb_{n+m-i-k} &= 0 \\
a_{n-i}b_m + 0 + \dots + 0 &= 0 \\
a_{n-i}b_m &= 0 \\
\end{align*}
This implies ##(a_{n-i}g)p = 0## and ##\deg a_{n-i}g < \deg g##. Therefore ##a_{n-i}g = 0##. In particular ##a_{n-i}b_m = a_{n-i}b_{m-1} = \dots = a_{n-i}b_1 = a_{n-i}b_0 = 0##. This completes the induction.
Observe, ##b_mp = b_ma_nx^n + b_ma_{n-1}x^{n-1} + \dots + b_ma_1x + b_ma_0 = 0 + 0 + \dots + 0 + 0 = 0##, as desired.
##(\Leftarrow)## Suppose there is nonzero ##b \in R## such that ##bp = 0##. By definition, ##bp## is a zero divisor in ##R[x]##.
You have a strange wording: up to some ## i -1##. You cannot use a running index as a certain border: either it is running, or it is fixed - not both at a time. I therefore do not see how your ##c_k## look like, i.e. how you are allowed to write them as you did.
I wouldn't use an induction, because we have a finite number of terms which all can be checked. We can write it as an and-so-on, but the best way is likely to define ##k:=\min\{\,0\leq j \leq n\,\,|\,a_nb_m=\ldots =a_jb_m=0\}##. With ##a_nb_m=0## we know that such a minimum exists, i.e. ##0\leq k\leq n.##
If we now could show that this implies ##a_{k-1}b_m=0## then all ##a_jb_m=0## and ##b_mp=0\,.##
(I am not sure whether it is sufficient to define ##k## with ##b_m##. Perhaps it is necessary or easier to use ##g##, but then the way back to ##b_m## is ugly.)
If you insist on an induction, then you have to go over ##\deg g = m##. But already the case ##m=1## looks like:
\begin{align*}
gp & =0 =\underbrace{ b_1a_n}_{=0}x^{n+1} + (b_1a_{n-1}+ \underbrace{b_0a_n}_{=0}) x^n+ (b_1a_{n-2}+b_0a_{n-1})x^{n-1}+ \ldots \\
& \Longrightarrow \\
b_1a_{n-1}&=0\\
&\Longrightarrow \\
a_{n-1}gp &= 0 \;\wedge \;\deg (a_{n-1}g) < \deg g \\
&\Longrightarrow \\
b_1a_{n-2} &=0 \\
&\Longrightarrow \\
&\vdots \\
&\Longrightarrow \\
b_1a_1&=0\\
&\Longrightarrow \\
gp&=0=(b_1x+b_0)p=b_1a_0x+b_0p\\
&\Longrightarrow \\
b_1a_0=&0\\
&\Longrightarrow \\
b_0p&=0
\end{align*}
The conclusion ##deg (c\cdot g) < \deg g## has to appear somewhere! I tried to write it as the and-so-on version, but I think the version with the minimal index ##k## where all higher coefficients ##a_kb_m=a_{k+1}b_m=\ldots =a_nb_m=0## is the best. The idea: if ##k## then also ##k-1## which means ##k## is already the lowest possible, i.e. ##k=0##.
